admin
rtems-admin.git
doxygen
builder
latest
rtems.git
libnetworking
net
if.h
1
2
* Copyright (c) 1982, 1986, 1989, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)if.h 8.1 (Berkeley) 6/10/93
30
* $FreeBSD: src/sys/net/if.h,v 1.95 2005/02/25 19:46:41 brooks Exp $
31
32
33
34
#ifndef _NET_IF_H_
35
#define _NET_IF_H_
36
37
#include <sys/cdefs.h>
38
39
#if defined(__rtems__)
40
41
* FIXME - HACK: BSD defines __BSD_VISIBLE in sys/cdefs.h
42
* RTEMS sys/cdefs.h doesn't, so we enforce it here.
43
44
#ifndef __BSD_VISIBLE
45
#define __BSD_VISIBLE 1
46
#endif
47
#include <inttypes.h>
48
sys/socket.h
/* struct sockaddr */
49
#endif
50
51
#ifdef _KERNEL
52
#include <sys/queue.h>
53
#endif
54
55
#if __BSD_VISIBLE
56
57
* <net/if.h> does not depend on <sys/time.h> on most other systems. This
58
* helps userland compatibility. (struct timeval ifi_lastchange)
59
60
#ifndef _KERNEL
61
#include <sys/time.h>
62
#endif
63
64
struct
ifnet
65
struct
ether_header
66
#endif
67
68
69
* Length of interface external name, including terminating '\0'.
70
* Note: this is the same size as a generic device's external name.
71
72
#define IF_NAMESIZE 16
73
#if __BSD_VISIBLE
74
#define IFNAMSIZ IF_NAMESIZE
75
#define IF_MAXUNIT 0x7fff
/* historical value */
76
#endif
77
#if __BSD_VISIBLE
78
79
80
* Structure used to query names of interface cloners.
81
82
83
struct
if_clonereq {
84
int
ifcr_total;
/* total cloners (out) */
85
int
ifcr_count;
/* room for this many in user buffer */
86
char
*ifcr_buffer;
/* buffer for cloner names */
87
88
89
90
* Structure describing information about an interface
91
* which may be of interest to management entities.
92
93
struct
if_data {
94
/* generic interface information */
95
u_char ifi_type;
/* ethernet, tokenring, etc */
96
u_char ifi_physical;
/* e.g., AUI, Thinnet, 10base-T, etc */
97
u_char ifi_addrlen;
/* media address length */
98
u_char ifi_hdrlen;
/* media header length */
99
u_char ifi_recvquota;
/* polling quota for receive intrs */
100
u_char ifi_xmitquota;
/* polling quota for xmit intrs */
101
u_long ifi_mtu;
/* maximum transmission unit */
102
u_long ifi_metric;
/* routing metric (external only) */
103
u_long ifi_baudrate;
/* linespeed */
104
/* volatile statistics */
105
u_long ifi_ipackets;
/* packets received on interface */
106
u_long ifi_ierrors;
/* input errors on interface */
107
u_long ifi_opackets;
/* packets sent on interface */
108
u_long ifi_oerrors;
/* output errors on interface */
109
u_long ifi_collisions;
/* collisions on csma interfaces */
110
u_long ifi_ibytes;
/* total number of octets received */
111
u_long ifi_obytes;
/* total number of octets sent */
112
u_long ifi_imcasts;
/* packets received via multicast */
113
u_long ifi_omcasts;
/* packets sent via multicast */
114
u_long ifi_iqdrops;
/* dropped on input, this interface */
115
u_long ifi_noproto;
/* destined for unsupported protocol */
116
u_long ifi_recvtiming;
/* usec spent receiving when timing */
117
u_long ifi_xmittiming;
/* usec spent xmitting when timing */
118
struct
timeval ifi_lastchange;
/* time of last administrative change */
119
120
121
#define IFF_UP 0x1
/* interface is up */
122
#define IFF_BROADCAST 0x2
