Files | Macros | Typedefs | Functions
Chain API. More...
Collaboration diagram for Chains:
file  chainappendnotify.c
 rtems_chain_append_with_notification() implementation.
file  chaingetnotify.c
 rtems_chain_get_with_notification() implementation.
file  chaingetwait.c
 rtems_chain_get_with_wait() implementation.
file  chainprependnotify.c
 rtems_chain_prepend_with_notification() implementation.
#define RTEMS_CHAIN_INITIALIZER_EMPTY(name)   CHAIN_INITIALIZER_EMPTY( name )
 Chain initializer for an empty chain with designator name.
#define RTEMS_CHAIN_INITIALIZER_ONE_NODE(node)   CHAIN_INITIALIZER_ONE_NODE( node )
 Chain initializer for a chain with one node. More...
#define RTEMS_CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(chain)   CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN( chain )
 Chain node initializer for a chain containing exactly this node. More...
#define RTEMS_CHAIN_DEFINE_EMPTY(name)   rtems_chain_control name = RTEMS_CHAIN_INITIALIZER_EMPTY( name )
 Chain definition for an empty chain with designator name.
typedef Chain_Node rtems_chain_node
typedef Chain_Control rtems_chain_control
rtems_status_code rtems_chain_append_with_notification (rtems_chain_control *chain, rtems_chain_node *node, rtems_id task, rtems_event_set events)
 Appends the node to the chain and sends the events to the task if the chain was empty before the append. More...
rtems_status_code rtems_chain_prepend_with_notification (rtems_chain_control *chain, rtems_chain_node *node, rtems_id task, rtems_event_set events)
 Prepends the node to the chain and sends the events to the task if the chain was empty before the prepend. More...
rtems_status_code rtems_chain_get_with_notification (rtems_chain_control *chain, rtems_id task, rtems_event_set events, rtems_chain_node **node)
 Gets the first node of the chain and sends the events to the task if the chain is empty after the get. More...
rtems_status_code rtems_chain_get_with_wait (rtems_chain_control *chain, rtems_event_set events, rtems_interval timeout, rtems_chain_node **node)
 Gets the first node of the chain and sends the events to the task if the chain is empty afterwards. More...
RTEMS_INLINE_ROUTINE void rtems_chain_initialize (rtems_chain_control *the_chain, void *starting_address, size_t number_nodes, size_t node_size)
 Initialize a chain Header. More...
RTEMS_INLINE_ROUTINE void rtems_chain_initialize_empty (rtems_chain_control *the_chain)
 Initialize this chain as empty. More...
RTEMS_INLINE_ROUTINE void rtems_chain_set_off_chain (rtems_chain_node *node)
 Set off chain. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_node_off_chain (const rtems_chain_node *node)
 Is the node off chain. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_null_node (const rtems_chain_node *the_node)
 Is the chain node pointer NULL. More...
RTEMS_INLINE_ROUTINE rtems_chain_nodertems_chain_head (rtems_chain_control *the_chain)
 Return pointer to Chain Head. More...
RTEMS_INLINE_ROUTINE const rtems_chain_nodertems_chain_immutable_head (const rtems_chain_control *the_chain)
 Return pointer to immutable Chain Head. More...
RTEMS_INLINE_ROUTINE rtems_chain_nodertems_chain_tail (rtems_chain_control *the_chain)
 Return pointer to Chain Tail. More...
RTEMS_INLINE_ROUTINE const rtems_chain_nodertems_chain_immutable_tail (const rtems_chain_control *the_chain)
 Return pointer to immutable Chain Tail. More...
RTEMS_INLINE_ROUTINE rtems_chain_nodertems_chain_first (rtems_chain_control *the_chain)
 Return pointer to Chain's First node after the permanent head. More...
RTEMS_INLINE_ROUTINE const rtems_chain_nodertems_chain_immutable_first (const rtems_chain_control *the_chain)
 Return pointer to immutable Chain's First node. More...
