rtl.h File Reference
RTEMS Run-Time Linker. More...
#include <link.h>
#include <rtems/chain.h>
#include <rtems/rtl/rtl-allocator.h>
#include <rtems/rtl/rtl-fwd.h>
#include <rtems/rtl/rtl-obj.h>
#include <rtems/rtl/rtl-obj-cache.h>
#include <rtems/rtl/rtl-obj-comp.h>
#include <rtems/rtl/rtl-unresolved.h>
Include dependency graph for rtl.h:
struct  rtems_rtl_data_s
 The global RTL data. More...
#define RTL_XGLUE(a, b)   ab
 Macros to glue two tokens.
#define RTL_GLUE(a, b)   RTL_XGLUE(a,b)
#define RTEMS_RTL_SYMS_GLOBAL_BUCKETS   (32)
 The number of buckets in the global symbol table.
#define RTEMS_RTL_UNRESOLVED_BLOCK_SIZE   (64)
 The number of relocation record per block in the unresolved table.
typedef void(* rtems_rtl_cdtor_t) (void)
 The type of constructor/destructor function.
void _rtld_debug_state (void)
 Debugger break function. More...
rtems_rtl_data_trtems_rtl_data (void)
 Get the RTL data with out locking. More...
rtems_rtl_symbols_trtems_rtl_global_symbols (void)
 Get the RTL global symbol table with out locking. More...
rtems_rtl_unresolved_trtems_rtl_unresolved (void)
 Get the RTL resolved table with out locking. More...
void rtems_rtl_obj_caches (rtems_rtl_obj_cache_t **symbols, rtems_rtl_obj_cache_t **strings, rtems_rtl_obj_cache_t **relocs)
 Get the RTL symbols, strings, or relocations object file caches. More...
void rtems_rtl_obj_caches_flush (void)
 Flush all the object file caches.
void rtems_rtl_obj_comp (rtems_rtl_obj_comp_t **decomp, rtems_rtl_obj_cache_t *cache, int fd, int compression, off_t offset)
 Get the RTL decompressor setting the cache and the offset in the file the compressed stream starts. More...
rtems_rtl_data_trtems_rtl_lock (void)
 Lock the Run-time Linker. More...
bool rtems_rtl_unlock (void)
 Unlock the Run-time Linker. More...
rtems_rtl_obj_trtems_rtl_check_handle (void *handle)
 Check a pointer is a valid object file descriptor returning the pointer as that type. More...
rtems_rtl_obj_trtems_rtl_find_obj (const char *name)
 Find the object given a file name. More...
rtems_rtl_obj_trtems_rtl_load_object (const char *name, int mode)
 Load an object file into memory relocating it. More...
bool rtems_rtl_unload_object (rtems_rtl_obj_t *obj)
 Unload an object file. More...
void rtems_rtl_run_ctors (rtems_rtl_obj_t *obj)
 Run any constructor functions the object file may contain. More...
int rtems_rtl_get_error (char *message, size_t max_message)
 Get the last error message clearing it. More...
bool rtems_rtl_path_append (const char *path)
 Append the path to the search path. More...
bool rtems_rtl_path_prepend (const char *path)
 Prepend the path to the search path. More...
void rtems_rtl_base_sym_global_add (const unsigned char *esyms, unsigned int count)
 Add an exported symbol table to the global symbol table. More...
rtems_rtl_obj_trtems_rtl_baseimage (void)
 Return the object file descriptor for the base image. More...
struct r_debug _rtld_debug
 The global debugger interface variable.
This is the POSIX interface to run-time loading of code into RTEMS.
◆ _rtld_debug_state()
void _rtld_debug_state ( void  )
Call when debugging to have it read the _rtld_debug variable.
◆ rtems_rtl_base_sym_global_add()
void rtems_rtl_base_sym_global_add ( const unsigned char *  esyms,
unsigned int  count
This call is normally used by an object file when loaded that contains a global symbol table.
Parameters
esymsThe exported symbol table.
countThe size of the exported symbol table.
◆ rtems_rtl_baseimage()
rtems_rtl_obj_t* rtems_rtl_baseimage ( void  )
The object file descriptor returned is created when the run time linker is initialised.
Assumes the RTL has been locked.
Returns
rtl_obj* The object file descriptor for the base image. NULL is returned if the load fails.
◆ rtems_rtl_check_handle()
rtems_rtl_obj_t* rtems_rtl_check_handle ( void *  handle)
Parameters
handlePointer to the object file to be validated.
Returns
rtl_obj* The object file descriptor. NULL is returned if invalid.
References rtems_rtl_data_s::objects, rtems_chain_first(), and rtems_chain_is_tail().
◆ rtems_rtl_data()
rtems_rtl_data_t* rtems_rtl_data ( void  )
This call assumes the RTL is locked.
Returns
rtems_rtl_data_t* The RTL data after being locked.
Return values
NULLThe RTL data is not initialised.
◆ rtems_rtl_find_obj()
rtems_rtl_obj_t* rtems_rtl_find_obj ( const char *  name)
Parameters
nameThe name of the object file.
Return values
NULLNo object file with that name found.
Returns
rtems_rtl_obj_t* The object file descriptor.
