RTEMS
5.1
score
cpu
bfin
include
score
bfin.h
1
13
14
15
* COPYRIGHT (c) 1989-2006.
16
* On-Line Applications Research Corporation (OAR).
17
* modified by Alain Schaefer <alain.schaefer@easc.ch>
18
* and Antonio Giovanini <antonio@atos.com.br>
19
20
* The license and distribution terms for this file may be
21
* found in the file LICENSE in this distribution or at
22
* http://www.rtems.org/license/LICENSE.
23
24
25
26
#ifndef _RTEMS_SCORE_BFIN_H
27
#define _RTEMS_SCORE_BFIN_H
28
29
#ifdef __cplusplus
30
extern
"C"
31
#endif
32
33
34
35
* This file contains the information required to build
36
* RTEMS for a particular member of the Blackfin family.
37
* It does this by setting variables to indicate which
38
* implementation dependent features are present in a particular
39
* member of the family.
40
41
* This is a good place to list all the known CPU models
42
* that this port supports and which RTEMS CPU model they correspond
43
* to.
44
45
46
47
* Figure out all CPU Model Feature Flags based upon compiler
48
* predefines.
49
50
#if defined(__BFIN__)
51
#define CPU_MODEL_NAME "BF533"
52
#define BF_HAS_FPU 0
53
#else
54
55
#error "Unsupported CPU Model"
56
57
#endif
58
59
60
* Define the name of the CPU family.
61
62
63
#define CPU_NAME "BFIN"
64
65
#ifdef __cplusplus
66
67
#endif
68
69
#endif
/* _RTEMS_SCORE_BFIN_H */
