34 #ifndef _AVR_IOM128RFA1_H_ 35 #define _AVR_IOM128RFA1_H_ 1 40 # error "Include <avr/io.h> instead of this file." 44 # define _AVR_IOXXX_H_ "iom128rfa1.h" 46 # error "Attempt to include more than one <avr/ioXXX.h> file." 52 # define _MMIO_BYTE_STRUCT(mem_addr,type) (*(volatile type *)(mem_addr)) 53 # define _SFR_IO8_STRUCT(io_addr,type) _MMIO_BYTE_STRUCT((io_addr) + 0x20, type) 54 # define _SFR_MEM8_STRUCT(io_addr,type) _MMIO_BYTE_STRUCT((io_addr), type) 69 #define PINA _SFR_IO8(0x00) 83 #define DDRA _SFR_IO8(0x01) 97 #define PORTA _SFR_IO8(0x02) 119 #define PINB _SFR_IO8(0x03) 133 #define DDRB _SFR_IO8(0x04) 147 #define PORTB _SFR_IO8(0x05) 169 #define PINC _SFR_IO8(0x06) 183 #define DDRC _SFR_IO8(0x07) 197 #define PORTC _SFR_IO8(0x08) 219 #define PIND _SFR_IO8(0x09) 233 #define DDRD _SFR_IO8(0x0A) 247 #define PORTD _SFR_IO8(0x0B) 269 #define PINE _SFR_IO8(0x0C) 283 #define DDRE _SFR_IO8(0x0D) 297 #define PORTE _SFR_IO8(0x0E) 319 #define PINF _SFR_IO8(0x0F) 333 #define DDRF _SFR_IO8(0x10) 347 #define PORTF _SFR_IO8(0x11) 369 #define PING _SFR_IO8(0x12) 381 #define DDRG _SFR_IO8(0x13) 393 #define PORTG _SFR_IO8(0x14) 411 #define TIFR0 _SFR_IO8(0x15) 413 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 416 unsigned int tov0 : 1;
417 unsigned int ocf0a : 1;
418 unsigned int ocf0b : 1;
422 #define TIFR0_struct _SFR_IO8_STRUCT(0x15, struct __reg_TIFR0) 433 #define TIFR1 _SFR_IO8(0x16) 435 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 438 unsigned int tov1 : 1;
439 unsigned int ocf1a : 1;
440 unsigned int ocf1b : 1;
441 unsigned int ocf1c : 1;
443 unsigned int icf1 : 1;
447 #define TIFR1_struct _SFR_IO8_STRUCT(0x16, struct __reg_TIFR1) 460 #define TIFR2 _SFR_IO8(0x17) 462 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 465 unsigned int tov2 : 1;
466 unsigned int ocf2a : 1;
467 unsigned int ocf2b : 1;
471 #define TIFR2_struct _SFR_IO8_STRUCT(0x17, struct __reg_TIFR2) 482 #define TIFR3 _SFR_IO8(0x18) 484 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 487 unsigned int tov3 : 1;
488 unsigned int ocf3a : 1;
489 unsigned int ocf3b : 1;
490 unsigned int ocf3c : 1;
492 unsigned int icf3 : 1;
496 #define TIFR3_struct _SFR_IO8_STRUCT(0x18, struct __reg_TIFR3) 509 #define TIFR4 _SFR_IO8(0x19) 511 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 514 unsigned int tov4 : 1;
515 unsigned int ocf4a : 1;
516 unsigned int ocf4b : 1;
517 unsigned int ocf4c : 1;
519 unsigned int icf4 : 1;
523 #define TIFR4_struct _SFR_IO8_STRUCT(0x19, struct __reg_TIFR4) 536 #define TIFR5 _SFR_IO8(0x1A) 538 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 541 unsigned int tov5 : 1;
542 unsigned int ocf5a : 1;
543 unsigned int ocf5b : 1;
544 unsigned int ocf5c : 1;
546 unsigned int icf5 : 1;
550 #define TIFR5_struct _SFR_IO8_STRUCT(0x1a, struct __reg_TIFR5) 563 #define PCIFR _SFR_IO8(0x1B) 565 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 568 unsigned int pcif : 3;
572 #define PCIFR_struct _SFR_IO8_STRUCT(0x1b, struct __reg_PCIFR) 583 #define EIFR _SFR_IO8(0x1C) 585 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 588 unsigned int intf : 8;
591 #define EIFR_struct _SFR_IO8_STRUCT(0x1c, struct __reg_EIFR) 607 #define EIMSK _SFR_IO8(0x1D) 609 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 612 unsigned int intm : 8;
615 #define EIMSK_struct _SFR_IO8_STRUCT(0x1d, struct __reg_EIMSK) 631 #define GPIOR0 _SFR_IO8(0x1E) 633 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 636 unsigned int gpior0 : 8;
639 #define GPIOR0_struct _SFR_IO8_STRUCT(0x1e, struct __reg_GPIOR0) 661 #define __EEPROM_REG_LOCATIONS__ 1F2021 664 #define EECR _SFR_IO8(0x1F) 666 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 669 unsigned int eere : 1;
670 unsigned int eepe : 1;
671 unsigned int eempe : 1;
672 unsigned int eerie : 1;
673 unsigned int eepm : 2;
677 #define EECR_struct _SFR_IO8_STRUCT(0x1f, struct __reg_EECR) 691 #define EEDR _SFR_IO8(0x20) 705 #define EEAR _SFR_IO16(0x21) 706 #define EEARL _SFR_IO8(0x21) 707 #define EEARH _SFR_IO8(0x22) 710 #define GTCCR _SFR_IO8(0x23) 712 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 715 unsigned int psrsync : 1;
716 unsigned int psrasy : 1;
718 unsigned int tsm : 1;
721 #define GTCCR_struct _SFR_IO8_STRUCT(0x23, struct __reg_GTCCR) 734 #define TCCR0A _SFR_IO8(0x24) 736 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 739 unsigned int wgm0 : 2;
741 unsigned int com0b : 2;
742 unsigned int com0a : 2;
745 #define TCCR0A_struct _SFR_IO8_STRUCT(0x24, struct __reg_TCCR0A) 759 #define TCCR0B _SFR_IO8(0x25) 761 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 764 unsigned int cs0 : 3;
765 unsigned int wgm02 : 1;
767 unsigned int foc0b : 1;
768 unsigned int foc0a : 1;
771 #define TCCR0B_struct _SFR_IO8_STRUCT(0x25, struct __reg_TCCR0B) 785 #define TCNT0 _SFR_IO8(0x26) 799 #define OCR0A _SFR_IO8(0x27) 813 #define OCR0B _SFR_IO8(0x28) 827 #define GPIOR1 _SFR_IO8(0x2A) 829 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 832 unsigned int gpior1 : 8;
835 #define GPIOR1_struct _SFR_IO8_STRUCT(0x2a, struct __reg_GPIOR1) 851 #define GPIOR2 _SFR_IO8(0x2B) 853 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 856 unsigned int gpior2 : 8;
859 #define GPIOR2_struct _SFR_IO8_STRUCT(0x2b, struct __reg_GPIOR2) 875 #define SPCR _SFR_IO8(0x2C) 877 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 880 unsigned int spr : 2;
881 unsigned int cpha : 1;
882 unsigned int cpol : 1;
883 unsigned int mstr : 1;
884 unsigned int dord : 1;
885 unsigned int spe : 1;
886 unsigned int spie : 1;
889 #define SPCR_struct _SFR_IO8_STRUCT(0x2c, struct __reg_SPCR) 905 #define SPSR _SFR_IO8(0x2D) 907 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 910 unsigned int spi2x : 1;
912 unsigned int wcol : 1;
913 unsigned int spif : 1;
916 #define SPSR_struct _SFR_IO8_STRUCT(0x2d, struct __reg_SPSR) 927 #define SPDR _SFR_IO8(0x2E) 941 #define ACSR _SFR_IO8(0x30) 943 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 946 unsigned int acis : 2;
947 unsigned int acic : 1;
948 unsigned int acie : 1;
949 unsigned int aci : 1;
950 unsigned int aco : 1;
951 unsigned int acbg : 1;
952 unsigned int acd : 1;
955 #define ACSR_struct _SFR_IO8_STRUCT(0x30, struct __reg_ACSR) 971 #define OCDR _SFR_IO8(0x31) 973 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 976 unsigned int ocdr : 8;
979 #define OCDR_struct _SFR_IO8_STRUCT(0x31, struct __reg_OCDR) 996 #define SMCR _SFR_IO8(0x33) 998 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1001 unsigned int se : 1;
1002 unsigned int sm : 3;
1006 #define SMCR_struct _SFR_IO8_STRUCT(0x33, struct __reg_SMCR) 1018 #define MCUSR _SFR_IO8(0x34) 1020 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1023 unsigned int porf : 1;
1024 unsigned int extrf : 1;
1025 unsigned int borf : 1;
1026 unsigned int wdrf : 1;
1027 unsigned int jtrf : 1;
1031 #define MCUSR_struct _SFR_IO8_STRUCT(0x34, struct __reg_MCUSR) 1044 #define MCUCR _SFR_IO8(0x35) 1046 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1049 unsigned int ivce : 1;
1050 unsigned int ivsel : 1;
1052 unsigned int pud : 1;
1054 unsigned int jtd : 1;
1057 #define MCUCR_struct _SFR_IO8_STRUCT(0x35, struct __reg_MCUCR) 1069 #define SPMCSR _SFR_IO8(0x37) 1071 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1074 unsigned int spmen : 1;