References rtems_rtl_data_s::objects, rtems_chain_first(), rtems_chain_is_tail(), and rtems_rtl_parse_name().
◆ rtems_rtl_get_error()
int rtems_rtl_get_error ( char *  message,
size_t  max_message
This operation locks the run time linker and therefore keeps the RTL thread safe but this call is not thread safe is multiple threads are loading object files at the same time. This call is provided to map to the dlopen family of calls.
Parameters
messagePointer to a buffer to copy the message into.
max_messageThe maximum message that can be copied.
Returns
int The last error number.
◆ rtems_rtl_global_symbols()
rtems_rtl_symbols_t* rtems_rtl_global_symbols ( void  )
This call assmes the RTL is locked.
Returns
rtems_rtl_symbols_t* The RTL global symbols after being locked.
Return values
References rtems_rtl_data_s::globals, and rtems_rtl_set_error().
Referenced by rtems_rtl_symbol_global_find().
◆ rtems_rtl_load_object()
rtems_rtl_obj_t* rtems_rtl_load_object ( const char *  name,
int  mode
It will not be resolved against other symbols in other object files or the base image.
The name can be a file name for an object file or it can be encoded to reference an archive of object modules (static library). This encoding is specific to RTEMS and allows dependences to specify an archive without the searching overhead normally incurred by linkers locating object files in an archive. The file name format rules are:
  1. Absolute file references a specific object file in the architecture specific location on the file system.
  2. Relative file references an object format file in the search path.
  3. Absolute archive and file reference to a specific location in the file system. The archive and file are encoded as 'archive:file [@offset]' where 'archive' is a valid file at the absolute path in the file system, and 'file' is a contained in the archive, and optionally an offset to the 'file' in the 'archive'. If no offset is provided the archive is searched.
  4. Relative archive and file in the search path. The encoding is the same as described in item 3 of this list.
Parameters
modeThe mode of the load as defined by the dlopen call.
Returns
rtl_obj* The object file descriptor. NULL is returned if the load fails.
References rtems_rtl_trace().
◆ rtems_rtl_lock()
rtems_rtl_data_t* rtems_rtl_lock ( void  )
Returns
Return values
NULLThe RTL data could not be initialised or locked. Typically this means the lock could not be created.
◆ rtems_rtl_obj_caches()
void rtems_rtl_obj_caches ( rtems_rtl_obj_cache_t **  symbols,
rtems_rtl_obj_cache_t **  strings,
rtems_rtl_obj_cache_t **  relocs
Parameters
symbolsPointer to the location to set the cache into. Returns NULL is rtl is not initialised. If NULL is passed in no value set.
stringsPointer to the location to set the cache into. Returns NULL is rtl is not initialised. If NULL is passed in no value set.
relocsPointer to the location to set the cache into. Returns NULL is rtl is not initialised. If NULL is passed in no value set.
References rtems_rtl_data_s::relocs, rtems_rtl_data_s::strings, and rtems_rtl_data_s::symbols.
Referenced by rtems_rtl_elf_file_check(), rtems_rtl_elf_file_load(), and rtems_rtl_rap_file_load().
◆ rtems_rtl_obj_comp()
void rtems_rtl_obj_comp ( rtems_rtl_obj_comp_t **  decomp,
rtems_rtl_obj_cache_t cache,
int  fd,
int  compression,
off_t  offset
Parameters
decompPointer to the location to set the compressor into. Returns NULL is rtl is not initialised.
cacheThe cache to read the file with. Saves needing an extrs buffer.
offsetThe offset in the file the compressed stream starts.
References rtems_rtl_data_s::decomp, and rtems_rtl_obj_comp_set().
◆ rtems_rtl_path_append()
bool rtems_rtl_path_append ( const char *  path)
Parameters
pathThe path to append.
Return values
falseThe path could not be appended.
trueThe path was appended.
◆ rtems_rtl_path_prepend()
bool rtems_rtl_path_prepend ( const char *  path)
Parameters
pathThe path to prepend.
Return values
falseThe path could not be prepended.
trueThe path was prepended.
◆ rtems_rtl_run_ctors()
void rtems_rtl_run_ctors ( rtems_rtl_obj_t obj)
This call assumes the linker is unlocked.
Parameters
objThe object file.
References rtems_rtl_obj_run_ctors().
◆ rtems_rtl_unload_object()
bool rtems_rtl_unload_object ( rtems_rtl_obj_t obj)
This only happens when the user count is 0.
Parameters
objThe object file descriptor.
Return values
trueThe object file has been unloaded.
falseThe object file could not be unloaded.
◆ rtems_rtl_unlock()
bool rtems_rtl_unlock ( void  )
Returns
True The RTL is unlocked.
False The RTL could not be unlocked. Not much you can do.
References rtems_rtl_data_s::lock, rtems_semaphore_release(), and RTEMS_SUCCESSFUL.
◆ rtems_rtl_unresolved()
rtems_rtl_unresolved_t* rtems_rtl_unresolved ( void  )
Returns
rtems_rtl_unresolv_t* The RTL unresolved symbols and reloc records.
Return values
References rtems_rtl_set_error(), and rtems_rtl_data_s::unresolved.
Referenced by rtems_rtl_unresolved_interate(), and rtems_rtl_unresolved_remove().
