RTEMS Run-Time Link Editor Shell Commands. More...
#include <inttypes.h>#include <stdio.h>#include <string.h>#include <rtems/rtl/rtl.h>#include "rtl-chain-iterator.h"#include "rtl-shell.h"#include "rtl-trace.h"
| struct | rtems_rtl_shell_cmd_t |
| Table of handlers we parse to invoke the command. More... | |
| struct | rtems_rtl_obj_summary_t |
| Object summary data. More... | |
| struct | rtems_rtl_obj_print_t |
| Object print data. More... | |
| #define | PRIdoff_t PRIo64 |
Typedefs | |
| typedef int(* | rtems_rtl_shell_handler_t) (rtems_rtl_data_t *rtl, int argc, char *argv[]) |
| The type of the shell handlers we have. | |
| int | rtems_rtl_shell_command (int argc, char *argv[]) |
| The RTL single shell command contains sub-commands. More... | |
A simple RTL command to aid using the RTL.
| int rtems_rtl_shell_command | ( | int | argc, |
| char * | argv[] | ||
| argc | The argument count. |
| argv | Array of argument strings. |
| 0 | No error. |