1075 unsigned int pgers : 1;
1076 unsigned int pgwrt : 1;
1077 unsigned int blbset : 1;
1078 unsigned int rwwsre : 1;
1079 unsigned int sigrd : 1;
1080 unsigned int rwwsb : 1;
1081 unsigned int spmie : 1;
1084 #define SPMCSR_struct _SFR_IO8_STRUCT(0x37, struct __reg_SPMCSR) 1100 #define RAMPZ _SFR_IO8(0x3B) 1102 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1105 unsigned int rampz : 2;
1109 #define RAMPZ_struct _SFR_IO8_STRUCT(0x3b, struct __reg_RAMPZ) 1119 #define SP _SFR_IO16(0x3D) 1120 #define SPL _SFR_IO8(0x3D) 1121 #define SPH _SFR_IO8(0x3E) 1124 #define SREG _SFR_IO8(0x3F) 1126 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1139 #define SREG_struct _SFR_IO8_STRUCT(0x3f, struct __reg_SREG) 1155 #define WDTCSR _SFR_MEM8(0x60) 1157 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1160 unsigned int wdp : 3;
1161 unsigned int wde : 1;
1162 unsigned int wdce : 1;
1164 unsigned int wdie : 1;
1165 unsigned int wdif : 1;
1168 #define WDTCSR_struct _SFR_MEM8_STRUCT(0x60, struct __reg_WDTCSR) 1184 #define CLKPR _SFR_MEM8(0x61) 1186 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1189 unsigned int clkps : 4;
1191 unsigned int clkpce : 1;
1194 #define CLKPR_struct _SFR_MEM8_STRUCT(0x61, struct __reg_CLKPR) 1207 #define PRR2 _SFR_MEM8(0x63) 1209 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1212 unsigned int prram : 4;
1216 #define PRR2_struct _SFR_MEM8_STRUCT(0x63, struct __reg_PRR2) 1228 #define PRR0 _SFR_MEM8(0x64) 1230 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1233 unsigned int pradc : 1;
1234 unsigned int prusart0 : 1;
1235 unsigned int prspi : 1;
1236 unsigned int prtim1 : 1;
1237 unsigned int prpga : 1;
1238 unsigned int prtim0 : 1;
1239 unsigned int prtim2 : 1;
1240 unsigned int prtwi : 1;
1243 #define PRR0_struct _SFR_MEM8_STRUCT(0x64, struct __reg_PRR0) 1259 #define PRR1 _SFR_MEM8(0x65) 1261 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1264 unsigned int prusart : 3;
1265 unsigned int prtim3 : 1;
1266 unsigned int prtim4 : 1;
1267 unsigned int prtim5 : 1;
1268 unsigned int prtrx24 : 1;
1272 #define PRR1_struct _SFR_MEM8_STRUCT(0x65, struct __reg_PRR1) 1287 #define OSCCAL _SFR_MEM8(0x66) 1289 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1292 unsigned int cal : 8;
1295 #define OSCCAL_struct _SFR_MEM8_STRUCT(0x66, struct __reg_OSCCAL) 1311 #define BGCR _SFR_MEM8(0x67) 1313 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1316 unsigned int bgcal : 3;
1317 unsigned int bgcal_fine : 4;
1321 #define BGCR_struct _SFR_MEM8_STRUCT(0x67, struct __reg_BGCR) 1330 #define BGCAL_FINE0 3 1331 #define BGCAL_FINE1 4 1332 #define BGCAL_FINE2 5 1333 #define BGCAL_FINE3 6 1336 #define PCICR _SFR_MEM8(0x68) 1338 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1341 unsigned int pcie : 3;
1345 #define PCICR_struct _SFR_MEM8_STRUCT(0x68, struct __reg_PCICR) 1356 #define EICRA _SFR_MEM8(0x69) 1358 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1361 unsigned int isc0 : 2;
1362 unsigned int isc1 : 2;
1363 unsigned int isc2 : 2;
1364 unsigned int isc3 : 2;
1367 #define EICRA_struct _SFR_MEM8_STRUCT(0x69, struct __reg_EICRA) 1383 #define EICRB _SFR_MEM8(0x6A) 1385 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1388 unsigned int isc4 : 2;
1389 unsigned int isc5 : 2;
1390 unsigned int isc6 : 2;
1391 unsigned int isc7 : 2;
1394 #define EICRB_struct _SFR_MEM8_STRUCT(0x6a, struct __reg_EICRB) 1410 #define PCMSK0 _SFR_MEM8(0x6B) 1424 #define PCMSK1 _SFR_MEM8(0x6C) 1426 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1429 unsigned int pcint : 2;
1430 unsigned int pcint1 : 6;
1433 #define PCMSK1_struct _SFR_MEM8_STRUCT(0x6c, struct __reg_PCMSK1) 1449 #define PCMSK2 _SFR_MEM8(0x6D) 1451 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1454 unsigned int pcint1 : 4;
1455 unsigned int pcint2 : 4;
1458 #define PCMSK2_struct _SFR_MEM8_STRUCT(0x6d, struct __reg_PCMSK2) 1474 #define TIMSK0 _SFR_MEM8(0x6E) 1476 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1479 unsigned int toie0 : 1;
1480 unsigned int ocie0a : 1;
1481 unsigned int ocie0b : 1;
1485 #define TIMSK0_struct _SFR_MEM8_STRUCT(0x6e, struct __reg_TIMSK0) 1496 #define TIMSK1 _SFR_MEM8(0x6F) 1498 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1501 unsigned int toie1 : 1;
1502 unsigned int ocie1a : 1;
1503 unsigned int ocie1b : 1;
1504 unsigned int ocie1c : 1;
1506 unsigned int icie1 : 1;
1510 #define TIMSK1_struct _SFR_MEM8_STRUCT(0x6f, struct __reg_TIMSK1) 1523 #define TIMSK2 _SFR_MEM8(0x70) 1525 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1528 unsigned int toie2 : 1;
1529 unsigned int ocie2a : 1;
1530 unsigned int ocie2b : 1;
1534 #define TIMSK2_struct _SFR_MEM8_STRUCT(0x70, struct __reg_TIMSK2) 1546 #define TIMSK3 _SFR_MEM8(0x71) 1548 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1551 unsigned int toie3 : 1;
1552 unsigned int ocie3a : 1;
1553 unsigned int ocie3b : 1;
1554 unsigned int ocie3c : 1;
1556 unsigned int icie3 : 1;
1560 #define TIMSK3_struct _SFR_MEM8_STRUCT(0x71, struct __reg_TIMSK3) 1573 #define TIMSK4 _SFR_MEM8(0x72) 1575 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1578 unsigned int toie4 : 1;
1579 unsigned int ocie4a : 1;
1580 unsigned int ocie4b : 1;
1581 unsigned int ocie4c : 1;
1583 unsigned int icie4 : 1;
1587 #define TIMSK4_struct _SFR_MEM8_STRUCT(0x72, struct __reg_TIMSK4) 1600 #define TIMSK5 _SFR_MEM8(0x73) 1602 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1605 unsigned int toie5 : 1;
1606 unsigned int ocie5a : 1;
1607 unsigned int ocie5b : 1;
1608 unsigned int ocie5c : 1;
1610 unsigned int icie5 : 1;
1614 #define TIMSK5_struct _SFR_MEM8_STRUCT(0x73, struct __reg_TIMSK5) 1627 #define NEMCR _SFR_MEM8(0x75) 1629 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1633 unsigned int aeam : 2;
1634 unsigned int eneam : 1;
1638 #define NEMCR_struct _SFR_MEM8_STRUCT(0x75, struct __reg_NEMCR) 1649 #define ADCSRC _SFR_MEM8(0x77) 1651 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1654 unsigned int adsut : 5;
1655 unsigned int res0 : 1;
1656 unsigned int adtht : 2;
1659 #define ADCSRC_struct _SFR_MEM8_STRUCT(0x77, struct __reg_ADCSRC) 1674 #ifndef __ASSEMBLER__ 1675 #define ADC _SFR_MEM16(0x78) 1676 #define ADCL _SFR_MEM8(0x78) 1677 #define ADCH _SFR_MEM8(0x79) 1679 #define ADCW _SFR_MEM16(0x78) 1680 #define ADCWL _SFR_MEM8(0x78) 1681 #define ADCWH _SFR_MEM8(0x79) 1684 #define ADCSRA _SFR_MEM8(0x7A) 1686 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1689 unsigned int adps : 3;
1690 unsigned int adie : 1;
1691 unsigned int adif : 1;
1692 unsigned int adate : 1;
1693 unsigned int adsc : 1;
1694 unsigned int aden : 1;
1697 #define ADCSRA_struct _SFR_MEM8_STRUCT(0x7a, struct __reg_ADCSRA) 1713 #define ADCSRB _SFR_MEM8(0x7B) 1715 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1718 unsigned int adts : 3;
1719 unsigned int mux5 : 1;
1720 unsigned int acch : 1;
1721 unsigned int refok : 1;
1722 unsigned int acme : 1;
1723 unsigned int avddok : 1;
1726 #define ADCSRB_struct _SFR_MEM8_STRUCT(0x7b, struct __reg_ADCSRB) 1742 #define ADMUX _SFR_MEM8(0x7C) 1744 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1747 unsigned int mux : 5;
1748 unsigned int adlar : 1;
1749 unsigned int refs : 2;