/* broadcast address valid */
123
#define IFF_DEBUG 0x4
/* turn on debugging */
124
#define IFF_LOOPBACK 0x8
/* is a loopback net */
125
#define IFF_POINTOPOINT 0x10
/* interface is point-to-point link */
126
#define IFF_SMART 0x20
/* interface manages own routes */
127
#define IFF_RUNNING 0x40
/* resources allocated */
128
#define IFF_NOARP 0x80
/* no address resolution protocol */
129
#define IFF_PROMISC 0x100
/* receive all packets */
130
#define IFF_ALLMULTI 0x200
/* receive all multicast packets */
131
#define IFF_OACTIVE 0x400
/* tx hardware queue is full */
132
#define IFF_SIMPLEX 0x800
/* can't hear own transmissions */
133
#define IFF_LINK0 0x1000
/* per link layer defined bit */
134
#define IFF_LINK1 0x2000
135
#define IFF_LINK2 0x4000
136
#define IFF_ALTPHYS IFF_LINK2
/* use alternate physical connection */
137
#define IFF_MULTICAST 0x8000
/* supports multicast */
138
#define IFF_POLLING 0x10000
/* Interface is in polling mode. */
139
#define IFF_PPROMISC 0x20000
/* user-requested promisc mode */
140
#define IFF_MONITOR 0x40000
/* user-requested monitor mode */
141
#define IFF_STATICARP 0x80000
/* static ARP */
142
#define IFF_NEEDSGIANT 0x100000
/* hold Giant over if_start calls */
143
144
/* flags set internally only: */
145
#define IFF_CANTCHANGE \
146
(IFF_BROADCAST|IFF_POINTOPOINT|IFF_RUNNING|IFF_OACTIVE|\
147
IFF_SIMPLEX|IFF_MULTICAST|IFF_ALLMULTI|IFF_SMART|IFF_PROMISC|\
148
IFF_POLLING)
149
150
151
* Values for if_link_state.
152
153
#define LINK_STATE_UNKNOWN 0
/* link invalid/unknown */
154
#define LINK_STATE_DOWN 1
/* link is down */
155
#define LINK_STATE_UP 2
/* link is up */
156
157
158
* Some convenience macros used for setting ifi_baudrate.
159
* XXX 1000 vs. 1024? --thorpej@netbsd.org
160
161
#define IF_Kbps(x) ((x) * 1000)
/* kilobits/sec. */
162
#define IF_Mbps(x) (IF_Kbps((x) * 1000))
/* megabits/sec. */
163
#define IF_Gbps(x) (IF_Mbps((x) * 1000))
/* gigabits/sec. */
164
165
#define IFQ_MAXLEN 50
166
#define IFNET_SLOWHZ 1
/* granularity is 1 second */
167
168
169
* Message format for use in obtaining information about interfaces
170
* from getkerninfo and the routing socket
171
172
struct
if_msghdr {
173
u_short ifm_msglen;
/* to skip over non-understood messages */
174
u_char ifm_version;
/* future binary compatibility */
175
u_char ifm_type;
/* message type */
176
int
ifm_addrs;
/* like rtm_addrs */
177
int
ifm_flags;
/* value of if_flags */
178
u_short ifm_index;
/* index for associated ifp */
179
struct
if_data ifm_data;
/* statistics and other data about if */
180
181
182
183
* Message format for use in obtaining information about interface addresses
184
185
186
struct
ifa_msghdr {
187
u_short ifam_msglen;
188
u_char ifam_version;
189
u_char ifam_type;
/* message type */
190
int
ifam_addrs;
191
int
ifam_flags;
/* value of ifa_flags */
192
u_short ifam_index;
193
int
ifam_metric;
/* value of ifa_metric */
194
195
196
/* forward declaration */
197
struct
mbuf
198
199
200
* Interface request structure used for socket
201
* ioctl's. All interface ioctl's must have parameter
202
* definitions which begin with ifr_name. The
203
* remainder may be interface specific.
