#define  | LPC176X_TMR0_BASE_ADDR   0x40004000U |
| #define  | LPC176X_T0IR |
| #define  | LPC176X_T0TCR |
| #define  | LPC176X_T0TC |
| #define  | LPC176X_T0PR |
| #define  | LPC176X_T0PC |
| #define  | LPC176X_T0MCR |
| #define  | LPC176X_T0MR0 |
| #define  | LPC176X_T0MR1 |
| #define  | LPC176X_T0MR2 |
| #define  | LPC176X_T0MR3 |
| #define  | LPC176X_T0CCR |
| #define  | LPC176X_T0CR0 |
| #define  | LPC176X_T0CR1 |
| #define  | LPC176X_T0CR2 |
| #define  | LPC176X_T0CR3 |
| #define  | LPC176X_T0EMR |
| #define  | LPC176X_T0CTCR |
#define  | LPC176X_TMR1_BASE_ADDR   0x40008000U |
| #define  | LPC176X_T1IR |
| #define  | LPC176X_T1TCR |
| #define  | LPC176X_T1TC |
| #define  | LPC176X_T1PR |
| #define  | LPC176X_T1PC |
| #define  | LPC176X_T1MCR |
| #define  | LPC176X_T1MR0 |
| #define  | LPC176X_T1MR1 |
| #define  | LPC176X_T1MR2 |
| #define  | LPC176X_T1MR3 |
| #define  | LPC176X_T1CCR |
| #define  | LPC176X_T1CR0 |
| #define  | LPC176X_T1CR1 |
| #define  | LPC176X_T1CR2 |
| #define  | LPC176X_T1CR3 |
| #define  | LPC176X_T1EMR |
| #define  | LPC176X_T1CTCR |
#define  | LPC176X_TMR2_BASE_ADDR   0x40090000U |
| #define  | LPC176X_T2IR |
| #define  | LPC176X_T2TCR |
| #define  | LPC176X_T2TC |
| #define  | LPC176X_T2PR |
| #define  | LPC176X_T2PC |
| #define  | LPC176X_T2MCR |
| #define  | LPC176X_T2MR0 |
| #define  | LPC176X_T2MR1 |
| #define  | LPC176X_T2MR2 |
| #define  | LPC176X_T2MR3 |
| #define  | LPC176X_T2CCR |
| #define  | LPC176X_T2CR0 |
| #define  | LPC176X_T2CR1 |
| #define  | LPC176X_T2CR2 |
| #define  | LPC176X_T2CR3 |
| #define  | LPC176X_T2EMR |
| #define  | LPC176X_T2CTCR |
#define  | LPC176X_TMR3_BASE_ADDR   0x40094000U |
| #define  | LPC176X_T3IR |
| #define  | LPC176X_T3TCR |
| #define  | LPC176X_T3TC |
| #define  | LPC176X_T3PR |
| #define  | LPC176X_T3PC |
| #define  | LPC176X_T3MCR |
| #define  | LPC176X_T3MR0 |
| #define  | LPC176X_T3MR1 |
| #define  | LPC176X_T3MR2 |
| #define  | LPC176X_T3MR3 |
| #define  | LPC176X_T3CCR |
| #define  | LPC176X_T3CR0 |
| #define  | LPC176X_T3CR1 |
| #define  | LPC176X_T3CR2 |
| #define  | LPC176X_T3CR3 |
| #define  | LPC176X_T3EMR |
| #define  | LPC176X_T3CTCR |
#define  | LPC176X_PIN_SELECT_TIMER   3U |
#define  | LPC176X_PINSEL_NO_PORT   999U |
#define  | LPC176X_TIMER_RESET   ( 1U << 1U ) |
#define  | LPC176X_TIMER_START   1U |
#define  | LPC176X_TIMER_MODE_COUNTER_SOURCE_CAP0   0U |
#define  | LPC176X_TIMER_MODE_COUNTER_SOURCE_CAP1   ( 1U << 2U ) |
#define  | LPC176X_TIMER0_CAPTURE_PORTS   { 58U, 59U } |
#define  | LPC176X_TIMER1_CAPTURE_PORTS   { 50U, 51U } |
#define  | LPC176X_TIMER2_CAPTURE_PORTS   { 4U, 5U } |
#define  | LPC176X_TIMER3_CAPTURE_PORTS   { 23U, 24U } |
| #define  | LPC176X_TIMER0_EMATCH_PORTS |
| #define  | LPC176X_TIMER1_EMATCH_PORTS |
#define  | LPC176X_TIMER2_EMATCH_PORTS   { 6U, 7U, 8U, 9U } |
| #define  | LPC176X_TIMER3_EMATCH_PORTS |
#define  | LPC176X_TIMER_DEFAULT_RESOLUTION   1U |
#define  | LPC176X_TIMER_MCR_MASK   7U |
#define  | LPC176X_TIMER_MCR_MASK_SIZE   3U |
