The following record contains the prefix for every packet passed between nodes in an MP system. More...
#include <mppkt.h>
Data Fields | |
| MP_packet_Classes | the_class |
| This field indicates the API class of the operation being performed. More... | |
| Objects_Id | id |
| This field is the id of the object to be acted upon. More... | |
| Objects_Id | source_tid |
| This field is the ID of the originating thread. More... | |
| Priority_Control | source_priority |
| This field is the priority of the originating thread. More... | |
| uint32_t | return_code |
| This field is where the status of the operation will be returned. More... | |
| uint32_t | length |
| This field is the length of the data following the prefix. More... | |
| uint32_t | to_convert |
| This field is the length of the data which required network conversion. More... | |
| Watchdog_Interval | timeout |
| This field is the requested timeout for this operation. More... | |
| Objects_Id MP_packet_Prefix::id |
Referenced by _MPCI_Process_response().
| uint32_t MP_packet_Prefix::length |
| uint32_t MP_packet_Prefix::return_code |
| Priority_Control MP_packet_Prefix::source_priority |
| Objects_Id MP_packet_Prefix::source_tid |
Referenced by _MPCI_Send_process_packet(), and _MPCI_Send_response_packet().
| MP_packet_Classes MP_packet_Prefix::the_class |
Referenced by _MPCI_Receive_server().
| Watchdog_Interval MP_packet_Prefix::timeout |
| uint32_t MP_packet_Prefix::to_convert |
