#define  | LEON_INTERRUPT_CORRECTABLE_MEMORY_ERROR   1 |
#define  | LEON_INTERRUPT_UART_2_RX_TX   2 |
#define  | LEON_INTERRUPT_UART_1_RX_TX   3 |
#define  | LEON_INTERRUPT_EXTERNAL_0   4 |
#define  | LEON_INTERRUPT_EXTERNAL_1   5 |
#define  | LEON_INTERRUPT_EXTERNAL_2   6 |
#define  | LEON_INTERRUPT_EXTERNAL_3   7 |
#define  | LEON_INTERRUPT_TIMER1   8 |
#define  | LEON_INTERRUPT_TIMER2   9 |
#define  | LEON_INTERRUPT_EMPTY1   10 |
#define  | LEON_INTERRUPT_EMPTY2   11 |
#define  | LEON_INTERRUPT_EMPTY3   12 |
#define  | LEON_INTERRUPT_EMPTY4   13 |
#define  | LEON_INTERRUPT_EMPTY5   14 |
#define  | LEON_INTERRUPT_EMPTY6   15 |
#define  | LEON_TRAP_TYPE(_source)   SPARC_ASYNCHRONOUS_TRAP((_source) + 0x10) |
#define  | LEON_TRAP_SOURCE(_trap)   ((_trap) - 0x10) |
| #define  | LEON_INT_TRAP(_trap) |
#define  | LEON_MEMORY_CONFIGURATION_PROM_SIZE_MASK   0x0003C000 |
#define  | LEON_MEMORY_CONFIGURATION_RAM_SIZE_MASK   0x00001E00 |
#define  | LEON_REG_TIMER_CONTROL_EN   0x00000001  /* 1 = enable counting */ |
#define  | LEON_REG_TIMER_CONTROL_RL   0x00000002  /* 1 = reload at 0 */ |
#define  | LEON_REG_TIMER_CONTROL_LD   0x00000004  /* 1 = load counter */ |
#define  | LEON_REG_UART_CONTROL_RTD   0x000000FF /* RX/TX data */ |
#define  | LEON_REG_UART_STATUS_CLR   0x00000000 /* Clear all status bits */ |
#define  | LEON_REG_UART_STATUS_DR   0x00000001 /* Data Ready */ |
#define  | LEON_REG_UART_STATUS_TSE   0x00000002 /* TX Send Register Empty */ |
#define  | LEON_REG_UART_STATUS_THE   0x00000004 /* TX Hold Register Empty */ |
#define  | LEON_REG_UART_STATUS_BR   0x00000008 /* Break Error */ |
#define  | LEON_REG_UART_STATUS_OE   0x00000010 /* RX Overrun Error */ |
#define  | LEON_REG_UART_STATUS_PE   0x00000020 /* RX Parity Error */ |
#define  | LEON_REG_UART_STATUS_FE   0x00000040 /* RX Framing Error */ |
#define  | LEON_REG_UART_STATUS_ERR   0x00000078 /* Error Mask */ |
#define  | LEON_REG_UART_CTRL_RE   0x00000001 /* Receiver enable */ |
#define  | LEON_REG_UART_CTRL_TE   0x00000002 /* Transmitter enable */ |
#define  | LEON_REG_UART_CTRL_RI   0x00000004 /* Receiver interrupt enable */ |
#define  | LEON_REG_UART_CTRL_TI   0x00000008 /* Transmitter interrupt enable */ |
#define  | LEON_REG_UART_CTRL_PS   0x00000010 /* Parity select */ |
#define  | LEON_REG_UART_CTRL_PE   0x00000020 /* Parity enable */ |
#define  | LEON_REG_UART_CTRL_FL   0x00000040 /* Flow control enable */ |
#define  | LEON_REG_UART_CTRL_LB   0x00000080 /* Loop Back enable */ |
| #define  | LEON_Clear_interrupt(_source) |
| #define  | LEON_Force_interrupt(_source) |
#define  | LEON_Is_interrupt_pending(_source)   (LEON_REG.Interrupt_Pending & (1 << (_source))) |
#define  | LEON_Is_interrupt_masked(_source)   (!(LEON_REG.Interrupt_Mask & (1 << (_source)))) |
| #define  | LEON_Mask_interrupt(_source) |
| #define  | LEON_Unmask_interrupt(_source) |
| #define  | LEON_Disable_interrupt(_source,  _previous) |
| #define  | LEON_Restore_interrupt(_source,  _previous) |
#define  | BSP_Clear_interrupt(_source)   LEON_Clear_interrupt(_source) |
#define  | BSP_Force_interrupt(_source)   LEON_Force_interrupt(_source) |
#define  | BSP_Is_interrupt_pending(_source)   LEON_Is_interrupt_pending(_source) |
#define  | BSP_Is_interrupt_masked(_source)   LEON_Is_interrupt_masked(_source) |
#define  | BSP_Unmask_interrupt(_source)   LEON_Unmask_interrupt(_source) |
#define  | BSP_Mask_interrupt(_source)   LEON_Mask_interrupt(_source) |
#define  | BSP_Disable_interrupt(_source,  _previous)   LEON_Disable_interrupt(_source, _prev) |
#define  | BSP_Restore_interrupt(_source,  _previous)   LEON_Restore_interrupt(_source, _previous) |
#define  | BSP_Cpu_Is_interrupt_masked(_source,  _cpu)   BSP_Is_interrupt_masked(_source) |
#define  | BSP_Cpu_Unmask_interrupt(_source,  _cpu)   BSP_Unmask_interrupt(_source) |
#define  | BSP_Cpu_Mask_interrupt(_source,  _cpu)   BSP_Mask_interrupt(_source) |
#define  | BSP_Cpu_Disable_interrupt(_source,  _previous,  _cpu)   BSP_Disable_interrupt(_source, _prev) |
#define  | BSP_Cpu_Restore_interrupt(_source,  _previous,  _cpu)   BSP_Cpu_Restore_interrupt(_source, _previous) |
#define  | LEON_REG_TIMER_COUNTER_RELOAD_AT_ZERO   0x00000002 |
#define  | LEON_REG_TIMER_COUNTER_STOP_AT_ZERO   0x00000000 |
#define  | LEON_REG_TIMER_COUNTER_LOAD_COUNTER   0x00000004 |
#define  | LEON_REG_TIMER_COUNTER_ENABLE_COUNTING   0x00000001 |
#define  | LEON_REG_TIMER_COUNTER_DISABLE_COUNTING   0x00000000 |
#define  | LEON_REG_TIMER_COUNTER_RELOAD_MASK   0x00000002 |
#define  | LEON_REG_TIMER_COUNTER_ENABLE_MASK   0x00000001 |
#define  | LEON_REG_TIMER_COUNTER_DEFINED_MASK   0x00000003 |
#define  | LEON_REG_TIMER_COUNTER_CURRENT_MODE_MASK   0x00000003 |
This include file contains information pertaining to the LEON-1. The LEON-1 is a custom SPARC V7 implementation. This CPU has a number of on-board peripherals and was developed by the European Space Agency to target space applications.
NOTE: Other than where absolutely required, this version currently supports only the peripherals and bits used by the basic board support package. This includes at least significant pieces of the following items:
- UART Channels A and B
- Real Time Clock
- Memory Control Register
- Interrupt Control