1752 #define ADMUX_struct _SFR_MEM8_STRUCT(0x7c, struct __reg_ADMUX) 1768 #define DIDR2 _SFR_MEM8(0x7D) 1770 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1773 unsigned int adc8d : 1;
1774 unsigned int adc9d : 1;
1775 unsigned int adc10d : 1;
1776 unsigned int adc11d : 1;
1777 unsigned int adc12d : 1;
1778 unsigned int adc13d : 1;
1779 unsigned int adc14d : 1;
1780 unsigned int adc15d : 1;
1783 #define DIDR2_struct _SFR_MEM8_STRUCT(0x7d, struct __reg_DIDR2) 1799 #define DIDR0 _SFR_MEM8(0x7E) 1801 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1804 unsigned int adc0d : 1;
1805 unsigned int adc1d : 1;
1806 unsigned int adc2d : 1;
1807 unsigned int adc3d : 1;
1808 unsigned int adc4d : 1;
1809 unsigned int adc5d : 1;
1810 unsigned int adc6d : 1;
1811 unsigned int adc7d : 1;
1814 #define DIDR0_struct _SFR_MEM8_STRUCT(0x7e, struct __reg_DIDR0) 1830 #define DIDR1 _SFR_MEM8(0x7F) 1832 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1835 unsigned int ain0d : 1;
1836 unsigned int ain1d : 1;
1840 #define DIDR1_struct _SFR_MEM8_STRUCT(0x7f, struct __reg_DIDR1) 1850 #define TCCR1A _SFR_MEM8(0x80) 1852 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1855 unsigned int wgm1 : 2;
1856 unsigned int com1c : 2;
1857 unsigned int com1b : 2;
1858 unsigned int com1a : 2;
1861 #define TCCR1A_struct _SFR_MEM8_STRUCT(0x80, struct __reg_TCCR1A) 1877 #define TCCR1B _SFR_MEM8(0x81) 1879 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1882 unsigned int cs1 : 3;
1883 unsigned int wgm1 : 2;
1885 unsigned int ices1 : 1;
1886 unsigned int icnc1 : 1;
1889 #define TCCR1B_struct _SFR_MEM8_STRUCT(0x81, struct __reg_TCCR1B) 1904 #define TCCR1C _SFR_MEM8(0x82) 1906 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1910 unsigned int foc1c : 1;
1911 unsigned int foc1b : 1;
1912 unsigned int foc1a : 1;
1915 #define TCCR1C_struct _SFR_MEM8_STRUCT(0x82, struct __reg_TCCR1C) 1926 #define TCNT1 _SFR_MEM16(0x84) 1927 #define TCNT1L _SFR_MEM8(0x84) 1928 #define TCNT1H _SFR_MEM8(0x85) 1931 #define ICR1 _SFR_MEM16(0x86) 1932 #define ICR1L _SFR_MEM8(0x86) 1933 #define ICR1H _SFR_MEM8(0x87) 1936 #define OCR1A _SFR_MEM16(0x88) 1937 #define OCR1AL _SFR_MEM8(0x88) 1938 #define OCR1AH _SFR_MEM8(0x89) 1941 #define OCR1B _SFR_MEM16(0x8A) 1942 #define OCR1BL _SFR_MEM8(0x8A) 1943 #define OCR1BH _SFR_MEM8(0x8B) 1946 #define OCR1C _SFR_MEM16(0x8C) 1947 #define OCR1CL _SFR_MEM8(0x8C) 1948 #define OCR1CH _SFR_MEM8(0x8D) 1951 #define TCCR3A _SFR_MEM8(0x90) 1953 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1956 unsigned int wgm3 : 2;
1957 unsigned int com3c : 2;
1958 unsigned int com3b : 2;
1959 unsigned int com3a : 2;
1962 #define TCCR3A_struct _SFR_MEM8_STRUCT(0x90, struct __reg_TCCR3A) 1978 #define TCCR3B _SFR_MEM8(0x91) 1980 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 1983 unsigned int cs3 : 3;
1984 unsigned int wgm3 : 2;
1986 unsigned int ices3 : 1;
1987 unsigned int icnc3 : 1;
1990 #define TCCR3B_struct _SFR_MEM8_STRUCT(0x91, struct __reg_TCCR3B) 2005 #define TCCR3C _SFR_MEM8(0x92) 2007 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2011 unsigned int foc3c : 1;
2012 unsigned int foc3b : 1;
2013 unsigned int foc3a : 1;
2016 #define TCCR3C_struct _SFR_MEM8_STRUCT(0x92, struct __reg_TCCR3C) 2027 #define TCNT3 _SFR_MEM16(0x94) 2028 #define TCNT3L _SFR_MEM8(0x94) 2029 #define TCNT3H _SFR_MEM8(0x95) 2032 #define ICR3 _SFR_MEM16(0x96) 2033 #define ICR3L _SFR_MEM8(0x96) 2034 #define ICR3H _SFR_MEM8(0x97) 2037 #define OCR3A _SFR_MEM16(0x98) 2038 #define OCR3AL _SFR_MEM8(0x98) 2039 #define OCR3AH _SFR_MEM8(0x99) 2042 #define OCR3B _SFR_MEM16(0x9A) 2043 #define OCR3BL _SFR_MEM8(0x9A) 2044 #define OCR3BH _SFR_MEM8(0x9B) 2047 #define OCR3C _SFR_MEM16(0x9C) 2048 #define OCR3CL _SFR_MEM8(0x9C) 2049 #define OCR3CH _SFR_MEM8(0x9D) 2052 #define TCCR4A _SFR_MEM8(0xA0) 2054 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2057 unsigned int wgm4 : 2;
2058 unsigned int com4c : 2;
2059 unsigned int com4b : 2;
2060 unsigned int com4a : 2;
2063 #define TCCR4A_struct _SFR_MEM8_STRUCT(0xa0, struct __reg_TCCR4A) 2079 #define TCCR4B _SFR_MEM8(0xA1) 2081 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2084 unsigned int cs4 : 3;
2085 unsigned int wgm4 : 2;
2087 unsigned int ices4 : 1;
2088 unsigned int icnc4 : 1;
2091 #define TCCR4B_struct _SFR_MEM8_STRUCT(0xa1, struct __reg_TCCR4B) 2106 #define TCCR4C _SFR_MEM8(0xA2) 2108 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2112 unsigned int foc4c : 1;
2113 unsigned int foc4b : 1;
2114 unsigned int foc4a : 1;
2117 #define TCCR4C_struct _SFR_MEM8_STRUCT(0xa2, struct __reg_TCCR4C) 2128 #define TCNT4 _SFR_MEM16(0xA4) 2129 #define TCNT4L _SFR_MEM8(0xA4) 2130 #define TCNT4H _SFR_MEM8(0xA5) 2133 #define ICR4 _SFR_MEM16(0xA6) 2134 #define ICR4L _SFR_MEM8(0xA6) 2135 #define ICR4H _SFR_MEM8(0xA7) 2138 #define OCR4A _SFR_MEM16(0xA8) 2139 #define OCR4AL _SFR_MEM8(0xA8) 2140 #define OCR4AH _SFR_MEM8(0xA9) 2143 #define OCR4B _SFR_MEM16(0xAA) 2144 #define OCR4BL _SFR_MEM8(0xAA) 2145 #define OCR4BH _SFR_MEM8(0xAB) 2148 #define OCR4C _SFR_MEM16(0xAC) 2149 #define OCR4CL _SFR_MEM8(0xAC) 2150 #define OCR4CH _SFR_MEM8(0xAD) 2153 #define TCCR2A _SFR_MEM8(0xB0) 2155 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2158 unsigned int wgm2 : 2;
2160 unsigned int com2b : 2;
2161 unsigned int com2a : 2;
2164 #define TCCR2A_struct _SFR_MEM8_STRUCT(0xb0, struct __reg_TCCR2A) 2178 #define TCCR2B _SFR_MEM8(0xB1) 2180 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2183 unsigned int cs2 : 3;
2184 unsigned int wgm22 : 1;
2186 unsigned int foc2b : 1;
2187 unsigned int foc2a : 1;
2190 #define TCCR2B_struct _SFR_MEM8_STRUCT(0xb1, struct __reg_TCCR2B) 2204 #define TCNT2 _SFR_MEM8(0xB2) 2218 #define OCR2A _SFR_MEM8(0xB3) 2232 #define OCR2B _SFR_MEM8(0xB4) 2246 #define ASSR _SFR_MEM8(0xB6) 2248 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2251 unsigned int tcr2bub : 1;
2252 unsigned int tcr2aub : 1;
2253 unsigned int ocr2bub : 1;
2254 unsigned int ocr2aub : 1;
2255 unsigned int tcn2ub : 1;
2256 unsigned int as2 : 1;
2257 unsigned int exclk : 1;
2258 unsigned int exclkamr : 1;
2261 #define ASSR_struct _SFR_MEM8_STRUCT(0xb6, struct __reg_ASSR) 2277 #define TWBR _SFR_MEM8(0xB8) 2291 #define TWSR _SFR_MEM8(0xB9) 2293 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2296 unsigned int twps : 2;
2298 unsigned int tws : 5;
2301 #define TWSR_struct _SFR_MEM8_STRUCT(0xb9, struct __reg_TWSR) 2316 #define TWAR _SFR_MEM8(0xBA) 2318 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2321 unsigned int twgce : 1;
2322 unsigned int twa : 7;
2325 #define TWAR_struct _SFR_MEM8_STRUCT(0xba, struct __reg_TWAR) 2341 #define TWDR _SFR_MEM8(0xBB) 2355 #define TWCR _SFR_MEM8(0xBC) 2357 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2360 unsigned int twie : 1;
2362 unsigned int twen : 1;
2363 unsigned int twwc : 1;
2364 unsigned int twsto : 1;
2365 unsigned int twsta : 1;
2366 unsigned int twea : 1;
2367 unsigned int twint : 1;
2370 #define TWCR_struct _SFR_MEM8_STRUCT(0xbc, struct __reg_TWCR) 2385 #define TWAMR _SFR_MEM8(0xBD) 2387 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2391 unsigned int twam : 7;