RTEMS_INLINE_ROUTINE rtems_chain_nodertems_chain_last (rtems_chain_control *the_chain)
 Return pointer to Chain's Last node before the permanent tail. More...
RTEMS_INLINE_ROUTINE const rtems_chain_nodertems_chain_immutable_last (const rtems_chain_control *the_chain)
 Return pointer to immutable Chain's Last node. More...
RTEMS_INLINE_ROUTINE rtems_chain_nodertems_chain_next (rtems_chain_node *the_node)
 Return pointer the next node from this node. More...
RTEMS_INLINE_ROUTINE const rtems_chain_nodertems_chain_immutable_next (const rtems_chain_node *the_node)
 Return pointer the immutable next node from this node. More...
RTEMS_INLINE_ROUTINE rtems_chain_nodertems_chain_previous (rtems_chain_node *the_node)
 Return pointer the previous node from this node. More...
RTEMS_INLINE_ROUTINE const rtems_chain_nodertems_chain_immutable_previous (const rtems_chain_node *the_node)
 Return pointer the immutable previous node from this node. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_are_nodes_equal (const rtems_chain_node *left, const rtems_chain_node *right)
 Are Two nodes equal. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_empty (const rtems_chain_control *the_chain)
 Is the chain empty. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_first (const rtems_chain_node *the_node)
 Is this the first node on the chain. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_last (const rtems_chain_node *the_node)
 Is this the last node on the chain. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_has_only_one_node (const rtems_chain_control *the_chain)
 Does this chain have only one node. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_head (const rtems_chain_control *the_chain, const rtems_chain_node *the_node)
 Is this node the chain head. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_tail (const rtems_chain_control *the_chain, const rtems_chain_node *the_node)
 Is this node the chain tail. More...
RTEMS_INLINE_ROUTINE void rtems_chain_extract (rtems_chain_node *the_node)
 Extract the specified node from a chain. More...
RTEMS_INLINE_ROUTINE void rtems_chain_extract_unprotected (rtems_chain_node *the_node)
 Extract the specified node from a chain (unprotected). More...
RTEMS_INLINE_ROUTINE rtems_chain_nodertems_chain_get (rtems_chain_control *the_chain)
 Obtain the first node on a chain. More...
RTEMS_INLINE_ROUTINE rtems_chain_nodertems_chain_get_unprotected (rtems_chain_control *the_chain)
 See _Chain_Get_unprotected().
RTEMS_INLINE_ROUTINE void rtems_chain_insert (rtems_chain_node *after_node, rtems_chain_node *the_node)
 Insert a node on a chain. More...
RTEMS_INLINE_ROUTINE void rtems_chain_insert_unprotected (rtems_chain_node *after_node, rtems_chain_node *the_node)
 See _Chain_Insert_unprotected().
RTEMS_INLINE_ROUTINE void rtems_chain_append (rtems_chain_control *the_chain, rtems_chain_node *the_node)
 Append a node on the end of a chain. More...
RTEMS_INLINE_ROUTINE void rtems_chain_append_unprotected (rtems_chain_control *the_chain, rtems_chain_node *the_node)
 Append a node on the end of a chain (unprotected). More...
RTEMS_INLINE_ROUTINE void rtems_chain_prepend (rtems_chain_control *the_chain, rtems_chain_node *the_node)
 Prepend a node. More...
RTEMS_INLINE_ROUTINE void rtems_chain_prepend_unprotected (rtems_chain_control *the_chain, rtems_chain_node *the_node)
 Prepend a node (unprotected). More...
RTEMS_INLINE_ROUTINE bool rtems_chain_append_with_empty_check (rtems_chain_control *chain, rtems_chain_node *node)
 Checks if the chain is empty and appends the node. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_prepend_with_empty_check (rtems_chain_control *chain, rtems_chain_node *node)
 Checks if the chain is empty and prepends the node. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_get_with_empty_check (rtems_chain_control *chain, rtems_chain_node **node)
 Tries to get the first node and check if the chain is empty afterwards. More...
