NFS Client Implementation for RTEMSHooks Into the RTEMS NFS Filesystem. More...
#include <rtems.h>#include <rtems/libio.h>#include <rtems/libio_.h>#include <rtems/seterr.h>#include <string.h>#include <stdio.h>#include <stdint.h>#include <stdlib.h>#include <assert.h>#include <sys/stat.h>#include <dirent.h>#include <netdb.h>#include <ctype.h>#include <netinet/in.h>#include <arpa/inet.h>#include <nfs_prot.h>#include <mount_prot.h>#include "rpcio.h"#include "librtemsNfs.h"
| struct | strbuf |
| struct | readlinkres_strbuf |
| struct | DirInfoRec_ |
| struct | serporidok |
| struct | serporid |
| struct | NfsRec_ |
| struct | NfsNodeRec_ |
| struct | nfsstats |
| struct | ResolvePathArgRec_ |
| #define | CONFIG_AVG_NAMLEN 10 |
| #define | CONFIG_NFS_SMALL_XACT_SIZE 800 /* size of RPC arguments for non-write ops */ |
| #define | CONFIG_ATTR_LIFETIME 10/*secs*/ |
| #define | DEFAULT_NFS_ST_BLKSIZE NFS_MAXDATA |
| #define | CONFIG_NFS_BIG_XACT_SIZE UDPMSGSIZE /* dont change this */ |
| #define | NFSCALL_TIMEOUT (&_nfscalltimeout) |
| #define | MNTCALL_TIMEOUT (&_nfscalltimeout) |
| #define | DELIM '/' |
| #define | HOSTDELIM ':' |
| #define | UPDIR ".." |
| #define | UIDSEP '@' |
| #define | NFS_VERSION_2 NFS_VERSION |
| #define | NFS_MAJOR (nfsGlob.nfs_major) |
| #define | NFS_MAKE_DEV_T_INO_HACK(node) |
| #define | NFS_MAKE_DEV_T(node) |
| #define | DIRENT_HEADER_SIZE |
| #define | DEBUG_COUNT_NODES (1<<0) |
| #define | DEBUG_TRACK_NODES (1<<1) |
| #define | DEBUG_EVALPATH (1<<2) |
| #define | DEBUG_READDIR (1<<3) |
| #define | DEBUG_SYSCALLS (1<<4) |
| #define | STATIC static |
| #define | MUTEX_ATTRIBUTES |
| #define | LOCK(s) |
| #define | UNLOCK(s) |
| #define | NFS_GLOBAL_ACQUIRE(lock_context) rtems_interrupt_lock_acquire(&nfs_global_lock, lock_context) |
| #define | NFS_GLOBAL_RELEASE(lock_context) rtems_interrupt_lock_release(&nfs_global_lock, lock_context) |
| #define | SERP_ARGS(node) ((node)->serporid.serporid_u.serporid.arg_u) |
| #define | SERP_ATTR(node) ((node)->serporid.serporid_u.serporid.attributes) |
| #define | SERP_FILE(node) ((node)->serporid.serporid_u.serporid.file) |
| #define | READ_LONG_IS_ATOMIC |
| #define | SATTR_MODE (1<<0) |
| #define | SATTR_UID (1<<1) |
| #define | SATTR_GID (1<<2) |
| #define | SATTR_SIZE (1<<3) |
| #define | SATTR_ATIME (1<<4) |
| #define | SATTR_TOUCHA (1<<5) |
| #define | SATTR_MTIME (1<<6) |
| #define | SATTR_TOUCHM (1<<7) |
| #define | SATTR_TOUCH (SATTR_TOUCHM | SATTR_TOUCHA) |
Typedefs | |
| typedef struct strbuf | strbuf |
| typedef struct readlinkres_strbuf | readlinkres_strbuf |
| typedef struct DirInfoRec_ | DirInfoRec |
| typedef struct DirInfoRec_ * | DirInfo |
| typedef struct serporidok | serporidok |
| typedef struct serporid | serporid |
| typedef uint32_t | TimeStamp |
| typedef struct NfsRec_ | NfsRec |
| typedef struct NfsRec_ * | Nfs |
| typedef struct NfsNodeRec_ | NfsNodeRec |
| typedef struct NfsNodeRec_ * | NfsNode |
| typedef struct ResolvePathArgRec_ | ResolvePathArgRec |
| typedef struct ResolvePathArgRec_ * | ResolvePathArg |
| int | nfsMountsShow (FILE *) |
| Dump a list of the currently mounted NFS to a file. More... | |
| rtems_status_code | rtems_filesystem_resolve_location (char *buf, int len, rtems_filesystem_location_info_t *loc) |
| A utility routine to find the path leading to a rtems_filesystem_location_info_t node. More... | |
| int | nfsInit (int smallPoolDepth, int bigPoolDepth) |
| NFS driver interface. More... | |
| int | nfsCleanup (void) |
| Driver cleanup code. More... | |
| STATIC int | nfscall (RpcUdpServer srvr, int proc, xdrproc_t xargs, void *pargs, xdrproc_t xres, void *pres) |
| int | rtems_nfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| Filesystem mount table mount handler. More... | |
| STATIC void | nfs_fsunmount_me (rtems_filesystem_mount_table_entry_t *mt_entry) |
| int | nfsSetTimeout (uint32_t timeout_ms) |
| Set the timeout (initial default: 10s) for NFS and mount calls. More... | |
| uint32_t | nfsGetTimeout (void) |
| Read current timeout (in milliseconds) | |
| const struct _rtems_filesystem_operations_table | nfs_fs_ops |
| int | nfsStBlksize = DEFAULT_NFS_ST_BLKSIZE |
| #define DIRENT_HEADER_SIZE |
| #define LOCK | ( | s | ) |
| #define MUTEX_ATTRIBUTES |
| #define NFS_MAKE_DEV_T | ( | node | ) |
| #define NFS_MAKE_DEV_T_INO_HACK | ( | node | ) |
| #define UNLOCK | ( | s | ) |
| const struct _rtems_filesystem_operations_table nfs_fs_ops |
