The following defines the control block used to manage each semaphore. More...
#include <sem.h>
Data Fields | |
| Objects_Control | Object |
| This field is the object management portion of a Semaphore instance. More... | |
| rtems_attribute | attribute_set |
| This is the Classic API attribute provided to the create directive. More... | |
| union { | |
| CORE_mutex_Control mutex | |
| This is the SuperCore Mutex instance associated with this Classic API Semaphore instance. | |
| CORE_semaphore_Control semaphore | |
| This is the SuperCore Semaphore instance associated with this Classic API Semaphore instance. | |
| } | Core_control |
| This contains the memory associated with the SuperCore Semaphore or Mutex instance that provides the primary functionality of each Classic API Semaphore instance. More... | |
| rtems_attribute Semaphore_Control::attribute_set |
It is translated into behavioral attributes on the SuperCore Semaphore or Mutex instance.
Referenced by rtems_semaphore_create().
| union { ... } Semaphore_Control::Core_control |
The structure used is dependent on the attributes specified by the user on the create directive.
| Objects_Control Semaphore_Control::Object |
Referenced by _Semaphore_Free(), and rtems_semaphore_create().