RTEMS_INLINE_ROUTINE size_t rtems_chain_node_count_unprotected (const rtems_chain_control *chain)
 Returns the node count of the chain. More...
Chain API.
◆ RTEMS_CHAIN_INITIALIZER_ONE_NODE
#define RTEMS_CHAIN_INITIALIZER_ONE_NODE (   node)    CHAIN_INITIALIZER_ONE_NODE( node )
See also
RTEMS_CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN().
◆ RTEMS_CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN
#define RTEMS_CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN (   chain)    CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN( chain )
See also
RTEMS_CHAIN_INITIALIZER_ONE_NODE().
◆ rtems_chain_append()
RTEMS_INLINE_ROUTINE void rtems_chain_append ( rtems_chain_control the_chain,
rtems_chain_node the_node
This routine appends the_node onto the end of the_chain.
NOTE: It disables interrupts to ensure the atomicity of the append operation.
References _Chain_Append().
Referenced by rtems_chain_insert_unprotected().
◆ rtems_chain_append_unprotected()
RTEMS_INLINE_ROUTINE void rtems_chain_append_unprotected ( rtems_chain_control the_chain,
NOTE: It does NOT disable interrupts to ensure the atomicity of the append operation.
References _Chain_Append_unprotected(), and rtems_chain_prepend().
◆ rtems_chain_append_with_empty_check()
RTEMS_INLINE_ROUTINE bool rtems_chain_append_with_empty_check ( rtems_chain_control chain,
rtems_chain_node node
Interrupts are disabled to ensure the atomicity of the operation.
Return values
trueThe chain was empty before the append.
falseThe chain contained at least one node before the append.
References _Chain_Append_with_empty_check(), and rtems_chain_prepend_with_empty_check().
Referenced by rtems_chain_append_with_notification(), and rtems_chain_prepend_unprotected().
◆ rtems_chain_append_with_notification()
rtems_status_code rtems_chain_append_with_notification ( rtems_chain_control chain,
rtems_chain_node node,
rtems_id  task,
See also
rtems_chain_append_with_empty_check() and rtems_event_send().
Return values
RTEMS_SUCCESSFULSuccessful operation.
RTEMS_INVALID_IDNo such task.
References rtems_chain_append_with_empty_check(), rtems_event_send(), and RTEMS_SUCCESSFUL.
◆ rtems_chain_are_nodes_equal()
RTEMS_INLINE_ROUTINE bool rtems_chain_are_nodes_equal ( const rtems_chain_node left,
const rtems_chain_node right
This function returns true if left and right are equal, and false otherwise.
Parameters
[in]leftis the node on the left hand side of the comparison.
[in]rightis the node on the left hand side of the comparison.
Return values
trueleft is equal to right.
falseleft is not equal to right
◆ rtems_chain_extract()
RTEMS_INLINE_ROUTINE void rtems_chain_extract ( rtems_chain_node the_node)
This routine extracts the_node from the chain on which it resides. It disables interrupts to ensure the atomicity of the extract operation.
  • the_node specifies the node to extract
References _Chain_Extract().
Referenced by rtems_chain_is_tail(), rtems_rtl_obj_erase_sections(), and rtems_rtl_obj_free().
◆ rtems_chain_extract_unprotected()
RTEMS_INLINE_ROUTINE void rtems_chain_extract_unprotected ( rtems_chain_node the_node)
References _Chain_Extract_unprotected(), and rtems_chain_get().
◆ rtems_chain_first()
RTEMS_INLINE_ROUTINE rtems_chain_node* rtems_chain_first ( rtems_chain_control the_chain)
This function returns a pointer to the first node on the chain after the head.
Parameters
[in]the_chainis the chain to be operated upon.
Returns
This method returns the first node of the chain.
References _Chain_First().
Referenced by rtems_rtl_chain_iterate(), rtems_rtl_check_handle(), rtems_rtl_find_obj(), rtems_rtl_obj_erase_sections(), rtems_rtl_unresolved_interate(), and rtems_rtl_unresolved_table_close().
