22 #ifndef LIBBSP_ARM_LPC176X_TIMER_DEFS_H    23 #define LIBBSP_ARM_LPC176X_TIMER_DEFS_H    32 #define LPC176X_TMR0_BASE_ADDR 0x40004000U    34 #define LPC176X_T0IR ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    36 #define LPC176X_T0TCR ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    38 #define LPC176X_T0TC ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    40 #define LPC176X_T0PR ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    42 #define LPC176X_T0PC ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    44 #define LPC176X_T0MCR ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    46 #define LPC176X_T0MR0 ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    48 #define LPC176X_T0MR1 ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    50 #define LPC176X_T0MR2 ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    52 #define LPC176X_T0MR3 ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    54 #define LPC176X_T0CCR ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    56 #define LPC176X_T0CR0 ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    58 #define LPC176X_T0CR1 ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    60 #define LPC176X_T0CR2 ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    62 #define LPC176X_T0CR3 ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    64 #define LPC176X_T0EMR ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    66 #define LPC176X_T0CTCR ( *(volatile uint32_t *) ( LPC176X_TMR0_BASE_ADDR + \    70 #define LPC176X_TMR1_BASE_ADDR 0x40008000U    72 #define LPC176X_T1IR ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    74 #define LPC176X_T1TCR ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    76 #define LPC176X_T1TC ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    78 #define LPC176X_T1PR ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    80 #define LPC176X_T1PC ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    82 #define LPC176X_T1MCR ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    84 #define LPC176X_T1MR0 ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    86 #define LPC176X_T1MR1 ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    88 #define LPC176X_T1MR2 ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    90 #define LPC176X_T1MR3 ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    92 #define LPC176X_T1CCR ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    94 #define LPC176X_T1CR0 ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    96 #define LPC176X_T1CR1 ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \    98 #define LPC176X_T1CR2 ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \   100 #define LPC176X_T1CR3 ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \   102 #define LPC176X_T1EMR ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \   104 #define LPC176X_T1CTCR ( *(volatile uint32_t *) ( LPC176X_TMR1_BASE_ADDR + \   108 #define LPC176X_TMR2_BASE_ADDR 0x40090000U   110 #define LPC176X_T2IR ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   112 #define LPC176X_T2TCR ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   114 #define LPC176X_T2TC ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   116 #define LPC176X_T2PR ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   118 #define LPC176X_T2PC ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   120 #define LPC176X_T2MCR ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   122 #define LPC176X_T2MR0 ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   124 #define LPC176X_T2MR1 ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   126 #define LPC176X_T2MR2 ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   128 #define LPC176X_T2MR3 ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   130 #define LPC176X_T2CCR ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   132 #define LPC176X_T2CR0 ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   134 #define LPC176X_T2CR1 ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   136 #define LPC176X_T2CR2 ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   