BF533 EZ-KIT Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | L1_DATA_SRAM_A   0xff800000L |
|   | Blackfin environment memory map.
#define  | FIFOLENGTH   0x100 |
PLL configuration for ezkit533
XTL = 27 MHz CLKIN = 13 MHz VCO = 391 MHz CCLK = 391 MHz SCLK = 130 MHz
#define  | PLL_CSEL   0x0000 |
|   | CCLK = VCO */.
#define  | PLL_SSEL   0x0003 |
|   | SCLK = CCLK/3 */.
#define  | PLL_MSEL   0x3A00 |
|   | VCO = 29xCLKIN */.
#define  | PLL_DF   0x0001 |
|   | CLKIN = XTL/2 */.
#define  | CCLK   391000000 |
|   | CORE CLOCK */.
#define  | SCLK   130000000 |
|   | SYSTEM CLOCK */.
#define  | FlashA_PortB_Dir   0x20270007L |
#define  | FlashA_PortB_Data   0x20270005L |
#define  | RAM_START   0 |
#define  | RAM_END   0x100000 |
void  | setLED (uint8_t value) |
|   | Helper Function to use the EzKits LEDS. Can be used by the Application.
uint8_t  | getLED (void) |
| rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
|   | Install an interrupt handler.  More...
void  | Init_RTC (void) |
void  | bfin_null_isr (void) |
◆ set_vector()
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