◆ rtems_chain_get()
RTEMS_INLINE_ROUTINE rtems_chain_node* rtems_chain_get ( rtems_chain_control the_chain)
This function removes the first node from the_chain and returns a pointer to that node. If the_chain is empty, then NULL is returned.
Returns
This method returns a pointer a node. If a node was removed, then a pointer to that node is returned. If the_chain was empty, then NULL is returned.
NOTE: It disables interrupts to ensure the atomicity of the get operation.
References _Chain_Get().
Referenced by rtems_chain_extract_unprotected().
◆ rtems_chain_get_with_empty_check()
RTEMS_INLINE_ROUTINE bool rtems_chain_get_with_empty_check ( rtems_chain_control chain,
rtems_chain_node **  node
This function removes the first node from the chain and returns a pointer to that node in node. If the chain is empty, then NULL is returned.
Return values
trueThe chain is empty after the node removal.
falseThe chain contained at least one node after the node removal.
References _Chain_Get_with_empty_check().
Referenced by rtems_chain_get_with_notification(), and rtems_chain_prepend_with_empty_check().
◆ rtems_chain_get_with_notification()
rtems_status_code rtems_chain_get_with_notification ( rtems_chain_control chain,
rtems_id  task,
See also
rtems_chain_get_with_empty_check() and rtems_event_send().
Return values
References rtems_chain_get_with_empty_check(), rtems_event_send(), and RTEMS_SUCCESSFUL.
◆ rtems_chain_get_with_wait()
rtems_status_code rtems_chain_get_with_wait ( rtems_chain_control chain,
See also
rtems_chain_get() and rtems_event_receive().
Return values
RTEMS_TIMEOUTTimeout.
◆ rtems_chain_has_only_one_node()
RTEMS_INLINE_ROUTINE bool rtems_chain_has_only_one_node ( const rtems_chain_control the_chain)
This function returns true if there is only one node on the_chain and false otherwise.
Parameters
Return values
trueThe chain has only one node.
falseThe chain has more than one nodes.
References _Chain_Has_only_one_node().
◆ rtems_chain_head()
RTEMS_INLINE_ROUTINE rtems_chain_node* rtems_chain_head ( rtems_chain_control the_chain)
This function returns a pointer to the first node on the chain.
Parameters
Returns
This method returns the permanent node of the chain.
References _Chain_Head().
◆ rtems_chain_immutable_first()
RTEMS_INLINE_ROUTINE const rtems_chain_node* rtems_chain_immutable_first ( const rtems_chain_control the_chain)
Parameters
Returns
References _Chain_Immutable_first().
◆ rtems_chain_immutable_head()
RTEMS_INLINE_ROUTINE const rtems_chain_node* rtems_chain_immutable_head ( const rtems_chain_control the_chain)
This function returns a pointer to the head node on the chain.
Parameters
Returns
This method returns the permanent head node of the chain.
References _Chain_Immutable_head().
◆ rtems_chain_immutable_last()
RTEMS_INLINE_ROUTINE const rtems_chain_node* rtems_chain_immutable_last ( const rtems_chain_control the_chain)
This function returns a pointer to the last node on the chain just before the tail.
Parameters
Returns
This method returns the last node of the chain.
References _Chain_Immutable_last().
◆ rtems_chain_immutable_next()
RTEMS_INLINE_ROUTINE const rtems_chain_node* rtems_chain_immutable_next ( const rtems_chain_node the_node)
This function returns a pointer to the next node after this node.
Parameters
[in]the_nodeis the node to be operated upon.
Returns
This method returns the next node on the chain.
References _Chain_Immutable_next().
◆ rtems_chain_immutable_previous()
RTEMS_INLINE_ROUTINE const rtems_chain_node* rtems_chain_immutable_previous ( const rtems_chain_node the_node)
This function returns a pointer to the previous node on this chain.
Parameters
Returns
This method returns the previous node on the chain.
References _Chain_Immutable_previous().
