Macros | Functions
rtems_dhcp_failsafe.h File Reference
#define RTEMS_DHCP_FAILSAFE_NETWORK_FAIL_TIMEOUT   5
#define RTEMS_DHCP_FAILSAFE_NETWORK_DOWN_TIME   30
#define RTEMS_DHCP_FAILSAFE_BROADCAST_DELAY   0
#define RTEMS_DHCP_FAILSAFE_DHCP_MONITOR_PRIORITY   250
void rtems_bsdnet_do_dhcp_failsafe (void)
void rtems_bsdnet_dhcp_failsafe_config (int network_fail_timeout, int network_down_time, int broadcast_delay, int dhcp_monitor_priority)
 Set the DHCP fallback options. More...
◆ rtems_bsdnet_dhcp_failsafe_config()
void rtems_bsdnet_dhcp_failsafe_config ( int  network_fail_timeout,
See the commentary at the top of the implementation.
Note
Some of these options can be compile-time disabled - see the code.
Parameters
network_fail_timeoutThe number of seconds before the interface is considered disconnected
network_down_timeThe number of seconds the interface remains down.
broadcast_delayThe delay in seconds before broadcasts are sent.
dhcp_monitor_priorityThe monitor priority.