2394 #define TWAMR_struct _SFR_MEM8_STRUCT(0xbd, struct __reg_TWAMR) 2416 #define UCSR0A _SFR_MEM8(0xC0) 2418 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2421 unsigned int mpcm0 : 1;
2422 unsigned int u2x0 : 1;
2423 unsigned int upe0 : 1;
2424 unsigned int dor0 : 1;
2425 unsigned int fe0 : 1;
2426 unsigned int udre0 : 1;
2427 unsigned int txc0 : 1;
2428 unsigned int rxc0 : 1;
2431 #define UCSR0A_struct _SFR_MEM8_STRUCT(0xc0, struct __reg_UCSR0A) 2447 #define UCSR0B _SFR_MEM8(0xC1) 2449 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2452 unsigned int txb80 : 1;
2453 unsigned int rxb80 : 1;
2454 unsigned int ucsz02 : 1;
2455 unsigned int txen0 : 1;
2456 unsigned int rxen0 : 1;
2457 unsigned int udrie0 : 1;
2458 unsigned int txcie0 : 1;
2459 unsigned int rxcie0 : 1;
2462 #define UCSR0B_struct _SFR_MEM8_STRUCT(0xc1, struct __reg_UCSR0B) 2478 #define UCSR0C _SFR_MEM8(0xC2) 2480 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2483 unsigned int ucpol0 : 1;
2484 unsigned int ucsz0 : 2;
2485 unsigned int ucpha0 : 1;
2486 unsigned int udord0 : 1;
2487 unsigned int usbs0 : 1;
2488 unsigned int upm0 : 2;
2489 unsigned int umsel0 : 2;
2492 #define UCSR0C_struct _SFR_MEM8_STRUCT(0xc2, struct __reg_UCSR0C) 2514 #define UBRR0 _SFR_MEM16(0xC4) 2515 #define UBRR0L _SFR_MEM8(0xC4) 2516 #define UBRR0H _SFR_MEM8(0xC5) 2519 #define UDR0 _SFR_MEM8(0xC6) 2533 #define UCSR1A _SFR_MEM8(0xC8) 2535 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2538 unsigned int mpcm1 : 1;
2539 unsigned int u2x1 : 1;
2540 unsigned int upe1 : 1;
2541 unsigned int dor1 : 1;
2542 unsigned int fe1 : 1;
2543 unsigned int udre1 : 1;
2544 unsigned int txc1 : 1;
2545 unsigned int rxc1 : 1;
2548 #define UCSR1A_struct _SFR_MEM8_STRUCT(0xc8, struct __reg_UCSR1A) 2564 #define UCSR1B _SFR_MEM8(0xC9) 2566 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2569 unsigned int txb81 : 1;
2570 unsigned int rxb81 : 1;
2571 unsigned int ucsz12 : 1;
2572 unsigned int txen1 : 1;
2573 unsigned int rxen1 : 1;
2574 unsigned int udrie1 : 1;
2575 unsigned int txcie1 : 1;
2576 unsigned int rxcie1 : 1;
2579 #define UCSR1B_struct _SFR_MEM8_STRUCT(0xc9, struct __reg_UCSR1B) 2595 #define UCSR1C _SFR_MEM8(0xCA) 2597 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2600 unsigned int ucpol1 : 1;
2601 unsigned int ucsz1 : 2;
2602 unsigned int ucpha1 : 1;
2603 unsigned int udord1 : 1;
2604 unsigned int usbs1 : 1;
2605 unsigned int upm1 : 2;
2606 unsigned int umsel1 : 2;
2609 #define UCSR1C_struct _SFR_MEM8_STRUCT(0xca, struct __reg_UCSR1C) 2629 #define UBRR1 _SFR_MEM16(0xCC) 2630 #define UBRR1L _SFR_MEM8(0xCC) 2631 #define UBRR1H _SFR_MEM8(0xCD) 2634 #define UDR1 _SFR_MEM8(0xCE) 2648 #define SCCR0 _SFR_MEM8(0xDC) 2650 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2653 unsigned int sccmp : 3;
2654 unsigned int sctse : 1;
2655 unsigned int sccksel : 1;
2656 unsigned int scen : 1;
2657 unsigned int scmbts : 1;
2658 unsigned int scres : 1;
2661 #define SCCR0_struct _SFR_MEM8_STRUCT(0xdc, struct __reg_SCCR0) 2677 #define SCCR1 _SFR_MEM8(0xDD) 2679 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2682 unsigned int scenbo : 1;
2686 #define SCCR1_struct _SFR_MEM8_STRUCT(0xdd, struct __reg_SCCR1) 2695 #define SCSR _SFR_MEM8(0xDE) 2697 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2700 unsigned int scbsy : 1;
2704 #define SCSR_struct _SFR_MEM8_STRUCT(0xde, struct __reg_SCSR) 2713 #define SCIRQM _SFR_MEM8(0xDF) 2715 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2718 unsigned int irqmcp : 3;
2719 unsigned int irqmof : 1;
2720 unsigned int irqmbo : 1;
2724 #define SCIRQM_struct _SFR_MEM8_STRUCT(0xdf, struct __reg_SCIRQM) 2737 #define SCIRQS _SFR_MEM8(0xE0) 2739 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2742 unsigned int irqscp : 3;
2743 unsigned int irqsof : 1;
2744 unsigned int irqsbo : 1;
2748 #define SCIRQS_struct _SFR_MEM8_STRUCT(0xe0, struct __reg_SCIRQS) 2761 #define SCCNTLL _SFR_MEM8(0xE1) 2763 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2766 unsigned int sccntll : 8;
2769 #define SCCNTLL_struct _SFR_MEM8_STRUCT(0xe1, struct __reg_SCCNTLL) 2785 #define SCCNTLH _SFR_MEM8(0xE2) 2787 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2790 unsigned int sccntlh : 8;
2793 #define SCCNTLH_struct _SFR_MEM8_STRUCT(0xe2, struct __reg_SCCNTLH) 2809 #define SCCNTHL _SFR_MEM8(0xE3) 2811 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2814 unsigned int sccnthl : 8;
2817 #define SCCNTHL_struct _SFR_MEM8_STRUCT(0xe3, struct __reg_SCCNTHL) 2833 #define SCCNTHH _SFR_MEM8(0xE4) 2835 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2838 unsigned int sccnthh : 8;
2841 #define SCCNTHH_struct _SFR_MEM8_STRUCT(0xe4, struct __reg_SCCNTHH) 2857 #define SCBTSRLL _SFR_MEM8(0xE5) 2859 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2862 unsigned int scbtsrll : 8;
2865 #define SCBTSRLL_struct _SFR_MEM8_STRUCT(0xe5, struct __reg_SCBTSRLL) 2881 #define SCBTSRLH _SFR_MEM8(0xE6) 2883 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2886 unsigned int scbtsrlh : 8;
2889 #define SCBTSRLH_struct _SFR_MEM8_STRUCT(0xe6, struct __reg_SCBTSRLH) 2905 #define SCBTSRHL _SFR_MEM8(0xE7) 2907 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2910 unsigned int scbtsrhl : 8;
2913 #define SCBTSRHL_struct _SFR_MEM8_STRUCT(0xe7, struct __reg_SCBTSRHL) 2929 #define SCBTSRHH _SFR_MEM8(0xE8) 2931 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2934 unsigned int scbtsrhh : 8;
2937 #define SCBTSRHH_struct _SFR_MEM8_STRUCT(0xe8, struct __reg_SCBTSRHH) 2953 #define SCTSRLL _SFR_MEM8(0xE9) 2955 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2958 unsigned int sctsrll : 8;
2961 #define SCTSRLL_struct _SFR_MEM8_STRUCT(0xe9, struct __reg_SCTSRLL) 2977 #define SCTSRLH _SFR_MEM8(0xEA) 2979 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 2982 unsigned int sctsrlh : 8;
2985 #define SCTSRLH_struct _SFR_MEM8_STRUCT(0xea, struct __reg_SCTSRLH) 3001 #define SCTSRHL _SFR_MEM8(0xEB) 3003 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3006 unsigned int sctsrhl : 8;
3009 #define SCTSRHL_struct _SFR_MEM8_STRUCT(0xeb, struct __reg_SCTSRHL) 3025 #define SCTSRHH _SFR_MEM8(0xEC) 3027 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3030 unsigned int sctsrhh : 8;
3033 #define SCTSRHH_struct _SFR_MEM8_STRUCT(0xec, struct __reg_SCTSRHH) 3049 #define SCOCR3LL _SFR_MEM8(0xED) 3051 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3054 unsigned int scocr3ll : 8;
3057 #define SCOCR3LL_struct _SFR_MEM8_STRUCT(0xed, struct __reg_SCOCR3LL) 3073 #define SCOCR3LH _SFR_MEM8(0xEE) 3075 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3078 unsigned int scocr3lh : 8;
3081 #define SCOCR3LH_struct _SFR_MEM8_STRUCT(0xee, struct __reg_SCOCR3LH) 3097 #define SCOCR3HL _SFR_MEM8(0xEF) 3099 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3102 unsigned int scocr3hl : 8;
3105 #define SCOCR3HL_struct _SFR_MEM8_STRUCT(0xef, struct __reg_SCOCR3HL) 3121 #define SCOCR3HH _SFR_MEM8(0xF0) 3123 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3126 unsigned int scocr3hh : 8;
3129 #define SCOCR3HH_struct _SFR_MEM8_STRUCT(0xf0, struct __reg_SCOCR3HH) 3145 #define SCOCR2LL _SFR_MEM8(0xF1) 3147 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3150 unsigned int scocr2ll : 8;
