.open_h = rtems_rfs_rtems_device_open,
.close_h = rtems_rfs_rtems_device_close,
.read_h = rtems_rfs_rtems_device_read,
.write_h = rtems_rfs_rtems_device_write,
.ioctl_h = rtems_rfs_rtems_device_ioctl,
.ftruncate_h = rtems_rfs_rtems_device_ftruncate,
int rtems_filesystem_default_fcntl(rtems_libio_t *iop, int cmd)
Definition: default_fcntl.c:21
int rtems_filesystem_default_kqfilter(rtems_libio_t *iop, struct knote *kn)
Default kernel event filter handler.
Definition: default_kqfilter.c:32
int rtems_filesystem_default_poll(rtems_libio_t *iop, int events)
Default poll handler.
Definition: default_poll.c:31
ssize_t rtems_filesystem_default_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the read handler for each IO vector entry.
Definition: default_readv.c:32
ssize_t rtems_filesystem_default_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the write handler for each IO vector entry.
Definition: default_writev.c:32
int rtems_rfs_rtems_fstat(const rtems_filesystem_location_info_t *pathloc, struct stat *buf)
The following routine does a stat on a node.
Definition: rtems-rfs-rtems.c:438
off_t rtems_filesystem_default_lseek_file(rtems_libio_t *iop, off_t offset, int whence)
Default lseek() handler for files.
Definition: default_lseek_file.c:28
int rtems_filesystem_default_fsync_or_fdatasync(rtems_libio_t *iop)
Definition: default_fsync.c:23
