    RTEMS
    5.1
Global BSP definitions. More...
#include <libcpu/bf533.h>#include <bspopts.h>#include <bsp/default-initial-extension.h>#include <rtems.h>#include <rtems/score/bfin.h>#include <rtems/bfin/bf533.h>Go to the source code of this file.
| #define | L1_DATA_SRAM_A 0xff800000L |
| Blackfin environment memory map.  | |
| #define | FIFOLENGTH 0x100 |
PLL and clock setup values:  | |
PLL configuration for ezkit533 XTL = 27 MHz CLKIN = 13 MHz VCO = 391 MHz CCLK = 391 MHz SCLK = 130 MHz  | |
| #define | PLL_CSEL 0x0000 |
| CCLK = VCO */.  | |
| #define | PLL_SSEL 0x0003 |
| SCLK = CCLK/3 */.  | |
| #define | PLL_MSEL 0x3A00 |
| VCO = 29xCLKIN */.  | |
| #define | PLL_DF 0x0001 |
| CLKIN = XTL/2 */.  | |
| #define | CCLK 391000000 |
| CORE CLOCK */.  | |
| #define | SCLK 130000000 |
| SYSTEM CLOCK */.  | |
UART setup values  | |
| #define | BAUDRATE 57600 |
| Console Baudrate */.  | |
| #define | WORD_5BITS 0x00 |
| 5 bits word */  | |
| #define | WORD_6BITS 0x01 |
| 6 bits word */  | |
| #define | WORD_7BITS 0x02 |
| 7 bits word */  | |
| #define | WORD_8BITS 0x03 |
| 8 bits word */  | |
| #define | EVEN_PARITY 0x18 |
| Enable EVEN parity */.  | |
| #define | ODD_PARITY 0x08 |
| Enable ODD parity */.  | |
| #define | TWO_STP_BIT 0x04 |
| 2 stop bits */  | |
Ezkit flash ports  | |
| #define | FlashA_PortB_Dir 0x20270007L |
| #define | FlashA_PortB_Data 0x20270005L |
Constants  | |
| #define | RAM_START 0 |
| #define | RAM_END 0x100000 |
functions  | |
| void | setLED (uint8_t value) |
| Helper Function to use the EzKits LEDS. Can be used by the Application.  | |
| uint8_t | getLED (void) |
| Helper Function to use the EzKits LEDS.  | |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler.  More... | |
| void | Init_RTC (void) |
| void | bfin_null_isr (void) |
This include file contains all board IO definitions for TLL6527M.
 1.8.15
