RTEMS  5.1
timer.h File Reference
Timer API for the lpc176x bsp. More...
#include <bsp/timer-defs.h>
rtems_status_code lpc176x_timer_reset (lpc176x_timer_number tnumber)
 resets timer counter and stops it. More...
rtems_status_code lpc176x_timer_set_mode (lpc176x_timer_number tnumber, lpc176x_timer_mode mode)
 Sets mode of the timer (timer, counter rising, counter falling or counter both edges) More...
rtems_status_code lpc176x_timer_start (lpc176x_timer_number tnumber)
 Starts the timer counter. More...
rtems_status_code lpc176x_timer_is_started (lpc176x_timer_number tnumber, bool *is_started)
 true if timer is started. More...
rtems_status_code lpc176x_timer_set_resolution (lpc176x_timer_number tnumber, lpc176x_microseconds resolution)
 sets the resolution in microseconds of the timer More...
rtems_status_code lpc176x_timer_match_config (lpc176x_timer_number tnumber, lpc176x_match_port match_port, lpc176x_match_function function, uint32_t match_value)
 Configures the timer match. More...
rtems_status_code lpc176x_timer_capture_config (lpc176x_timer_number tnumber, lpc176x_capture_port capture_port, lpc176x_capture_function function)
 Configures the capture ports. More...
rtems_status_code lpc176x_timer_external_match_config (lpc176x_timer_number tnumber, lpc176x_match_port match_port, lpc176x_ext_match_function function)
 Configures the external match ports. More...
uint32_t lpc176x_timer_get_capvalue (lpc176x_timer_number tnumber, lpc176x_capture_port capnumber)
 Gets the captured value. More...
uint32_t lpc176x_timer_get_timer_value (lpc176x_timer_number tnumber)
 Gets the timer value. More...
rtems_status_code lpc176x_timer_set_timer_value (lpc176x_timer_number tnumber, uint32_t lpc176x_timer_value)
 Sets the timer value. More...
void lpc176x_timer_isr (void *lpc176x_timer_number)
 Timer generic isroutine. More...
rtems_status_code lpc176x_timer_init (lpc176x_timer_number tnumber)
 Initializes timer in timer mode and resets counter but without starting it, and without any capture or match function. More...
rtems_status_code lpc176x_timer_init_with_interrupt (lpc176x_timer_number tnumber, const lpc176x_isr_funct_vector *vector)
◆ lpc176x_timer_capture_config()
rtems_status_code lpc176x_timer_capture_config ( lpc176x_timer_number  tnumber,
inline
Parameters
tnumberthe device to be modified
capture_portwhich port of this timer will be setted
functionAt which edge/s will the capture work, and if it will interrupt
◆ lpc176x_timer_external_match_config()
rtems_status_code lpc176x_timer_external_match_config ( lpc176x_timer_number  tnumber,
inline
Parameters
match_portwhich match for this timer
functionwhat should do when match: set, clear toggle or nothing
◆ lpc176x_timer_get_capvalue()
uint32_t lpc176x_timer_get_capvalue ( lpc176x_timer_number  tnumber,
inline
Parameters
capnumberwhich capture port for this timer
Returns
the captured value
◆ lpc176x_timer_get_timer_value()
uint32_t lpc176x_timer_get_timer_value ( lpc176x_timer_number  tnumber)
inline
Parameters
tnumberthe device
Returns
the timer value
◆ lpc176x_timer_init()
rtems_status_code lpc176x_timer_init ( lpc176x_timer_number  tnumber)
Parameters
tnumberwhich timer
Returns
RTEMS_SUCCESSFUL when everything ok.
◆ lpc176x_timer_init_with_interrupt()
rtems_status_code lpc176x_timer_init_with_interrupt ( lpc176x_timer_number  tnumber,
const lpc176x_isr_funct_vector *  vector
Parameters
tnumberwhich timer to init
vectorthe functions to be used by the isr.
Returns
◆ lpc176x_timer_is_started()
rtems_status_code lpc176x_timer_is_started ( lpc176x_timer_number  tnumber,
bool *  is_started
inline
Parameters
tnumberthe timer number to check.
is_startedTRUE if the timer is running.
Returns
RTEMS_SUCCESSFUL if the started timer check was successfuly.
◆ lpc176x_timer_isr()
void lpc176x_timer_isr ( void *  lpc176x_timer_number)
Parameters
timernumberthe number of timer.
◆ lpc176x_timer_match_config()
rtems_status_code lpc176x_timer_match_config ( lpc176x_timer_number  tnumber,
Parameters
match_portwhich port of this timer will be setted
functionwhat the timer should do when match: stop timer, clear, and/or interrupt
match_valuethe value that the timer should match.
Returns
RTEMS_SUCCESSFUL if the timer was configured successfuly.
◆ lpc176x_timer_reset()
rtems_status_code lpc176x_timer_reset ( lpc176x_timer_number  tnumber)
inline
Parameters
tnumberthe device to be reseted
Returns
RTEMS_SUCCESSFUL if the timer was reseted successfuly.
◆ lpc176x_timer_set_mode()
rtems_status_code lpc176x_timer_set_mode ( lpc176x_timer_number  tnumber,
inline
Parameters
tnumberthe device to be setted
modethe desired mode
Returns
RTEMS_SUCCESSFUL if the timer's mode was setted successfuly.
◆ lpc176x_timer_set_resolution()
rtems_status_code lpc176x_timer_set_resolution ( lpc176x_timer_number  tnumber,
inline
Parameters
tnumberthe device to be modified.
resolutionhow many microseconds will mean each timer counter unit.
Returns
RTEMS_SUCCESSFUL if the timer resolution was setted successfuly.
◆ lpc176x_timer_set_timer_value()
rtems_status_code lpc176x_timer_set_timer_value ( lpc176x_timer_number  tnumber,
inline
Parameters
tnumberthe timer to modify.
timer_valuethe value to set.
◆ lpc176x_timer_start()
rtems_status_code lpc176x_timer_start ( lpc176x_timer_number  tnumber)
inline
Parameters
tnumberthe device to be started
Returns
RTEMS_SUCCESSFUL if the timer's was started successfuly.