3153 #define SCOCR2LL_struct _SFR_MEM8_STRUCT(0xf1, struct __reg_SCOCR2LL) 3169 #define SCOCR2LH _SFR_MEM8(0xF2) 3171 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3174 unsigned int scocr2lh : 8;
3177 #define SCOCR2LH_struct _SFR_MEM8_STRUCT(0xf2, struct __reg_SCOCR2LH) 3193 #define SCOCR2HL _SFR_MEM8(0xF3) 3195 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3198 unsigned int scocr2hl : 8;
3201 #define SCOCR2HL_struct _SFR_MEM8_STRUCT(0xf3, struct __reg_SCOCR2HL) 3217 #define SCOCR2HH _SFR_MEM8(0xF4) 3219 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3222 unsigned int scocr2hh : 8;
3225 #define SCOCR2HH_struct _SFR_MEM8_STRUCT(0xf4, struct __reg_SCOCR2HH) 3241 #define SCOCR1LL _SFR_MEM8(0xF5) 3243 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3246 unsigned int scocr1ll : 8;
3249 #define SCOCR1LL_struct _SFR_MEM8_STRUCT(0xf5, struct __reg_SCOCR1LL) 3265 #define SCOCR1LH _SFR_MEM8(0xF6) 3267 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3270 unsigned int scocr1lh : 8;
3273 #define SCOCR1LH_struct _SFR_MEM8_STRUCT(0xf6, struct __reg_SCOCR1LH) 3289 #define SCOCR1HL _SFR_MEM8(0xF7) 3291 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3294 unsigned int scocr1hl : 8;
3297 #define SCOCR1HL_struct _SFR_MEM8_STRUCT(0xf7, struct __reg_SCOCR1HL) 3313 #define SCOCR1HH _SFR_MEM8(0xF8) 3315 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3318 unsigned int scocr1hh : 8;
3321 #define SCOCR1HH_struct _SFR_MEM8_STRUCT(0xf8, struct __reg_SCOCR1HH) 3337 #define TCCR5A _SFR_MEM8(0x120) 3339 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3342 unsigned int wgm5 : 2;
3343 unsigned int com5c : 2;
3344 unsigned int com5b : 2;
3345 unsigned int com5a : 2;
3348 #define TCCR5A_struct _SFR_MEM8_STRUCT(0x120, struct __reg_TCCR5A) 3364 #define TCCR5B _SFR_MEM8(0x121) 3366 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3369 unsigned int cs5 : 3;
3370 unsigned int wgm5 : 2;
3372 unsigned int ices5 : 1;
3373 unsigned int icnc5 : 1;
3376 #define TCCR5B_struct _SFR_MEM8_STRUCT(0x121, struct __reg_TCCR5B) 3391 #define TCCR5C _SFR_MEM8(0x122) 3393 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3397 unsigned int foc5c : 1;
3398 unsigned int foc5b : 1;
3399 unsigned int foc5a : 1;
3402 #define TCCR5C_struct _SFR_MEM8_STRUCT(0x122, struct __reg_TCCR5C) 3413 #define TCNT5 _SFR_MEM16(0x124) 3414 #define TCNT5L _SFR_MEM8(0x124) 3415 #define TCNT5H _SFR_MEM8(0x125) 3418 #define ICR5 _SFR_MEM16(0x126) 3419 #define ICR5L _SFR_MEM8(0x126) 3420 #define ICR5H _SFR_MEM8(0x127) 3423 #define OCR5A _SFR_MEM16(0x128) 3424 #define OCR5AL _SFR_MEM8(0x128) 3425 #define OCR5AH _SFR_MEM8(0x129) 3428 #define OCR5B _SFR_MEM16(0x12A) 3429 #define OCR5BL _SFR_MEM8(0x12A) 3430 #define OCR5BH _SFR_MEM8(0x12B) 3433 #define OCR5C _SFR_MEM16(0x12C) 3434 #define OCR5CL _SFR_MEM8(0x12C) 3435 #define OCR5CH _SFR_MEM8(0x12D) 3438 #define LLCR _SFR_MEM8(0x12F) 3440 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3443 unsigned int llencal : 1;
3444 unsigned int llshort : 1;
3445 unsigned int lltco : 1;
3446 unsigned int llcal : 1;
3447 unsigned int llcomp : 1;
3448 unsigned int lldone : 1;
3452 #define LLCR_struct _SFR_MEM8_STRUCT(0x12f, struct __reg_LLCR) 3466 #define LLDRL _SFR_MEM8(0x130) 3468 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3471 unsigned int lldrl : 4;
3475 #define LLDRL_struct _SFR_MEM8_STRUCT(0x130, struct __reg_LLDRL) 3487 #define LLDRH _SFR_MEM8(0x131) 3489 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3492 unsigned int lldrh : 5;
3496 #define LLDRH_struct _SFR_MEM8_STRUCT(0x131, struct __reg_LLDRH) 3509 #define DRTRAM3 _SFR_MEM8(0x132) 3511 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3515 unsigned int endrt : 1;
3516 unsigned int drtswok : 1;
3520 #define DRTRAM3_struct _SFR_MEM8_STRUCT(0x132, struct __reg_DRTRAM3) 3530 #define DRTRAM2 _SFR_MEM8(0x133) 3532 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3536 unsigned int endrt : 1;
3537 unsigned int drtswok : 1;
3541 #define DRTRAM2_struct _SFR_MEM8_STRUCT(0x133, struct __reg_DRTRAM2) 3551 #define DRTRAM1 _SFR_MEM8(0x134) 3553 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3557 unsigned int endrt : 1;
3558 unsigned int drtswok : 1;
3562 #define DRTRAM1_struct _SFR_MEM8_STRUCT(0x134, struct __reg_DRTRAM1) 3572 #define DRTRAM0 _SFR_MEM8(0x135) 3574 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3578 unsigned int endrt : 1;
3579 unsigned int drtswok : 1;
3583 #define DRTRAM0_struct _SFR_MEM8_STRUCT(0x135, struct __reg_DRTRAM0) 3593 #define DPDS0 _SFR_MEM8(0x136) 3595 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3598 unsigned int pbdrv : 2;
3599 unsigned int pddrv : 2;
3600 unsigned int pedrv : 2;
3601 unsigned int pfdrv : 2;
3604 #define DPDS0_struct _SFR_MEM8_STRUCT(0x136, struct __reg_DPDS0) 3620 #define DPDS1 _SFR_MEM8(0x137) 3622 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3625 unsigned int pgdrv : 2;
3629 #define DPDS1_struct _SFR_MEM8_STRUCT(0x137, struct __reg_DPDS1) 3639 #define TRXPR _SFR_MEM8(0x139) 3641 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3644 unsigned int trxrst : 1;
3645 unsigned int slptr : 1;
3649 #define TRXPR_struct _SFR_MEM8_STRUCT(0x139, struct __reg_TRXPR) 3659 #define AES_CTRL _SFR_MEM8(0x13C) 3661 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3665 unsigned int aes_im : 1;
3666 unsigned int aes_dir : 1;
3668 unsigned int aes_mode : 1;
3670 unsigned int aes_request : 1;
3673 #define AES_CTRL_struct _SFR_MEM8_STRUCT(0x13c, struct __reg_AES_CTRL) 3677 #define AES_DIR_ENC 0 3678 #define AES_DIR_DEC 1 3679 #define AES_MODE_ECB 0 3680 #define AES_MODE_CBC 1 3689 #define AES_REQUEST 7 3692 #define AES_STATUS _SFR_MEM8(0x13D) 3694 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3697 unsigned int aes_done : 1;
3699 unsigned int aes_er : 1;
3702 #define AES_STATUS_struct _SFR_MEM8_STRUCT(0x13d, struct __reg_AES_STATUS) 3712 #define AES_STATE _SFR_MEM8(0x13E) 3714 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3717 unsigned int aes_state : 8;
3720 #define AES_STATE_struct _SFR_MEM8_STRUCT(0x13e, struct __reg_AES_STATE) 3726 #define AES_STATE0 0 3727 #define AES_STATE1 1 3728 #define AES_STATE2 2 3729 #define AES_STATE3 3 3730 #define AES_STATE4 4 3731 #define AES_STATE5 5 3732 #define AES_STATE6 6 3733 #define AES_STATE7 7 3736 #define AES_KEY _SFR_MEM8(0x13F) 3738 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3741 unsigned int aes_key : 8;
3744 #define AES_KEY_struct _SFR_MEM8_STRUCT(0x13f, struct __reg_AES_KEY) 3760 #define TRX_STATUS _SFR_MEM8(0x141) 3762 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3765 unsigned int trx_status : 5;
3766 unsigned int tst_status : 1;
3767 unsigned int cca_status : 1;
3768 unsigned int cca_done : 1;
3771 #define TRX_STATUS_struct _SFR_MEM8_STRUCT(0x141, struct __reg_TRX_STATUS) 3782 #define BUSY_RX_AACK 17 3783 #define BUSY_TX_ARET 18 3784 #define RX_AACK_ON 22 3785 #define TX_ARET_ON 25 3786 #define STATE_TRANSITION_IN_PROGRESS 31 3787 #define TST_DISABLED 0 3788 #define TST_ENABLED 1 3791 #define CCA_NOT_FIN 0 3798 #define TRX_STATUS0 0 3799 #define TRX_STATUS1 1 3800 #define TRX_STATUS2 2 3801 #define TRX_STATUS3 3 3802 #define TRX_STATUS4 4 3803 #define TST_STATUS 5 3804 #define CCA_STATUS 6 3808 #define TRX_STATE _SFR_MEM8(0x142) 3810 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3813 unsigned int trx_cmd : 5;
