score/cpu/m68k/rtems/score/cpu.h File Reference
Motorola M68K CPU Dependent Source. More...
#include <rtems/score/types.h>
#include <rtems/score/m68k.h>
Include dependency graph for score/cpu/m68k/rtems/score/cpu.h:
struct  Context_Control
 This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More...
struct  Context_Control_fp
 This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More...
struct  CPU_Interrupt_frame
 This defines the set of integer and processor state registers that must be saved during an interrupt. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
struct  _CPU_ISR_handler_entry
#define CPU_INLINE_ENABLE_DISPATCH   TRUE
#define CPU_SIMPLE_VECTORED_INTERRUPTS   TRUE
#define CPU_HAS_SOFTWARE_INTERRUPT_STACK   1
#define CPU_HAS_HARDWARE_INTERRUPT_STACK   0
#define CPU_ALLOCATE_INTERRUPT_STACK   1
#define CPU_ISR_PASSES_FRAME_POINTER   0
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
#define CPU_PROVIDES_IDLE_THREAD_BODY   TRUE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_STRUCTURE_ALIGNMENT   __attribute__ ((aligned (4)))
#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC   TRUE
#define CPU_BIG_ENDIAN   TRUE
#define CPU_LITTLE_ENDIAN   FALSE
#define CPU_PER_CPU_CONTROL_SIZE   0
#define M68K_FP_STATE_SIZE   216
#define _CPU_Context_Get_SP(_context)   (_context)->a7_msp
#define _CPU_Context_Fp_start(_base, _offset)   ((void *) _Addresses_Add_offset( (_base), (_offset) ) )
#define _CPU_Context_Initialize_fp(_fp_area)
#define M68K_MOVE_A7   0x3F3C
#define M68K_JMP   0x4EF9
#define CPU_MODES_INTERRUPT_LEVEL   0x00000007 /* interrupt level in mode */
#define CPU_MODES_INTERRUPT_MASK   0x00000007 /* interrupt level in mode */
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   1024
#define CPU_INTERRUPT_NUMBER_OF_VECTORS   256
#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER   (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   M68K_CPU_STACK_MINIMUM_SIZE
#define CPU_PRIORITY_MAXIMUM   M68K_CPU_PRIORITY_MAXIMUM
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   4
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_PARTITION_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   0
#define _CPU_Initialize_vectors()
#define _CPU_ISR_Disable(_level)   m68k_disable_interrupts( _level )
#define _CPU_ISR_Enable(_level)   m68k_enable_interrupts( _level )
#define _CPU_ISR_Flash(_level)   m68k_flash_interrupts( _level )
#define _CPU_ISR_Set_level(_newlevel)   m68k_set_interrupt_level( _newlevel )
#define _CPU_Fatal_halt(_source, _error)
#define CPU_USE_GENERIC_BITFIELD_CODE   FALSE
#define CPU_USE_GENERIC_BITFIELD_DATA   FALSE
#define _CPU_Bitfield_Find_first_bit(_value, _output)
#define _CPU_Priority_Mask(_bit_number)   ( 0x8000 >> (_bit_number) )
#define _CPU_Priority_bits_index(_priority)   (_priority)
typedef uint32_t CPU_Counter_ticks
uint32_t _CPU_ISR_Get_level (void)
 Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More...
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
 Initializes the CPU context. More...
void * _CPU_Thread_Idle_body (uintptr_t ignored)
 This routine is the CPU dependent IDLE thread body. More...
void _CPU_Initialize (void)
 CPU initialization. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs a "raw" interrupt handler directly into the processor's vector table. More...
void _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs an interrupt vector. More...
void _CPU_Install_interrupt_stack (void)
 This routine installs the hardware interrupt stack pointer. More...
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context. More...
void _CPU_Context_Restart_self (Context_Control *the_context)
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
 This routine saves the floating point context passed to it. More...
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
 This routine restores the floating point context passed to it. More...
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 This method prints the CPU exception frame. More...
CPU_Counter_ticks _CPU_Counter_read (void)
void * _VBR
SCORE_EXTERN _CPU_ISR_handler_entry _CPU_ISR_jump_table [256]
const unsigned char _CPU_m68k_BFFFO_table [256]
This include file contains information pertaining to the Motorola m68xxx processor family.
◆ _CPU_Bitfield_Find_first_bit
#define _CPU_Bitfield_Find_first_bit (   _value,
  _output
Value:
register int dumby; \
__asm__ volatile ( " move.w %2,%1\n" \
" lsr.w #8,%1\n" \
" beq.s 1f\n" \
" move.b (%3,%1.w),%0\n" \
" and.l #0x000000ff,%0\n"\
" bra.s 0f\n" \
"1: moveq.l #8,%0\n" \
" add.b (%3,%2.w),%0\n" \
"0:\n" \
: "=&d" ((_output)), "=&d" ((dumby)) \
: "d" ((_value)), "ao" ((_CPU_m68k_BFFFO_table)) \
: "cc" ) ; \
◆ _CPU_Context_Fp_start
#define _CPU_Context_Fp_start (   _base,
  _offset
Value:
(_base), \
(_offset) + CPU_CONTEXT_FP_SIZE - 4 \
RTEMS_INLINE_ROUTINE void * _Addresses_Add_offset(const void *base, uintptr_t offset)
Add offset to an address.
Definition: address.h:50
◆ _CPU_Context_Initialize_fp [1/2]
#define _CPU_Context_Initialize_fp (   _fp_area)
Value:
Context_Control_fp *_fp; \
_fp = *(Context_Control_fp **)_fp_area; \
_fp->_exception_bits = 0; \
_fp->_trap_enable_bits = 0; \
_fp->_sticky_bits = 0; \
_fp->_rounding_mode = 0; /* ROUND_TO_NEAREST */ \
_fp->_format = 0; /* NIL */ \
_fp->_last_operation = 0; /* NOOP */ \
_fp->_operand1.df = 0; \
_fp->_operand2.df = 0; \
This defines the complete set of floating point registers that must be saved during any context switc...
Definition: score/cpu/arm/rtems/score/cpu.h:294
◆ _CPU_Context_Initialize_fp [2/2]
Value:
uint32_t *_fp_context = (uint32_t *)*(_fp_area); \
*(--(_fp_context)) = 0; \
*(_fp_area) = (void *)(_fp_context); \
◆ _CPU_Fatal_halt
#define _CPU_Fatal_halt (   _source,
  _error
Value:
{ __asm__ volatile( "movl %0,%%d0; " \
"orw #0x0700,%%sr; " \
"stop #0x2700" : "=d" ((_error)) : "0" ((_error)) ); \
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