#define  | LPC176X_TIMER_CCR_MASK   7U |
#define  | LPC176X_TIMER_CCR_MASK_SIZE   3U |
#define  | LPC176X_TIMER_EMR_MASK   3U |
#define  | LPC176X_TIMER_EMR_MASK_SIZE   2U |
#define  | LPC176X_TIMER_EMR_MASK_OFFSET   4U |
#define  | LPC176X_TIMER_CLEAR_FUNCTION   0U |
#define  | LPC176X_TIMER_PRESCALER_DIVISOR   1000000U |
#define  | LPC176X_TIMER_VECTOR_NUMBER(timernumber)   ( timernumber + 1U ) |
#define  | LPC176X_TIMER_INTERRUPT_SOURCE_BIT(i)   ( 1U << i ) |
#define  | LPC176X_TIMER_MATCH_FUNCTION_COUNT   8U |
#define  | LPC176X_TIMER_CAPTURE_FUNCTION_COUNT   8U |
#define  | LPC176X_ISR_NAME_STRING_SIZE   10U |
| #define  | LPC176X_SET_MCR(mcr,  match_port,  function) |
| #define  | LPC176X_SET_CCR(mcr,  capture_port,  function) |
| #define  | LPC176X_SET_EMR(mcr,  match_port,  function) |
| enum   | lpc176x_capture_port { LPC176X_CAPn_0,
LPC176X_CAPn_1,
LPC176X_CAPTURE_PORTS_COUNT
|   | Capture ports of a timer.  More...
| enum   | lpc176x_match_port {
  LPC176X_MATn_0,
LPC176X_MATn_1,
LPC176X_MATn_2,
LPC176X_MATn_3,
  LPC176X_EMATCH_PORTS_COUNT
|   | Match ports of a timer.  More...
| enum   | lpc176x_timer_mode {
  LPC176X_TIMER_MODE_TIMER,
LPC176X_TIMER_MODE_COUNTER_RISING_CAP0,
LPC176X_TIMER_MODE_COUNTER_FALLING_CAP0,
LPC176X_TIMER_MODE_COUNTER_BOTH_CAP0,
  LPC176X_TIMER_MODE_COUNTER_RISING_CAP1 = ( 1U & ( 1U << 2U ) ),
LPC176X_TIMER_MODE_COUNTER_FALLING_CAP1 = ( 2U & ( 1U << 2U ) ),
LPC176X_TIMER_MODE_COUNTER_BOTH_CAP1 = ( 3U & ( 1U << 2U ) )
|   | Timer modes of a timer.  More...
| enum   | lpc176x_timer_number {
  LPC176X_TIMER_0,
LPC176X_TIMER_1,
LPC176X_TIMER_2,
LPC176X_TIMER_3,
  LPC176X_TIMER_COUNT
|   | The timer devices in the board.  More...
| enum   | lpc176x_isr_function {
  LPC176X_MAT0_ISR_FUNCTION,
LPC176X_MAT1_ISR_FUNCTION,
LPC176X_MAT2_ISR_FUNCTION,
LPC176X_MAT3_ISR_FUNCTION,
  LPC176X_CAP0_ISR_FUNCTION,
LPC176X_CAP1_ISR_FUNCTION,
LPC176X_ISR_FUNCTIONS_COUNT
|   | The index for the isr_funct_vector representing the functions that attends each possible interrupt source for a timer.  More...
| enum   | lpc176x_match_function { LPC176X_TIMER_MATCH_FUNCTION_NONE = 0U,
LPC176X_TIMER_MATCH_FUNCTION_INTERRUPT = 1U,
LPC176X_TIMER_MATCH_FUNCTION_RESET = ( 1U << 1U ),
LPC176X_TIMER_MATCH_FUNCTION_STOP = ( 1U << 2U )
|   | The possible functions at match. This options could be used together.  More...
| enum   | lpc176x_capture_function { LPC176X_TIMER_CAPTURE_FUNCTION_NONE = 0U,
LPC176X_TIMER_CAPTURE_FUNCTION_RISING = 1U,
LPC176X_TIMER_CAPTURE_FUNCTION_FALLING = ( 1U << 1U ),
LPC176X_TIMER_CAPTURE_FUNCTION_INTERRUPT = ( 1U << 2U )
|   | The possible functions at capture. This options could be used together.  More...
| enum   | lpc176x_ext_match_function { LPC176X_TIMER_EXTMATCH_FUNCTION_NONE,
LPC176X_TIMER_EXTMATCH_FUNCTION_CLEAR,
LPC176X_TIMER_EXTMATCH_FUNCTION_SET,
LPC176X_TIMER_EXTMATCH_FUNCTION_TOGGLE
|   | The possible functions at match, for the external ports.  More...
API definitions of the for the timer of the lpc176x bsp.
