rtems-4.11.3
libnetworking
vm
vm_extern.h
1
2
* Copyright (c) 1992, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)vm_extern.h 8.2 (Berkeley) 1/12/94
30
* $FreeBSD: src/sys/vm/vm_extern.h,v 1.78 2006/05/29 21:28:56 tegge Exp $
31
32
33
#ifndef _VM_EXTERN_H_
34
#define _VM_EXTERN_H_
35
36
struct
buf;
37
struct
proc
38
struct
vmtotal;
39
struct
mount
40
struct
vnode;
41
42
#endif
/* !_VM_EXTERN_H_ */
mount
int mount(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system instance at the specified target path.
Definition:
mount.c:178
proc
Definition:
proc.h:5
