#define | FW_IFNLEN IFNAMSIZ |
#define | IP_FW_MAX_PORTS 10 /* A reasonable maximum */ |
#define | IP_FW_ICMPTYPES_DIM (32 / (sizeof(unsigned) * 8)) |
#define | IP_FW_GETNSRCP(rule) ((rule)->fw_nports & 0x0f) |
#define | IP_FW_SETNSRCP(rule, n) |
#define | IP_FW_GETNDSTP(rule) ((rule)->fw_nports >> 4) |
#define | IP_FW_SETNDSTP(rule, n) |
#define | fw_divert_port fw_un.fu_divert_port |
#define | fw_skipto_rule fw_un.fu_skipto_rule |
#define | fw_reject_code fw_un.fu_reject_code |
#define | IP_FW_F_IN 0x0001 /* Check inbound packets */ |
#define | IP_FW_F_OUT 0x0002 /* Check outbound packets */ |
#define | IP_FW_F_IIFACE 0x0004 /* Apply inbound interface test */ |
#define | IP_FW_F_OIFACE 0x0008 /* Apply outbound interface test */ |
#define | IP_FW_F_COMMAND 0x0070 /* Mask for type of chain entry: */ |
#define | IP_FW_F_DENY 0x0000 /* This is a deny rule */ |
#define | IP_FW_F_REJECT 0x0010 /* Deny and send a response packet */ |
#define | IP_FW_F_ACCEPT 0x0020 /* This is an accept rule */ |
#define | IP_FW_F_COUNT 0x0030 /* This is a count rule */ |
#define | IP_FW_F_DIVERT 0x0040 /* This is a divert rule */ |
#define | IP_FW_F_TEE 0x0050 /* This is a tee rule */ |
#define | IP_FW_F_SKIPTO 0x0060 /* This is a skipto rule */ |
#define | IP_FW_F_PRN 0x0080 /* Print if this rule matches */ |
#define | IP_FW_F_SRNG |
#define | IP_FW_F_DRNG |
#define | IP_FW_F_IIFNAME 0x0400 /* In interface by name/unit (not IP) */ |
#define | IP_FW_F_OIFNAME 0x0800 /* Out interface by name/unit (not IP) */ |
#define | IP_FW_F_INVSRC 0x1000 /* Invert sense of src check */ |
#define | IP_FW_F_INVDST 0x2000 /* Invert sense of dst check */ |
#define | IP_FW_F_FRAG 0x4000 /* Fragment */ |
#define | IP_FW_F_ICMPBIT 0x8000 /* ICMP type bitmap is valid */ |
#define | IP_FW_F_MASK 0xFFFF /* All possible flag bits mask */ |
#define | IF_FW_F_VIAHACK (IP_FW_F_IN|IP_FW_F_OUT|IP_FW_F_IIFACE|IP_FW_F_OIFACE) |
#define | IP_FW_REJECT_RST 0x0100 /* TCP packets: send RST */ |
#define | IP_FW_IPOPT_LSRR 0x01 |
#define | IP_FW_IPOPT_SSRR 0x02 |
#define | IP_FW_IPOPT_RR 0x04 |
#define | IP_FW_IPOPT_TS 0x08 |
#define | IP_FW_TCPF_FIN TH_FIN |
#define | IP_FW_TCPF_SYN TH_SYN |
#define | IP_FW_TCPF_RST TH_RST |
#define | IP_FW_TCPF_PSH TH_PUSH |
#define | IP_FW_TCPF_ACK TH_ACK |
#define | IP_FW_TCPF_URG TH_URG |
#define | IP_FW_TCPF_ESTAB 0x40 |