138 #define LPC176X_T2CR3 ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   140 #define LPC176X_T2EMR ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   142 #define LPC176X_T2CTCR ( *(volatile uint32_t *) ( LPC176X_TMR2_BASE_ADDR + \   146 #define LPC176X_TMR3_BASE_ADDR 0x40094000U   148 #define LPC176X_T3IR ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   150 #define LPC176X_T3TCR ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   152 #define LPC176X_T3TC ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   154 #define LPC176X_T3PR ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   156 #define LPC176X_T3PC ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   158 #define LPC176X_T3MCR ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   160 #define LPC176X_T3MR0 ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   162 #define LPC176X_T3MR1 ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   164 #define LPC176X_T3MR2 ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   166 #define LPC176X_T3MR3 ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   168 #define LPC176X_T3CCR ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   170 #define LPC176X_T3CR0 ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   172 #define LPC176X_T3CR1 ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   174 #define LPC176X_T3CR2 ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   176 #define LPC176X_T3CR3 ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   178 #define LPC176X_T3EMR ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   180 #define LPC176X_T3CTCR ( *(volatile uint32_t *) ( LPC176X_TMR3_BASE_ADDR + \   190   volatile uint32_t
IR;
   198   volatile uint32_t
TC;
   202   volatile uint32_t
PR;
   206   volatile uint32_t
PC;
   214   volatile uint32_t MR[ 4 ];
   222   volatile uint32_t CR[ 2 ];
   223   volatile uint32_t reserved0;
   224   volatile uint32_t reserved1;
   229   volatile uint32_t reserved2[ 12 ];
   236 #define LPC176X_PIN_SELECT_TIMER 3U   237 #define LPC176X_PINSEL_NO_PORT 999U   239 #define LPC176X_TIMER_RESET ( 1U << 1U )   240 #define LPC176X_TIMER_START 1U   241 #define LPC176X_TIMER_MODE_COUNTER_SOURCE_CAP0 0U   242 #define LPC176X_TIMER_MODE_COUNTER_SOURCE_CAP1 ( 1U << 2U )   243 #define LPC176X_TIMER0_CAPTURE_PORTS { 58U, 59U }   244 #define LPC176X_TIMER1_CAPTURE_PORTS { 50U, 51U }   245 #define LPC176X_TIMER2_CAPTURE_PORTS { 4U, 5U }   246 #define LPC176X_TIMER3_CAPTURE_PORTS { 23U, 24U }   247 #define LPC176X_TIMER0_EMATCH_PORTS { 60U,   \   249                                       LPC176X_PINSEL_NO_PORT, \   250                                       LPC176X_PINSEL_NO_PORT }   251 #define LPC176X_TIMER1_EMATCH_PORTS { 54U, \   253                                       LPC176X_PINSEL_NO_PORT, \   254                                       LPC176X_PINSEL_NO_PORT }   255 #define LPC176X_TIMER2_EMATCH_PORTS { 6U, 7U, 8U, 9U }   256 #define LPC176X_TIMER3_EMATCH_PORTS { 10U, \   258                                       LPC176X_PINSEL_NO_PORT, \   259                                       LPC176X_PINSEL_NO_PORT }   260 #define LPC176X_TIMER_DEFAULT_RESOLUTION 1U   261 #define LPC176X_TIMER_MCR_MASK 7U   262 #define LPC176X_TIMER_MCR_MASK_SIZE 3U   263 #define LPC176X_TIMER_CCR_MASK 7U   264 #define LPC176X_TIMER_CCR_MASK_SIZE 3U   265 #define LPC176X_TIMER_EMR_MASK 3U   266 #define LPC176X_TIMER_EMR_MASK_SIZE 2U   267 #define LPC176X_TIMER_EMR_MASK_OFFSET 4U   268 #define LPC176X_TIMER_CLEAR_FUNCTION 0U   269 #define LPC176X_TIMER_PRESCALER_DIVISOR 1000000U   270 #define LPC176X_TIMER_VECTOR_NUMBER( timernumber ) ( timernumber + 1U )   271 #define LPC176X_TIMER_INTERRUPT_SOURCE_BIT( i ) ( 1U << i )   272 #define LPC176X_TIMER_MATCH_FUNCTION_COUNT 8U   273 #define LPC176X_TIMER_CAPTURE_FUNCTION_COUNT 8U   275 #define LPC176X_ISR_NAME_STRING_SIZE 10U   277 #define LPC176X_SET_MCR( mcr, match_port, function )  \   280   ( 0x7U << ( 3U * match_port ) ), \   281   ( 3U * match_port ) )   282 #define LPC176X_SET_CCR( mcr, capture_port, function )  \   283   SET_FIELD( mcr, function, ( 0x7U << ( 3U * capture_port ) ), \   284   ( 3U * capture_port ) )   285 #define LPC176X_SET_EMR( mcr, match_port, function )  \   286   SET_FIELD( mcr, function, ( 0x3U << ( 2U * match_port + 4U ) ), \   287   ( 2U * match_port + 4U ) )   297   LPC176X_CAPTURE_PORTS_COUNT
