void | sysctl_register_oid (struct sysctl_oid *oidp) |
void | sysctl_unregister_oid (struct sysctl_oid *oidp) |
int | sysctl_ctx_init (struct sysctl_ctx_list *c) |
int | sysctl_ctx_free (struct sysctl_ctx_list *clist) |
struct sysctl_ctx_entry * | sysctl_ctx_entry_add (struct sysctl_ctx_list *clist, struct sysctl_oid *oidp) |
struct sysctl_ctx_entry * | sysctl_ctx_entry_find (struct sysctl_ctx_list *clist, struct sysctl_oid *oidp) |
int | sysctl_ctx_entry_del (struct sysctl_ctx_list *clist, struct sysctl_oid *oidp) |
int | sysctl_remove_oid (struct sysctl_oid *oidp, int del, int recurse) |
struct sysctl_oid * | sysctl_add_oid (struct sysctl_ctx_list *clist, struct sysctl_oid_list *parent, int number, const char *name, int kind, void *arg1, int arg2, int(*handler)(SYSCTL_HANDLER_ARGS), const char *fmt, const char *descr) |
| SET_DECLARE (sysctl_set, struct sysctl_oid) |
| SYSINIT (sysctl, SI_SUB_KMEM, SI_ORDER_ANY, sysctl_register_all, 0) |
| SYSCTL_PROC (_sysctl, 0, debug, CTLTYPE_STRING|CTLFLAG_RD, 0, 0, sysctl_sysctl_debug, "-", "") |
| SYSCTL_NODE (_sysctl, 1, name, CTLFLAG_RD, sysctl_sysctl_name, "") |
| SYSCTL_NODE (_sysctl, 2, next, CTLFLAG_RD, sysctl_sysctl_next, "") |
| SYSCTL_PROC (_sysctl, 3, name2oid, CTLFLAG_RW|CTLFLAG_ANYBODY, 0, 0, sysctl_sysctl_name2oid, "I", "") |
| SYSCTL_NODE (_sysctl, 4, oidfmt, CTLFLAG_RD, sysctl_sysctl_oidfmt, "") |
| SYSCTL_NODE (_sysctl, 5, oiddescr, CTLFLAG_RD, sysctl_sysctl_oiddescr, "") |
int | sysctl_handle_int (SYSCTL_HANDLER_ARGS) |
int | sysctl_handle_long (SYSCTL_HANDLER_ARGS) |
int | sysctl_handle_string (SYSCTL_HANDLER_ARGS) |
int | sysctl_handle_opaque (SYSCTL_HANDLER_ARGS) |
int | kernel_sysctl (struct thread *td, int *name, u_int namelen, void *old, size_t *oldlenp, void *new, size_t newlen, size_t *retval) |
int | kernel_sysctlbyname (struct thread *td, char *name, void *old, size_t *oldlenp, void *new, size_t newlen, size_t *retval) |
int | sysctl_wire_old_buffer (struct sysctl_req *req, size_t len) |
int | sysctl_find_oid (int *name, u_int namelen, struct sysctl_oid **noid, int *nindx, struct sysctl_req *req) |
int | __sysctl (struct thread *td, struct sysctl_args *uap) |
int | userland_sysctl (struct thread *td, int *name, u_int namelen, void *old, size_t *oldlenp, int inkernel, void *new, size_t newlen, size_t *retval) |