◆ rtems_chain_immutable_tail()
RTEMS_INLINE_ROUTINE const rtems_chain_node* rtems_chain_immutable_tail ( const rtems_chain_control the_chain)
This function returns a pointer to the tail node on the chain.
Parameters
Returns
This method returns the permanent tail node of the chain.
References _Chain_Immutable_tail().
◆ rtems_chain_initialize()
RTEMS_INLINE_ROUTINE void rtems_chain_initialize ( rtems_chain_control the_chain,
void *  starting_address,
size_t  node_size
This routine initializes the_chain structure to manage the contiguous array of number_nodes nodes which starts at starting_address. Each node is of node_size bytes.
Parameters
[in]the_chainspecifies the chain to initialize
[in]starting_addressis the starting address of the array of elements
[in]number_nodesis the number of nodes that will be in the chain
[in]node_sizeis the size of each node
References _Chain_Initialize().
◆ rtems_chain_initialize_empty()
RTEMS_INLINE_ROUTINE void rtems_chain_initialize_empty ( rtems_chain_control the_chain)
This routine initializes the specified chain to contain zero nodes.
Parameters
[in]the_chainis the chain to be initialized.
References _Chain_Initialize_empty().
Referenced by rtems_rtl_alloc_initialise(), rtems_rtl_obj_alloc(), rtems_rtl_symbol_table_open(), and rtems_rtl_unresolved_table_open().
◆ rtems_chain_insert()
RTEMS_INLINE_ROUTINE void rtems_chain_insert ( rtems_chain_node after_node,
This routine inserts the_node on a chain immediately following after_node.
NOTE: It disables interrupts to ensure the atomicity of the extract operation.
References _Chain_Insert().
Referenced by rtems_chain_get_unprotected().
◆ rtems_chain_is_empty()
RTEMS_INLINE_ROUTINE bool rtems_chain_is_empty ( const rtems_chain_control the_chain)
Is the chain empty.
This function returns true if there a no nodes on the_chain and false otherwise.
Parameters
Return values
trueThe chain is empty.
falseThe chain is not empty.
References _Chain_Is_empty().
◆ rtems_chain_is_first()
RTEMS_INLINE_ROUTINE bool rtems_chain_is_first ( const rtems_chain_node the_node)
This function returns true if the_node is the first node on a chain and false otherwise.
Parameters
[in]the_nodeis the node the caller wants to know if it is the first node on a chain.
Return values
truethe_node is the first node on a chain.
falsethe_node is not the first node on a chain.
References _Chain_Is_first().
◆ rtems_chain_is_head()
RTEMS_INLINE_ROUTINE bool rtems_chain_is_head ( const rtems_chain_control the_chain,
This function returns true if the_node is the head of the_chain and false otherwise.
Parameters
[in]the_nodeis the node to check for being the Chain Head.
Return values
truethe_node is the head of the_chain.
falsethe_node is not the head of the_chain.
References _Chain_Is_head().
◆ rtems_chain_is_last()
RTEMS_INLINE_ROUTINE bool rtems_chain_is_last ( const rtems_chain_node the_node)
This function returns true if the_node is the last node on a chain and false otherwise.
Parameters
[in]the_nodeis the node to check as the last node.
Return values
truethe_node is the last node on a chain.
falsethe_node is not the last node on a chain
References _Chain_Is_last().
◆ rtems_chain_is_node_off_chain()
RTEMS_INLINE_ROUTINE bool rtems_chain_is_node_off_chain ( const rtems_chain_node node)
This function returns true if the node is not on a chain. A node is off chain if the next and previous fields are set to NULL.
Parameters
[in]nodeis the node off chain.
Return values
trueThe node is off chain.
falseThe node is not off chain.
References _Chain_Is_node_off_chain().
Referenced by rtems_rtl_obj_free().
◆ rtems_chain_is_null_node()
RTEMS_INLINE_ROUTINE bool rtems_chain_is_null_node ( const rtems_chain_node the_node)
This function returns true if the_node is NULL and false otherwise.