3814 unsigned int trac_status : 3;
3817 #define TRX_STATE_struct _SFR_MEM8_STRUCT(0x142, struct __reg_TRX_STATE) 3822 #define CMD_TX_START 2 3823 #define CMD_FORCE_TRX_OFF 3 3824 #define CMD_FORCE_PLL_ON 4 3826 #define CMD_TRX_OFF 8 3827 #define CMD_PLL_ON 9 3828 #define CMD_RX_AACK_ON 22 3829 #define CMD_TX_ARET_ON 25 3830 #define TRAC_SUCCESS 0 3831 #define TRAC_SUCCESS_DATA_PENDING 1 3832 #define TRAC_SUCCESS_WAIT_FOR_ACK 2 3833 #define TRAC_CHANNEL_ACCESS_FAILURE 3 3834 #define TRAC_NO_ACK 5 3835 #define TRAC_INVALID 7 3846 #define TRAC_STATUS0 5 3847 #define TRAC_STATUS1 6 3848 #define TRAC_STATUS2 7 3851 #define TRX_CTRL_0 _SFR_MEM8(0x143) 3854 #define TRX_CTRL_1 _SFR_MEM8(0x144) 3856 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3860 unsigned int tx_auto_crc_on : 1;
3861 unsigned int irq_2_ext_en : 1;
3862 unsigned int pa_ext_en : 1;
3865 #define TRX_CTRL_1_struct _SFR_MEM8_STRUCT(0x144, struct __reg_TRX_CTRL_1) 3871 #define TX_AUTO_CRC_ON 5 3872 #define IRQ_2_EXT_EN 6 3876 #define PHY_TX_PWR _SFR_MEM8(0x145) 3878 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3881 unsigned int tx_pwr : 4;
3882 unsigned int pa_lt : 2;
3883 unsigned int pa_buf_lt : 2;
3886 #define PHY_TX_PWR_struct _SFR_MEM8_STRUCT(0x145, struct __reg_PHY_TX_PWR) 3894 #define PA_BUF_LT_0US 0 3895 #define PA_BUF_LT_2US 1 3896 #define PA_BUF_LT_4US 2 3897 #define PA_BUF_LT_6US 3 3909 #define PA_BUF_LT0 6 3910 #define PA_BUF_LT1 7 3913 #define PHY_RSSI _SFR_MEM8(0x146) 3915 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3918 unsigned int rssi : 5;
3919 unsigned int rnd_value : 2;
3920 unsigned int rx_crc_valid : 1;
3923 #define PHY_RSSI_struct _SFR_MEM8_STRUCT(0x146, struct __reg_PHY_RSSI) 3928 #define RSSI_MIN_PLUS_3dB 1 3930 #define CRC_INVALID 0 3942 #define RND_VALUE0 5 3943 #define RND_VALUE1 6 3944 #define RX_CRC_VALID 7 3947 #define PHY_ED_LEVEL _SFR_MEM8(0x147) 3949 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3952 unsigned int ed_level : 8;
3955 #define PHY_ED_LEVEL_struct _SFR_MEM8_STRUCT(0x147, struct __reg_PHY_ED_LEVEL) 3960 #define ED_MIN_PLUS_1dB 1 3962 #define ED_RESET 255 3978 #define PHY_CC_CCA _SFR_MEM8(0x148) 3980 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 3983 unsigned int channel : 5;
3984 unsigned int cca_mode : 2;
3985 unsigned int cca_request : 1;
3988 #define PHY_CC_CCA_struct _SFR_MEM8_STRUCT(0x148, struct __reg_PHY_CC_CCA) 3992 #define F_2405MHZ 11 3993 #define F_2410MHZ 12 3994 #define F_2415MHZ 13 3995 #define F_2420MHZ 14 3996 #define F_2425MHZ 15 3997 #define F_2430MHZ 16 3998 #define F_2435MHZ 17 3999 #define F_2440MHZ 18 4000 #define F_2445MHZ 19 4001 #define F_2450MHZ 20 4002 #define F_2455MHZ 21 4003 #define F_2460MHZ 22 4004 #define F_2465MHZ 23 4005 #define F_2470MHZ 24 4006 #define F_2475MHZ 25 4007 #define F_2480MHZ 26 4008 #define CCA_CS_OR_ED 0 4011 #define CCA_CS_AND_ED 3 4024 #define CCA_REQUEST 7 4027 #define CCA_THRES _SFR_MEM8(0x149) 4029 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4032 unsigned int cca_ed_thres : 4;
4033 unsigned int cca_cs_thres : 4;
4036 #define CCA_THRES_struct _SFR_MEM8_STRUCT(0x149, struct __reg_CCA_THRES) 4042 #define CCA_ED_THRES0 0 4043 #define CCA_ED_THRES1 1 4044 #define CCA_ED_THRES2 2 4045 #define CCA_ED_THRES3 3 4046 #define CCA_CS_THRES0 4 4047 #define CCA_CS_THRES1 5 4048 #define CCA_CS_THRES2 6 4049 #define CCA_CS_THRES3 7 4052 #define RX_CTRL _SFR_MEM8(0x14A) 4054 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4057 unsigned int pdt_thres : 4;
4061 #define RX_CTRL_struct _SFR_MEM8_STRUCT(0x14a, struct __reg_RX_CTRL) 4065 #define PDT_THRES_ANT_DIV_OFF 7 4066 #define PDT_THRES_ANT_DIV_ON 3 4072 #define PDT_THRES0 0 4073 #define PDT_THRES1 1 4074 #define PDT_THRES2 2 4075 #define PDT_THRES3 3 4078 #define SFD_VALUE _SFR_MEM8(0x14B) 4080 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4083 unsigned int sfd_value : 8;
4086 #define SFD_VALUE_struct _SFR_MEM8_STRUCT(0x14b, struct __reg_SFD_VALUE) 4090 #define IEEE_SFD 167 4096 #define SFD_VALUE0 0 4097 #define SFD_VALUE1 1 4098 #define SFD_VALUE2 2 4099 #define SFD_VALUE3 3 4100 #define SFD_VALUE4 4 4101 #define SFD_VALUE5 5 4102 #define SFD_VALUE6 6 4103 #define SFD_VALUE7 7 4106 #define TRX_CTRL_2 _SFR_MEM8(0x14C) 4108 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4111 unsigned int oqpsk_data_rate : 2;
4113 unsigned int rx_safe_mode : 1;
4116 #define TRX_CTRL_2_struct _SFR_MEM8_STRUCT(0x14c, struct __reg_TRX_CTRL_2) 4120 #define RATE_250KB 0 4121 #define RATE_500KB 1 4122 #define RATE_1000KB 2 4123 #define RATE_2000KB 3 4129 #define OQPSK_DATA_RATE0 0 4130 #define OQPSK_DATA_RATE1 1 4131 #define RX_SAFE_MODE 7 4134 #define ANT_DIV _SFR_MEM8(0x14D) 4136 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4139 unsigned int ant_ctrl : 2;
4140 unsigned int ant_ext_sw_en : 1;
4141 unsigned int ant_div_en : 1;
4143 unsigned int ant_sel : 1;
4146 #define ANT_DIV_struct _SFR_MEM8_STRUCT(0x14d, struct __reg_ANT_DIV) 4153 #define ANT_DIV_EXT_SW_DIS 0 4154 #define ANT_DIV_EXT_SW_EN 1 4164 #define ANT_EXT_SW_EN 2 4165 #define ANT_DIV_EN 3 4169 #define IRQ_MASK _SFR_MEM8(0x14E) 4171 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4174 unsigned int pll_lock_en : 1;
4175 unsigned int pll_unlock_en : 1;
4176 unsigned int rx_start_en : 1;
4177 unsigned int rx_end_en : 1;
4178 unsigned int cca_ed_done_en : 1;
4179 unsigned int ami_en : 1;
4180 unsigned int tx_end_en : 1;
4181 unsigned int awake_en : 1;
4184 #define IRQ_MASK_struct _SFR_MEM8_STRUCT(0x14e, struct __reg_IRQ_MASK) 4190 #define PLL_LOCK_EN 0 4191 #define PLL_UNLOCK_EN 1 4192 #define RX_START_EN 2 4194 #define CCA_ED_DONE_EN 4 4200 #define IRQ_STATUS _SFR_MEM8(0x14F) 4202 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4205 unsigned int pll_lock : 1;
4206 unsigned int pll_unlock : 1;
4207 unsigned int rx_start : 1;
4208 unsigned int rx_end : 1;
4209 unsigned int cca_ed_done : 1;
4210 unsigned int ami : 1;
4211 unsigned int tx_end : 1;
4212 unsigned int awake : 1;
4215 #define IRQ_STATUS_struct _SFR_MEM8_STRUCT(0x14f, struct __reg_IRQ_STATUS) 4222 #define PLL_UNLOCK 1 4225 #define CCA_ED_DONE 4 4231 #define VREG_CTRL _SFR_MEM8(0x150) 4233 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4237 unsigned int dvdd_ok : 1;
4238 unsigned int dvreg_ext : 1;
4240 unsigned int avdd_ok : 1;
4241 unsigned int avreg_ext : 1;
4244 #define VREG_CTRL_struct _SFR_MEM8_STRUCT(0x150, struct __reg_VREG_CTRL) 4263 #define BATMON _SFR_MEM8(0x151) 4265 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4268 unsigned int batmon_vth : 4;
4269 unsigned int batmon_hr : 1;
4270 unsigned int batmon_ok : 1;
4271 unsigned int bat_low_en : 1;
4272 unsigned int bat_low : 1;
4275 #define BATMON_struct _SFR_MEM8_STRUCT(0x151, struct __reg_BATMON) 4279 #define BATMON_HR_DIS 0 4280 #define BATMON_HR_EN 1 4286 #define BATMON_VTH0 0 4287 #define BATMON_VTH1 1 4288 #define BATMON_VTH2 2 4289 #define BATMON_VTH3 3 4292 #define BAT_LOW_EN 6 4296 #define XOSC_CTRL _SFR_MEM8(0x152) 4298 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4301 unsigned int xtal_trim : 4;
4302 unsigned int xtal_mode : 4;