204
205
struct
ifreq {
206
char
ifr_name[IFNAMSIZ];
/* if name, e.g. "en0" */
207
union
208
struct
sockaddr
ifru_addr;
209
struct
sockaddr
ifru_dstaddr;
210
struct
sockaddr
ifru_broadaddr;
211
short
ifru_flags[2];
212
int32_t ifru_metric;
213
int32_t ifru_mtu;
214
int
ifru_phys;
215
int
ifru_media;
216
caddr_t ifru_data;
217
int (*ifru_tap)(
struct
ifnet
struct
ether_header
struct
mbuf
218
} ifr_ifru;
219
#define ifr_addr ifr_ifru.ifru_addr
/* address */
220
#define ifr_dstaddr ifr_ifru.ifru_dstaddr
/* other end of p-to-p link */
221
#define ifr_broadaddr ifr_ifru.ifru_broadaddr
/* broadcast address */
222
#define ifr_flags ifr_ifru.ifru_flags[0]
/* flags (low 16 bits) */
223
#define ifr_flagshigh ifr_ifru.ifru_flags[1]
/* flags (high 16 bits) */
224
#define ifr_metric ifr_ifru.ifru_metric
/* metric */
225
#define ifr_mtu ifr_ifru.ifru_mtu
/* mtu */
226
#define ifr_phys ifr_ifru.ifru_phys
/* physical wire */
227
#define ifr_media ifr_ifru.ifru_media
/* physical media */
228
#define ifr_data ifr_ifru.ifru_data
/* for use by interface */
229
#define ifr_tap ifr_ifru.ifru_tap
/* tap function */
230
231
232
struct
ifaliasreq {
233
char
ifra_name[IFNAMSIZ];
234
struct
sockaddr
ifra_addr;
235
struct
sockaddr
ifra_broadaddr;
236
struct
sockaddr
ifra_mask;
237
238
239
struct
ifmediareq {
240
char
ifm_name[IFNAMSIZ];
241
int
ifm_current;
/* current media options */
242
int
ifm_mask;
/* don't care mask */
243
int
ifm_status;
/* media status */
244
int
ifm_active;
/* active options */
245
int
ifm_count;
/* # entries in ifm_ulist array */
246
int
*ifm_ulist;
/* media words */
247
248
249
250
* Structure used to retrieve aux status data from interfaces.
251
* Kernel suppliers to this interface should respect the formatting
252
* needed by ifconfig(8): each line starts with a TAB and ends with
253
* a newline. The canonical example to copy and paste is in if_tun.c.
254
255
256
#define IFSTATMAX 800
/* 10 lines of text */
257
struct
ifstat {
258
char
ifs_name[IFNAMSIZ];
259
char
ascii[IFSTATMAX + 1];
260
261
262
263
* Structure used in SIOCGIFCONF request.
264
* Used to retrieve interface configuration
265
* for machine (useful for programs which
266
* must know all networks accessible).
267
268
struct
ifconf {
269
int
ifc_len;
/* size of associated buffer */
270
union
271
caddr_t ifcu_buf;
272
struct
ifreq *ifcu_req;
273
} ifc_ifcu;
274
#define ifc_buf ifc_ifcu.ifcu_buf
/* buffer address */
275
#define ifc_req ifc_ifcu.ifcu_req
/* array of structures returned */
276
277
#endif
/* __BSD_VISIBLE */
278
279
#ifndef _KERNEL
280
struct
if_nameindex {
281
unsigned
int
if_index;
/* 1, 2, ... */
282
char
*if_name;
/* null terminated name: "le0", ... */
283
284
285
__BEGIN_DECLS
286
void
if_freenameindex(
struct
if_nameindex *);
287
char
*if_indextoname(
unsigned
int
char
288
struct
if_nameindex *if_nameindex(
void
289
__END_DECLS
290
#endif
291
292
#ifdef _KERNEL
293
294
/* XXX - this should go away soon. */
295
net/if_var.h
296
297
void
ifafree(
struct
ifaddr
298
299
int
looutput(
struct
ifnet
300
struct
mbuf
struct
sockaddr
struct
rtentry
301
#endif
302
303
#endif
/* !_NET_IF_H_ */
ether_header
Definition:
ethernet.h:62
sockaddr
Definition:
socket.h:180
ifnet
Definition:
if_var.h:99
ifaddr
Definition:
if_var.h:211
mbuf
Definition:
mbuf.h:103
socket.h
if_var.h
rtentry
Definition:
route.h:104