Parameters
[in]the_nodeis the node pointer to check.
Return values
trueThe chain node pointer is NULL.
falseThe chain node pointer is not NULL.
References _Chain_Is_null_node().
◆ rtems_chain_is_tail()
RTEMS_INLINE_ROUTINE bool rtems_chain_is_tail ( const rtems_chain_control the_chain,
This function returns true if the_node is the tail of the_chain and false otherwise.
Parameters
[in]the_nodeis the node to check for being the Chain Tail.
Return values
truethe_node is the tail of the_chain.
falsethe_node is not the tail of the_chain.
References _Chain_Is_tail(), and rtems_chain_extract().
◆ rtems_chain_last()
RTEMS_INLINE_ROUTINE rtems_chain_node* rtems_chain_last ( rtems_chain_control the_chain)
Parameters
Returns
References _Chain_Last().
◆ rtems_chain_next()
RTEMS_INLINE_ROUTINE rtems_chain_node* rtems_chain_next ( rtems_chain_node the_node)
Parameters
Returns
References _Chain_Next().
Referenced by rtems_rtl_chain_iterate(), and rtems_rtl_obj_erase_sections().
◆ rtems_chain_node_count_unprotected()
RTEMS_INLINE_ROUTINE size_t rtems_chain_node_count_unprotected ( const rtems_chain_control chain)
Parameters
[in]chainThe chain.
Note
It does NOT disable interrupts to ensure the atomicity of the operation.
Returns
The node count of the chain.
References _Chain_Node_count_unprotected().
◆ rtems_chain_prepend()
RTEMS_INLINE_ROUTINE void rtems_chain_prepend ( rtems_chain_control the_chain,
Prepend a node.
This routine prepends the_node onto the front of the_chain.
Parameters
[in]the_nodeis the node to be prepended.
NOTE: It disables interrupts to ensure the atomicity of the prepend operation.
References _Chain_Prepend().
Referenced by rtems_chain_append_unprotected().
◆ rtems_chain_prepend_unprotected()
RTEMS_INLINE_ROUTINE void rtems_chain_prepend_unprotected ( rtems_chain_control the_chain,
Parameters
NOTE: It does NOT disable interrupts to ensure the atomicity of the prepend operation.
References _Chain_Prepend_unprotected(), and rtems_chain_append_with_empty_check().
◆ rtems_chain_prepend_with_empty_check()
RTEMS_INLINE_ROUTINE bool rtems_chain_prepend_with_empty_check ( rtems_chain_control chain,
Return values
trueThe chain was empty before the prepend.
falseThe chain contained at least one node before the prepend.
References _Chain_Prepend_with_empty_check(), and rtems_chain_get_with_empty_check().
Referenced by rtems_chain_append_with_empty_check(), and rtems_chain_prepend_with_notification().
◆ rtems_chain_prepend_with_notification()
rtems_status_code rtems_chain_prepend_with_notification ( rtems_chain_control chain,
rtems_id  task,
See also
rtems_chain_prepend_with_empty_check() and rtems_event_send().
Return values
References rtems_chain_prepend_with_empty_check(), rtems_event_send(), and RTEMS_SUCCESSFUL.
◆ rtems_chain_previous()
RTEMS_INLINE_ROUTINE rtems_chain_node* rtems_chain_previous ( rtems_chain_node the_node)
Parameters
Returns
References _Chain_Previous().
◆ rtems_chain_set_off_chain()
RTEMS_INLINE_ROUTINE void rtems_chain_set_off_chain ( rtems_chain_node node)
Set off chain.
This function sets the next and previous fields of the node to NULL indicating the node is not part of a chain.
Parameters
[in]nodethe node set to off chain.
References _Chain_Set_off_chain().
◆ rtems_chain_tail()
RTEMS_INLINE_ROUTINE rtems_chain_node* rtems_chain_tail ( rtems_chain_control the_chain)
Parameters
Returns
References _Chain_Tail().