4305 #define XOSC_CTRL_struct _SFR_MEM8_STRUCT(0x152, struct __reg_XOSC_CTRL) 4309 #define XTAL_TRIM_MIN 0 4310 #define XTAL_TRIM_MAX 15 4316 #define XTAL_TRIM0 0 4317 #define XTAL_TRIM1 1 4318 #define XTAL_TRIM2 2 4319 #define XTAL_TRIM3 3 4320 #define XTAL_MODE0 4 4321 #define XTAL_MODE1 5 4322 #define XTAL_MODE2 6 4323 #define XTAL_MODE3 7 4326 #define RX_SYN _SFR_MEM8(0x155) 4328 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4331 unsigned int rx_pdt_level : 4;
4333 unsigned int rx_pdt_dis : 1;
4336 #define RX_SYN_struct _SFR_MEM8_STRUCT(0x155, struct __reg_RX_SYN) 4340 #define RX_PDT_LEVEL_MIN 0 4341 #define RX_PDT_LEVEL_MAX 15 4347 #define RX_PDT_LEVEL0 0 4348 #define RX_PDT_LEVEL1 1 4349 #define RX_PDT_LEVEL2 2 4350 #define RX_PDT_LEVEL3 3 4351 #define RX_PDT_DIS 7 4354 #define XAH_CTRL_1 _SFR_MEM8(0x157) 4356 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4360 unsigned int aack_prom_mode : 1;
4361 unsigned int aack_ack_time : 1;
4363 unsigned int aack_upld_res_ft : 1;
4364 unsigned int aack_fltr_res_ft : 1;
4368 #define XAH_CTRL_1_struct _SFR_MEM8_STRUCT(0x157, struct __reg_XAH_CTRL_1) 4372 #define AACK_ACK_TIME_12_SYM 0 4373 #define AACK_ACK_TIME_2_SYM 1 4379 #define AACK_PROM_MODE 1 4380 #define AACK_ACK_TIME 2 4381 #define AACK_UPLD_RES_FT 4 4382 #define AACK_FLTR_RES_FT 5 4385 #define FTN_CTRL _SFR_MEM8(0x158) 4387 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4391 unsigned int ftn_start : 1;
4394 #define FTN_CTRL_struct _SFR_MEM8_STRUCT(0x158, struct __reg_FTN_CTRL) 4403 #define PLL_CF _SFR_MEM8(0x15A) 4405 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4409 unsigned int pll_cf_start : 1;
4412 #define PLL_CF_struct _SFR_MEM8_STRUCT(0x15a, struct __reg_PLL_CF) 4418 #define PLL_CF_START 7 4421 #define PLL_DCU _SFR_MEM8(0x15B) 4423 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4427 unsigned int pll_dcu_start : 1;
4430 #define PLL_DCU_struct _SFR_MEM8_STRUCT(0x15b, struct __reg_PLL_DCU) 4436 #define PLL_DCU_START 7 4439 #define PART_NUM _SFR_MEM8(0x15C) 4441 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4444 unsigned int part_num : 8;
4447 #define PART_NUM_struct _SFR_MEM8_STRUCT(0x15c, struct __reg_PART_NUM) 4451 #define P_ATmega128RFA1 131 4467 #define VERSION_NUM _SFR_MEM8(0x15D) 4469 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4472 unsigned int version_num : 8;
4475 #define VERSION_NUM_struct _SFR_MEM8_STRUCT(0x15d, struct __reg_VERSION_NUM) 4486 #define VERSION_NUM0 0 4487 #define VERSION_NUM1 1 4488 #define VERSION_NUM2 2 4489 #define VERSION_NUM3 3 4490 #define VERSION_NUM4 4 4491 #define VERSION_NUM5 5 4492 #define VERSION_NUM6 6 4493 #define VERSION_NUM7 7 4496 #define MAN_ID_0 _SFR_MEM8(0x15E) 4498 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4501 unsigned int man_id_0 : 8;
4504 #define MAN_ID_0_struct _SFR_MEM8_STRUCT(0x15e, struct __reg_MAN_ID_0) 4508 #define ATMEL_BYTE_0 31 4524 #define MAN_ID_1 _SFR_MEM8(0x15F) 4526 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4529 unsigned int man_id_1 : 8;
4532 #define MAN_ID_1_struct _SFR_MEM8_STRUCT(0x15f, struct __reg_MAN_ID_1) 4536 #define ATMEL_BYTE_1 0 4552 #define SHORT_ADDR_0 _SFR_MEM8(0x160) 4554 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4557 unsigned int short_addr_0 : 8;
4560 #define SHORT_ADDR_0_struct _SFR_MEM8_STRUCT(0x160, struct __reg_SHORT_ADDR_0) 4566 #define SHORT_ADDR_00 0 4567 #define SHORT_ADDR_01 1 4568 #define SHORT_ADDR_02 2 4569 #define SHORT_ADDR_03 3 4570 #define SHORT_ADDR_04 4 4571 #define SHORT_ADDR_05 5 4572 #define SHORT_ADDR_06 6 4573 #define SHORT_ADDR_07 7 4576 #define SHORT_ADDR_1 _SFR_MEM8(0x161) 4578 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4581 unsigned int short_addr_1 : 8;
4584 #define SHORT_ADDR_1_struct _SFR_MEM8_STRUCT(0x161, struct __reg_SHORT_ADDR_1) 4590 #define SHORT_ADDR_10 0 4591 #define SHORT_ADDR_11 1 4592 #define SHORT_ADDR_12 2 4593 #define SHORT_ADDR_13 3 4594 #define SHORT_ADDR_14 4 4595 #define SHORT_ADDR_15 5 4596 #define SHORT_ADDR_16 6 4597 #define SHORT_ADDR_17 7 4600 #define PAN_ID_0 _SFR_MEM8(0x162) 4602 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4605 unsigned int pan_id_0 : 8;
4608 #define PAN_ID_0_struct _SFR_MEM8_STRUCT(0x162, struct __reg_PAN_ID_0) 4624 #define PAN_ID_1 _SFR_MEM8(0x163) 4626 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4629 unsigned int pan_id_1 : 8;
4632 #define PAN_ID_1_struct _SFR_MEM8_STRUCT(0x163, struct __reg_PAN_ID_1) 4648 #define IEEE_ADDR_0 _SFR_MEM8(0x164) 4650 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4653 unsigned int ieee_addr_0 : 8;
4656 #define IEEE_ADDR_0_struct _SFR_MEM8_STRUCT(0x164, struct __reg_IEEE_ADDR_0) 4662 #define IEEE_ADDR_00 0 4663 #define IEEE_ADDR_01 1 4664 #define IEEE_ADDR_02 2 4665 #define IEEE_ADDR_03 3 4666 #define IEEE_ADDR_04 4 4667 #define IEEE_ADDR_05 5 4668 #define IEEE_ADDR_06 6 4669 #define IEEE_ADDR_07 7 4672 #define IEEE_ADDR_1 _SFR_MEM8(0x165) 4674 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4677 unsigned int ieee_addr_1 : 8;
4680 #define IEEE_ADDR_1_struct _SFR_MEM8_STRUCT(0x165, struct __reg_IEEE_ADDR_1) 4686 #define IEEE_ADDR_10 0 4687 #define IEEE_ADDR_11 1 4688 #define IEEE_ADDR_12 2 4689 #define IEEE_ADDR_13 3 4690 #define IEEE_ADDR_14 4 4691 #define IEEE_ADDR_15 5 4692 #define IEEE_ADDR_16 6 4693 #define IEEE_ADDR_17 7 4696 #define IEEE_ADDR_2 _SFR_MEM8(0x166) 4698 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4701 unsigned int ieee_addr_2 : 8;
4704 #define IEEE_ADDR_2_struct _SFR_MEM8_STRUCT(0x166, struct __reg_IEEE_ADDR_2) 4710 #define IEEE_ADDR_20 0 4711 #define IEEE_ADDR_21 1 4712 #define IEEE_ADDR_22 2 4713 #define IEEE_ADDR_23 3 4714 #define IEEE_ADDR_24 4 4715 #define IEEE_ADDR_25 5 4716 #define IEEE_ADDR_26 6 4717 #define IEEE_ADDR_27 7 4720 #define IEEE_ADDR_3 _SFR_MEM8(0x167) 4722 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4725 unsigned int ieee_addr_3 : 8;
4728 #define IEEE_ADDR_3_struct _SFR_MEM8_STRUCT(0x167, struct __reg_IEEE_ADDR_3) 4734 #define IEEE_ADDR_30 0 4735 #define IEEE_ADDR_31 1 4736 #define IEEE_ADDR_32 2 4737 #define IEEE_ADDR_33 3 4738 #define IEEE_ADDR_34 4 4739 #define IEEE_ADDR_35 5 4740 #define IEEE_ADDR_36 6 4741 #define IEEE_ADDR_37 7 4744 #define IEEE_ADDR_4 _SFR_MEM8(0x168) 4746 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4749 unsigned int ieee_addr_4 : 8;
4752 #define IEEE_ADDR_4_struct _SFR_MEM8_STRUCT(0x168, struct __reg_IEEE_ADDR_4) 4758 #define IEEE_ADDR_40 0 4759 #define IEEE_ADDR_41 1 4760 #define IEEE_ADDR_42 2 4761 #define IEEE_ADDR_43 3 4762 #define IEEE_ADDR_44 4 4763 #define IEEE_ADDR_45 5 4764 #define IEEE_ADDR_46 6 4765 #define IEEE_ADDR_47 7 4768 #define IEEE_ADDR_5 _SFR_MEM8(0x169) 4770 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4773 unsigned int ieee_addr_5 : 8;
4776 #define IEEE_ADDR_5_struct _SFR_MEM8_STRUCT(0x169, struct __reg_IEEE_ADDR_5) 4782 #define IEEE_ADDR_50 0 4783 #define IEEE_ADDR_51 1 4784 #define IEEE_ADDR_52 2 4785 #define IEEE_ADDR_53 3 4786 #define IEEE_ADDR_54 4 4787 #define IEEE_ADDR_55 5 4788 #define IEEE_ADDR_56 6 4789 #define IEEE_ADDR_57 7 4792 #define IEEE_ADDR_6 _SFR_MEM8(0x16A) 4794 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4797 unsigned int ieee_addr_6 : 8;
