Connection entry for each open file stream. More...
Data Fields | |
| off_t | file_size |
| int | ctrl_socket |
| Control connection socket. | |
| uint32_t | client_address |
| int | data_socket |
| Data transfer socket. | |
| size_t | reply_current |
| Current index into the reply buffer. | |
| size_t | reply_end |
| End index of the reply buffer. | |
| char | reply_buffer [128] |
| Buffer for relpy data. | |
| bool | eof |
| End of file flag. | |
| bool | write |
| bool | do_size_command |
| Indicates if we should do a SIZE command. More... | |
| ino_t | ino |
| const char * | user |
| const char * | password |
| const char * | hostname |
| const char * | filename |
| char | buffer [] |
| bool rtems_ftpfs_entry::do_size_command |
The first call to the rtems_ftpfs_fstat() handler is issued by the path evaluation to check for access permission. For this case we avoid the SIZE command.
