RTEMS Run-Time Linker Allocator. More...
| struct | rtems_rtl_alloc_data_s |
| The allocator data. More... | |
| #define | RTEMS_RTL_ALLOC_TAGS ((size_t) (RTEMS_RTL_ALLOC_READ_EXEC + 1)) |
| The number of tags. | |
Typedefs | |
| typedef enum rtems_rtl_alloc_tags_e | rtems_rtl_alloc_tag_t |
| The allocator tag type. | |
| typedef void(* | rtems_rtl_allocator_t) (bool allocate, rtems_rtl_alloc_tag_t tag, void **address, size_t size) |
| Allocator handler handles all RTL allocations. More... | |
| typedef struct rtems_rtl_alloc_data_s | rtems_rtl_alloc_data_t |
Enumerations | |
| enum | rtems_rtl_alloc_tags_e { RTEMS_RTL_ALLOC_OBJECT, RTEMS_RTL_ALLOC_SYMBOL, RTEMS_RTL_ALLOC_EXTERNAL, RTEMS_RTL_ALLOC_READ, RTEMS_RTL_ALLOC_READ_WRITE, RTEMS_RTL_ALLOC_READ_EXEC } |
| Define the types of allocation the loader requires. More... | |
| void | rtems_rtl_alloc_initialise (rtems_rtl_alloc_data_t *data) |
| Initialise the allocate data. More... | |
| void * | rtems_rtl_alloc_new (rtems_rtl_alloc_tag_t tag, size_t size, bool zero) |
| The Runtime Loader allocator new allocates new memory and optionally clear the memory if requested. More... | |
| void | rtems_rtl_alloc_del (rtems_rtl_alloc_tag_t tag, void *address) |
| The Runtime Loader allocator delete deletes allocated memory. More... | |
| rtems_rtl_allocator_t | rtems_rtl_alloc_hook (rtems_rtl_allocator_t handler) |
| Hook the Runtime Loader allocatior. More... | |
| void | rtems_rtl_alloc_indirect_new (rtems_rtl_alloc_tag_t tag, rtems_rtl_ptr_t *handle, size_t size) |
| Allocate memory to an indirect handle. More... | |
| void | rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag_t tag, rtems_rtl_ptr_t *handle) |
| Free memory from an indirect handle. More... | |
| bool | rtems_rtl_alloc_module_new (void **text_base, size_t text_size, void **const_base, size_t const_size, void **eh_base, size_t eh_size, void **data_base, size_t data_size, void **bss_base, size_t bss_size) |
| Allocate the memory for a module given the size of the text, const, data and bss sections. More... | |
| void | rtems_rtl_alloc_module_del (void **text_base, void **const_base, void **eh_base, void **data_base, void **bss_base) |
| Free the memory allocated to a module. More... | |
| typedef void(* rtems_rtl_allocator_t) (bool allocate, rtems_rtl_alloc_tag_t tag, void **address, size_t size) |
It can be hooked and overridded for customised allocation schemes or memory maps.
| allocation | If true the request is to allocate memory else free. |
| tag | The type of allocation request. |
| address | Pointer to the memory address. If an allocation the value is unspecific on entry and the allocated address or NULL on exit. The NULL value means the allocation failed. If a delete or free request the memory address is the block to free. A free request of NULL is silently ignored. |
| size | The size of the allocation if an allocation request and not used if deleting or freeing a previous allocation. |
| void rtems_rtl_alloc_del | ( | rtems_rtl_alloc_tag_t | tag, |
| void * | address | ||
| address | The memory address to delete. A NULL is ignored. |
Referenced by rtems_rtl_alloc_module_del(), rtems_rtl_obj_comp_close(), rtems_rtl_obj_erase_sections(), rtems_rtl_symbol_obj_erase_local(), and rtems_rtl_symbol_table_close().
| rtems_rtl_allocator_t rtems_rtl_alloc_hook | ( | rtems_rtl_allocator_t | handler | ) |
A handler can call the previous handler in the chain to use it for specific tags. The default handler uses the system heap. Do not unhook your handler if memory it allocates has not been returned.
| handler | The handler to use as the allocator. |
| void rtems_rtl_alloc_indirect_del | ( | rtems_rtl_alloc_tag_t | tag, |
| rtems_rtl_ptr_t * | handle | ||
| handle | The handle to free the memory from. |
| void rtems_rtl_alloc_indirect_new | ( | rtems_rtl_alloc_tag_t | tag, |
| rtems_rtl_ptr_t * | handle, | ||
| size_t | size | ||
| handle | The handle to allocate the memory to. |
| size | The size of the allocation. |
| void rtems_rtl_alloc_initialise | ( | rtems_rtl_alloc_data_t * | data | ) |
| data | The data to initialise. |
References rtems_rtl_alloc_data_s::allocator, rtems_chain_initialize_empty(), rtems_rtl_alloc_heap(), and RTEMS_RTL_ALLOC_TAGS.
| void rtems_rtl_alloc_module_del | ( | void ** | text_base, |
| void ** | const_base, | ||
| void ** | eh_base, | ||
| void ** | data_base, | ||
| void ** | bss_base | ||
| text_base | Pointer to the text base pointer. |
| const_base | Pointer to the const base pointer. |
| eh_base | Pointer to the eh base pointer. |
| data_base | Pointer to the data base pointer. |
| bss_base | Pointer to the bss base pointer. |
References rtems_rtl_alloc_del(), RTEMS_RTL_ALLOC_READ, RTEMS_RTL_ALLOC_READ_EXEC, and RTEMS_RTL_ALLOC_READ_WRITE.
Referenced by rtems_rtl_alloc_module_new(), and rtems_rtl_obj_free().
| bool rtems_rtl_alloc_module_new | ( | void ** | text_base, |
| size_t | text_size, | ||
| size_t | const_size, | ||
| size_t | eh_size, | ||
| size_t | data_size, | ||
| void ** | bss_base, | ||
| size_t | bss_size | ||
If any part of the allocation fails the no memory is allocated.
| text_size | The size of the read/exec section. |
| const_size | The size of the read only section. |
| eh_size | The size of the eh section. |
| data_size | The size of the read/write secton. |
| bss_size | The size of the read/write. |
| true | The memory has been allocated. |
| false | The allocation of memory has failed. |
References rtems_rtl_alloc_module_del(), rtems_rtl_alloc_new(), RTEMS_RTL_ALLOC_READ, RTEMS_RTL_ALLOC_READ_EXEC, and RTEMS_RTL_ALLOC_READ_WRITE.
Referenced by rtems_rtl_obj_load_sections().
| void* rtems_rtl_alloc_new | ( | rtems_rtl_alloc_tag_t | tag, |
| size_t | size, | ||
| bool | zero | ||
| zero | If true the memory is cleared. |
Referenced by rtems_rtl_alloc_module_new(), rtems_rtl_obj_alloc(), and rtems_rtl_symbol_table_open().
