25 #ifndef LIBBSP_BFIN_EZKIT533_BSP_H    26 #define LIBBSP_BFIN_EZKIT533_BSP_H    30 #include <libcpu/bf533.h>    67 #define PLL_CSEL    0x0000          68 #define PLL_SSEL    0x0003          69 #define PLL_MSEL    0x3A00          72 #define CCLK        391000000       73 #define SCLK        130000000       82 #define BAUDRATE    57600           83 #define WORD_5BITS  0x00            84 #define WORD_6BITS  0x01            85 #define WORD_7BITS  0x02            86 #define WORD_8BITS  0x03            87 #define EVEN_PARITY 0x18            88 #define ODD_PARITY  0x08            89 #define TWO_STP_BIT 0x04            98 #define FlashA_PortB_Dir  0x20270007L    99 #define FlashA_PortB_Data 0x20270005L   106 #define L1_DATA_SRAM_A 0xff800000L   108 #define FIFOLENGTH 0x100   116 #define RAM_END   0x100000   129 void setLED (uint8_t value);
   148   rtems_isr_entry     handler,
   161 void bfin_null_isr(
void);
 rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
Blackfin Set up Basic CPU Dependency Settings Based on Compiler Settings.
Basic MMR for the Blackfin 531/532/533 CPU.
void setLED(uint8_t value)
Helper Function to use the EzKits LEDS. Can be used by the Application.
Definition: bspstart.c:145
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
uint8_t getLED(void)
Definition: bspstart.c:153
