17 #ifndef _RTEMS_RTEMS_RATEMONIMPL_H 18 #define _RTEMS_RTEMS_RATEMONIMPL_H 43 #ifndef RTEMS_RATEMON_EXTERN 44 #define RTEMS_RATEMON_EXTERN extern 106 _Objects_Get( &_Rate_monotonic_Information,
id, location );
183 Thread_CPU_usage_t *cpu_since_last_period
204 #define _Rate_monotonic_Reset_wall_time_statistics( _the_period ) \ 208 &(_the_period)->Statistics.min_wall_time, \ 219 #define _Rate_monotonic_Reset_cpu_use_statistics( _the_period ) \ 223 &(_the_period)->Statistics.min_cpu_time, \ 234 #define _Rate_monotonic_Reset_statistics( _the_period ) \ 237 &(_the_period)->Statistics, \ 239 sizeof( rtems_rate_monotonic_period_statistics ) \ 241 _Rate_monotonic_Reset_cpu_use_statistics( _the_period ); \ 242 _Rate_monotonic_Reset_wall_time_statistics( _the_period ); \ void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectfree.c:25
This value indicates the period is off the watchdog chain, and has never been initialized.
Definition: ratemon.h:86
Objects_Control Object
This field is the object management portion of a Period instance.
Definition: ratemon.h:205
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:80
RTEMS_RATEMON_EXTERN Objects_Information _Rate_monotonic_Information
Rate Monotonic Period Class Management Structure.
Definition: ratemonimpl.h:53
Timestamp_Control Rate_monotonic_Period_time_t
This is the internal type used for the rate monotonic timing statistics.
Definition: ratemon.h:75
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:101
RTEMS_INLINE_ROUTINE void _Rate_monotonic_Free(Rate_monotonic_Control *the_period)
Allocates a period control block from the inactive chain of free period control blocks.
Definition: ratemonimpl.h:84
#define RTEMS_INLINE_ROUTINE
The following (in conjunction with compiler arguments) are used to choose between the use of static i...
Definition: basedefs.h:135
void _Rate_monotonic_Timeout(rtems_id id, void *ignored)
Rate Monotonic Timeout.
Definition: ratemontimeout.c:25
Objects_Control * _Objects_Get(Objects_Information *information, Objects_Id id, Objects_Locations *location)
Maps object ids to object control blocks.
Definition: objectget.c:23
This constant is defined to extern most of the time when using this header file.
Definition: ratemonimpl.h:44
This value indicates the period is on the watchdog chain, and running.
Definition: ratemon.h:99
void _Rate_monotonic_Initiate_statistics(Rate_monotonic_Control *the_period)
Initiate Rate Monotonic Statistics.
Definition: ratemonperiod.c:80
RTEMS_INLINE_ROUTINE bool _Rate_monotonic_Is_active(Rate_monotonic_Control *the_period)
Checks if the_period is in the ACTIVE state.
Definition: ratemonimpl.h:115
This value indicates the period is off the watchdog chain, and has expired.
Definition: ratemon.h:112
RTEMS_INLINE_ROUTINE Rate_monotonic_Control * _Rate_monotonic_Get(Objects_Id id, Objects_Locations *location)
Maps period IDs to period control blocks.
Definition: ratemonimpl.h:100
RTEMS_INLINE_ROUTINE bool _Rate_monotonic_Is_expired(Rate_monotonic_Control *the_period)
Checks if the_period is in the EXPIRED state.
Definition: ratemonimpl.h:141
rtems_rate_monotonic_period_states state
This field indicates the current state of the period.
Definition: ratemon.h:211
The following structure defines the control block used to manage each period.
Definition: ratemon.h:203
void _Rate_monotonic_Manager_initialization(void)
Rate Monotonic Manager Initialization.
Definition: ratemon.c:29
RTEMS_INLINE_ROUTINE bool _Rate_monotonic_Is_inactive(Rate_monotonic_Control *the_period)
Definition: ratemonimpl.h:128
Objects_Locations
This enumerated type lists the locations which may be returned by _Objects_Get.
Definition: objectimpl.h:117
bool _Rate_monotonic_Get_status(Rate_monotonic_Control *the_period, Rate_monotonic_Period_time_t *wall_since_last_period, Thread_CPU_usage_t *cpu_since_last_period)
Definition: ratemonperiod.c:27
Inlined Routines in the Object Handler.
uint32_t Objects_Id
The following type defines the control block used to manage object IDs.
Definition: object.h:122
RTEMS_INLINE_ROUTINE Rate_monotonic_Control * _Rate_monotonic_Allocate(void)
Definition: ratemonimpl.h:71
