Global BSP definitions.
More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#include <leon.h>
#include <rtems/irq-extension.h>
#define  | LEON2   1 |
#define  | BSP_IDLE_TASK_BODY   bsp_idle_thread |
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME   "open_eth1" |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH   rtems_leon_open_eth_driver_attach |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111   rtems_smc91111_driver_attach_leon2 |
#define  | HAS_SMC91111 |
#define  | GRETH_SUPPORTED |
#define  | GRETH_MEM_LOAD(addr)   leon_r32_no_cache((uintptr_t) addr) |
#define  | BSP_PCI_BIG_ENDIAN |
#define  | AMBAPPBUS_INFO_AVAIL   /* AMBAPP Bus driver */ |
#define  | GPTIMER_INFO_AVAIL   /* GPTIMER Timer driver */ |
#define  | GRETH_INFO_AVAIL   /* GRETH Ethernet driver */ |
typedef void(*  | bsp_shared_isr) (void *arg) |
| void *  | bsp_idle_thread (uintptr_t ignored) |
|   | Optimized idle task.  More...
int  | rtems_leon_open_eth_driver_attach (struct rtems_bsdnet_ifconfig *config) |
int  | rtems_smc91111_driver_attach_leon2 (struct rtems_bsdnet_ifconfig *config) |
| rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
|   | Install an interrupt handler.  More...
void  | BSP_fatal_exit (uint32_t error) |
void  | bsp_spurious_initialize (void) |
void  | BSP_shared_interrupt_init (void) |
void  | bsp_isr_handler (rtems_vector_number vector) |
void  | BSP_shared_interrupt_clear (int irq) |
void  | BSP_shared_interrupt_unmask (int irq) |
void  | BSP_shared_interrupt_mask (int irq) |
void  | rtems_bsp_delay (int usecs) |
int  | cchip1_register (void) |
void  | console_outbyte_polled (int port, unsigned char ch) |
| int  | console_inbyte_nonblocking (int port) |
int  | CPU_SPARC_HAS_SNOOPING |
int  | RAM_START |
int  | RAM_END |
int  | RAM_SIZE |
int  | PROM_START |
int  | PROM_END |
int  | PROM_SIZE |
int  | CLOCK_SPEED |
int  | end |