   310   LPC176X_EMATCH_PORTS_COUNT
   319   LPC176X_TIMER_MODE_TIMER,
   320   LPC176X_TIMER_MODE_COUNTER_RISING_CAP0,
   321   LPC176X_TIMER_MODE_COUNTER_FALLING_CAP0,
   322   LPC176X_TIMER_MODE_COUNTER_BOTH_CAP0,
   323   LPC176X_TIMER_MODE_COUNTER_RISING_CAP1 = ( 1U & ( 1U << 2U ) ),
   324   LPC176X_TIMER_MODE_COUNTER_FALLING_CAP1 = ( 2U & ( 1U << 2U ) ),
   325   LPC176X_TIMER_MODE_COUNTER_BOTH_CAP1 = ( 3U & ( 1U << 2U ) ),
   348   LPC176X_MAT0_ISR_FUNCTION,
   349   LPC176X_MAT1_ISR_FUNCTION,
   350   LPC176X_MAT2_ISR_FUNCTION,
   351   LPC176X_MAT3_ISR_FUNCTION,
   352   LPC176X_CAP0_ISR_FUNCTION,
   353   LPC176X_CAP1_ISR_FUNCTION,
   354   LPC176X_ISR_FUNCTIONS_COUNT
   365   LPC176X_TIMER_MATCH_FUNCTION_NONE = 0U,
   366   LPC176X_TIMER_MATCH_FUNCTION_INTERRUPT = 1U,
   367   LPC176X_TIMER_MATCH_FUNCTION_RESET = ( 1U << 1U ),
   368   LPC176X_TIMER_MATCH_FUNCTION_STOP = ( 1U << 2U )
   379   LPC176X_TIMER_CAPTURE_FUNCTION_NONE = 0U,
   380   LPC176X_TIMER_CAPTURE_FUNCTION_RISING = 1U,
   381   LPC176X_TIMER_CAPTURE_FUNCTION_FALLING = ( 1U << 1U ),
   382   LPC176X_TIMER_CAPTURE_FUNCTION_INTERRUPT = ( 1U << 2U )
   392   LPC176X_TIMER_EXTMATCH_FUNCTION_NONE,
   393   LPC176X_TIMER_EXTMATCH_FUNCTION_CLEAR,
   394   LPC176X_TIMER_EXTMATCH_FUNCTION_SET,
   395   LPC176X_TIMER_EXTMATCH_FUNCTION_TOGGLE
   411     LPC176X_ISR_FUNCTIONS_COUNT ];
 volatile uint32_t PR
Prescale Register.
Definition: timer-defs.h:202
lpc176x_timer_mode
Timer modes of a timer.
Definition: timer-defs.h:318
volatile uint32_t MCR
Match Control Register.
Definition: timer-defs.h:210
lpc176x_timer_number
The timer devices in the board.
Definition: timer-defs.h:333
lpc176x_match_port
Match ports of a timer.
Definition: timer-defs.h:305
lpc176x_ext_match_function
The possible functions at match, for the external ports.
Definition: timer-defs.h:391
const lpc176x_module module
The module for the RTEMS module starting (power and clock).
Definition: timer-defs.h:424
volatile uint32_t TC
Timer Counter.
Definition: timer-defs.h:198
lpc176x_isr_function
The index for the isr_funct_vector representing the functions that attends each possible interrupt so...
Definition: timer-defs.h:347
lpc176x_timer_device *const device
The address of the controlling registers for the timer.
Definition: timer-defs.h:420
lpc176x_match_function
The possible functions at match. This options could be used together.
Definition: timer-defs.h:364
volatile uint32_t CTCR
Count Control Register.
Definition: timer-defs.h:233
volatile uint32_t IR
Interrupt Register.
Definition: timer-defs.h:190
volatile uint32_t PC
Prescale Counter.
Definition: timer-defs.h:206
volatile uint32_t CCR
Capture Control Register.
Definition: timer-defs.h:218
The Timer device representation.
Definition: timer-defs.h:416
lpc176x_isr_funct const lpc176x_isr_funct_vector[LPC176X_ISR_FUNCTIONS_COUNT]
The vector of functions that attends each possible interrupt source for a timer.
Definition: timer-defs.h:411
volatile uint32_t EMR
External Match Register.
Definition: timer-defs.h:228
Represents the timer device registers.
Definition: timer-defs.h:186
lpc176x_capture_port
Capture ports of a timer.
Definition: timer-defs.h:294
Definitions types used by some devices in common.
lpc176x_module
lpc176x module representation.
Definition: common-types.h:44
volatile uint32_t TCR
Timer Control Register.
Definition: timer-defs.h:194
void(* lpc176x_isr_funct)(const lpc176x_timer_number tnumber)
A function that attends an interruption for a timer.
Definition: timer-defs.h:404
const lpc176x_isr_funct_vector * funct_vector
The vector of isr functions for this timer.
Definition: timer-defs.h:442
uint32_t lpc176x_pin_number
A pin of the board.
Definition: common-types.h:32
The Timer functions.
Definition: timer-defs.h:438
lpc176x_capture_function
The possible functions at capture. This options could be used together.
Definition: timer-defs.h:378
