RTEMS Run-Time Linker Object File Symbol Table. More...
struct | rtems_rtl_obj_sym_s |
An object file symbol. More... | |
struct | rtems_rtl_symbols_s |
Table of symbols stored in a hash table. More... | |
Typedefs | |
typedef struct rtems_rtl_obj_sym_s | rtems_rtl_obj_sym_t |
An object file symbol. | |
typedef struct rtems_rtl_symbols_s | rtems_rtl_symbols_t |
Table of symbols stored in a hash table. | |
bool | rtems_rtl_symbol_table_open (rtems_rtl_symbols_t *symbols, size_t buckets) |
Open a symbol table with the specified number of buckets. More... | |
void | rtems_rtl_symbol_table_close (rtems_rtl_symbols_t *symbols) |
Close the table and erase the hash table. More... | |
bool | rtems_rtl_symbol_global_add (rtems_rtl_obj_t *obj, const unsigned char *esyms, unsigned int size) |
Add a table of exported symbols to the symbol table. More... | |
rtems_rtl_obj_sym_t * | rtems_rtl_symbol_global_find (const char *name) |
Find a symbol given the symbol label in the global symbol table. More... | |
rtems_rtl_obj_sym_t * | rtems_rtl_symbol_obj_find (rtems_rtl_obj_t *obj, const char *name) |
Find a symbol given the symbol label in the local object file. More... | |
void | rtems_rtl_symbol_obj_add (rtems_rtl_obj_t *obj) |
Add the object file's symbols to the global table. More... | |
void | rtems_rtl_symbol_obj_erase_local (rtems_rtl_obj_t *obj) |
Erase the object file's local symbols. More... | |
void | rtems_rtl_symbol_obj_erase (rtems_rtl_obj_t *obj) |
Erase the object file's symbols. More... | |
bool rtems_rtl_symbol_global_add | ( | rtems_rtl_obj_t * | obj, |
const unsigned char * | esyms, | ||
unsigned int | size | ||
The export table is a series of symbol records and each record has two fields:
The 'label' is an ASCIIZ string of variable length. The address is of size of an unsigned long for the target running the link editor. The byte order is defined by the machine type because the table should be built by the target compiler.
The table is terminated with a nul string followed by the bytes 0xDE, 0xAD, 0xBE, and 0xEF. This avoids alignments issues.
obj | The object table the symbols are for. |
esyms | The exported symbol table. |
size | The size of the table in bytes. |
rtems_rtl_obj_sym_t* rtems_rtl_symbol_global_find | ( | const char * | name | ) |
name | The name as an ASCIIZ string. |
NULL | No symbol found. |
References rtems_rtl_global_symbols().
void rtems_rtl_symbol_obj_add | ( | rtems_rtl_obj_t * | obj | ) |
obj | The object file the symbols are to be added. |
void rtems_rtl_symbol_obj_erase | ( | rtems_rtl_obj_t * | obj | ) |
obj | The object file the symbols are to be erased from. |
References rtems_rtl_obj_s::global_table, and rtems_rtl_symbol_obj_erase_local().
Referenced by rtems_rtl_obj_free().
void rtems_rtl_symbol_obj_erase_local | ( | rtems_rtl_obj_t * | obj | ) |
obj | The object file the local symbols are to be erased from. |
References rtems_rtl_obj_s::local_size, rtems_rtl_obj_s::local_syms, rtems_rtl_obj_s::local_table, rtems_rtl_alloc_del(), and RTEMS_RTL_ALLOC_SYMBOL.
Referenced by rtems_rtl_symbol_obj_erase().
rtems_rtl_obj_sym_t* rtems_rtl_symbol_obj_find | ( | rtems_rtl_obj_t * | obj, |
const char * | name | ||
obj | The object file to search. |
void rtems_rtl_symbol_table_close | ( | rtems_rtl_symbols_t * | symbols | ) |
symbols | Close the symbol table. |
References rtems_rtl_alloc_del(), and RTEMS_RTL_ALLOC_SYMBOL.
bool rtems_rtl_symbol_table_open | ( | rtems_rtl_symbols_t * | symbols, |
size_t | buckets | ||
symbols | The symbol table to open. |
buckets | The number of buckets in the hash table. |
true | The symbol is open. |
false | The symbol table could not created. The RTL error has the error. |
References rtems_chain_initialize_empty(), rtems_rtl_alloc_new(), RTEMS_RTL_ALLOC_SYMBOL, and rtems_rtl_set_error().