4800 #define IEEE_ADDR_6_struct _SFR_MEM8_STRUCT(0x16a, struct __reg_IEEE_ADDR_6) 4806 #define IEEE_ADDR_60 0 4807 #define IEEE_ADDR_61 1 4808 #define IEEE_ADDR_62 2 4809 #define IEEE_ADDR_63 3 4810 #define IEEE_ADDR_64 4 4811 #define IEEE_ADDR_65 5 4812 #define IEEE_ADDR_66 6 4813 #define IEEE_ADDR_67 7 4816 #define IEEE_ADDR_7 _SFR_MEM8(0x16B) 4818 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4821 unsigned int ieee_addr_7 : 8;
4824 #define IEEE_ADDR_7_struct _SFR_MEM8_STRUCT(0x16b, struct __reg_IEEE_ADDR_7) 4830 #define IEEE_ADDR_70 0 4831 #define IEEE_ADDR_71 1 4832 #define IEEE_ADDR_72 2 4833 #define IEEE_ADDR_73 3 4834 #define IEEE_ADDR_74 4 4835 #define IEEE_ADDR_75 5 4836 #define IEEE_ADDR_76 6 4837 #define IEEE_ADDR_77 7 4840 #define XAH_CTRL_0 _SFR_MEM8(0x16C) 4842 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4845 unsigned int slotted_operation : 1;
4846 unsigned int max_csma_retries : 3;
4847 unsigned int max_frame_retries : 4;
4850 #define XAH_CTRL_0_struct _SFR_MEM8_STRUCT(0x16c, struct __reg_XAH_CTRL_0) 4854 #define SLOTTED_OP_DIS 0 4855 #define SLOTTED_OP_EN 1 4861 #define SLOTTED_OPERATION 0 4862 #define MAX_CSMA_RETRIES0 1 4863 #define MAX_CSMA_RETRIES1 2 4864 #define MAX_CSMA_RETRIES2 3 4865 #define MAX_FRAME_RETRIES0 4 4866 #define MAX_FRAME_RETRIES1 5 4867 #define MAX_FRAME_RETRIES2 6 4868 #define MAX_FRAME_RETRIES3 7 4871 #define CSMA_SEED_0 _SFR_MEM8(0x16D) 4873 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4876 unsigned int csma_seed_0 : 8;
4879 #define CSMA_SEED_0_struct _SFR_MEM8_STRUCT(0x16d, struct __reg_CSMA_SEED_0) 4885 #define CSMA_SEED_00 0 4886 #define CSMA_SEED_01 1 4887 #define CSMA_SEED_02 2 4888 #define CSMA_SEED_03 3 4889 #define CSMA_SEED_04 4 4890 #define CSMA_SEED_05 5 4891 #define CSMA_SEED_06 6 4892 #define CSMA_SEED_07 7 4895 #define CSMA_SEED_1 _SFR_MEM8(0x16E) 4897 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4900 unsigned int csma_seed_1 : 3;
4901 unsigned int aack_i_am_coord : 1;
4902 unsigned int aack_dis_ack : 1;
4903 unsigned int aack_set_pd : 1;
4904 unsigned int aack_fvn_mode : 2;
4907 #define CSMA_SEED_1_struct _SFR_MEM8_STRUCT(0x16e, struct __reg_CSMA_SEED_1) 4913 #define CSMA_SEED_10 0 4914 #define CSMA_SEED_11 1 4915 #define CSMA_SEED_12 2 4916 #define AACK_I_AM_COORD 3 4917 #define AACK_DIS_ACK 4 4918 #define AACK_SET_PD 5 4919 #define AACK_FVN_MODE0 6 4920 #define AACK_FVN_MODE1 7 4923 #define CSMA_BE _SFR_MEM8(0x16F) 4925 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4928 unsigned int min_be : 4;
4929 unsigned int max_be : 4;
4932 #define CSMA_BE_struct _SFR_MEM8_STRUCT(0x16f, struct __reg_CSMA_BE) 4948 #define TST_CTRL_DIGI _SFR_MEM8(0x176) 4950 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4953 unsigned int tst_ctrl_dig : 4;
4957 #define TST_CTRL_DIGI_struct _SFR_MEM8_STRUCT(0x176, struct __reg_TST_CTRL_DIGI) 4963 #define TST_CTRL_DIG0 0 4964 #define TST_CTRL_DIG1 1 4965 #define TST_CTRL_DIG2 2 4966 #define TST_CTRL_DIG3 3 4969 #define TST_RX_LENGTH _SFR_MEM8(0x17B) 4971 #if !(defined(__ASSEMBLER__) || defined(__NOSTRUCT__)) 4974 unsigned int rx_length : 8;
4977 #define TST_RX_LENGTH_struct _SFR_MEM8_STRUCT(0x17b, struct __reg_TST_RX_LENGTH) 4983 #define RX_LENGTH0 0 4984 #define RX_LENGTH1 1 4985 #define RX_LENGTH2 2 4986 #define RX_LENGTH3 3 4987 #define RX_LENGTH4 4 4988 #define RX_LENGTH5 5 4989 #define RX_LENGTH6 6 4990 #define RX_LENGTH7 7 4993 #define TRXFBST _SFR_MEM8(0x180) 5007 #define TRXFBEND _SFR_MEM8(0x1FF) 5024 #define _VECTORS_SIZE 288 5027 #define INT0_vect _VECTOR(1) 5028 #define INT0_vect_num 1 5031 #define INT1_vect _VECTOR(2) 5032 #define INT1_vect_num 2 5035 #define INT2_vect _VECTOR(3) 5036 #define INT2_vect_num 3 5039 #define INT3_vect _VECTOR(4) 5040 #define INT3_vect_num 4 5043 #define INT4_vect _VECTOR(5) 5044 #define INT4_vect_num 5 5047 #define INT5_vect _VECTOR(6) 5048 #define INT5_vect_num 6 5051 #define INT6_vect _VECTOR(7) 5052 #define INT6_vect_num 7 5055 #define INT7_vect _VECTOR(8) 5056 #define INT7_vect_num 8 5059 #define PCINT0_vect _VECTOR(9) 5060 #define PCINT0_vect_num 9 5063 #define PCINT1_vect _VECTOR(10) 5064 #define PCINT1_vect_num 10 5067 #define PCINT2_vect _VECTOR(11) 5068 #define PCINT2_vect_num 11 5071 #define WDT_vect _VECTOR(12) 5072 #define WDT_vect_num 12 5075 #define TIMER2_COMPA_vect _VECTOR(13) 5076 #define TIMER2_COMPA_vect_num 13 5079 #define TIMER2_COMPB_vect _VECTOR(14) 5080 #define TIMER2_COMPB_vect_num 14 5083 #define TIMER2_OVF_vect _VECTOR(15) 5084 #define TIMER2_OVF_vect_num 15 5087 #define TIMER1_CAPT_vect _VECTOR(16) 5088 #define TIMER1_CAPT_vect_num 16 5091 #define TIMER1_COMPA_vect _VECTOR(17) 5092 #define TIMER1_COMPA_vect_num 17 5095 #define TIMER1_COMPB_vect _VECTOR(18) 5096 #define TIMER1_COMPB_vect_num 18 5099 #define TIMER1_COMPC_vect _VECTOR(19) 5100 #define TIMER1_COMPC_vect_num 19 5103 #define TIMER1_OVF_vect _VECTOR(20) 5104 #define TIMER1_OVF_vect_num 20 5107 #define TIMER0_COMPA_vect _VECTOR(21) 5108 #define TIMER0_COMPA_vect_num 21 5111 #define TIMER0_COMPB_vect _VECTOR(22) 5112 #define TIMER0_COMPB_vect_num 22 5115 #define TIMER0_OVF_vect _VECTOR(23) 5116 #define TIMER0_OVF_vect_num 23 5119 #define SPI_STC_vect _VECTOR(24) 5120 #define SPI_STC_vect_num 24 5123 #define USART0_RX_vect _VECTOR(25) 5124 #define USART0_RX_vect_num 25 5127 #define USART0_UDRE_vect _VECTOR(26) 5128 #define USART0_UDRE_vect_num 26 5131 #define USART0_TX_vect _VECTOR(27) 5132 #define USART0_TX_vect_num 27 5135 #define ANALOG_COMP_vect _VECTOR(28) 5136 #define ANALOG_COMP_vect_num 28 5139 #define ADC_vect _VECTOR(29) 5140 #define ADC_vect_num 29 5143 #define EE_READY_vect _VECTOR(30) 5144 #define EE_READY_vect_num 30 5147 #define TIMER3_CAPT_vect _VECTOR(31) 5148 #define TIMER3_CAPT_vect_num 31 5151 #define TIMER3_COMPA_vect _VECTOR(32) 5152 #define TIMER3_COMPA_vect_num 32 5155 #define TIMER3_COMPB_vect _VECTOR(33) 5156 #define TIMER3_COMPB_vect_num 33 5159 #define TIMER3_COMPC_vect _VECTOR(34) 5160 #define TIMER3_COMPC_vect_num 34 5163 #define TIMER3_OVF_vect _VECTOR(35) 5164 #define TIMER3_OVF_vect_num 35 5167 #define USART1_RX_vect _VECTOR(36) 5168 #define USART1_RX_vect_num 36 5171 #define USART1_UDRE_vect _VECTOR(37) 5172 #define USART1_UDRE_vect_num 37 5175 #define USART1_TX_vect _VECTOR(38) 5176 #define USART1_TX_vect_num 38 5179 #define TWI_vect _VECTOR(39) 5180 #define TWI_vect_num 39 5183 #define SPM_READY_vect _VECTOR(40) 5184 #define SPM_READY_vect_num 40 5187 #define TIMER4_CAPT_vect _VECTOR(41) 5188 #define TIMER4_CAPT_vect_num 41 5191 #define TIMER4_COMPA_vect _VECTOR(42) 5192 #define TIMER4_COMPA_vect_num 42 5195 #define TIMER4_COMPB_vect _VECTOR(43) 5196 #define TIMER4_COMPB_vect_num 43 5199 #define TIMER4_COMPC_vect _VECTOR(44) 5200 #define TIMER4_COMPC_vect_num 44 5203 #define TIMER4_OVF_vect _VECTOR(45) 5204 #define TIMER4_OVF_vect_num 45 5207 #define TIMER5_CAPT_vect _VECTOR(46) 5208 #define TIMER5_CAPT_vect_num 46 5211 #define TIMER5_COMPA_vect _VECTOR(47) 5212 #define TIMER5_COMPA_vect_num 47 5215 #define TIMER5_COMPB_vect _VECTOR(48) 5216 #define TIMER5_COMPB_vect_num 48 5219 #define TIMER5_COMPC_vect _VECTOR(49) 5220 #define TIMER5_COMPC_vect_num 49 5223 #define TIMER5_OVF_vect _VECTOR(50) 5224 #define TIMER5_OVF_vect_num 50 5227 #define USART2_RX_vect _VECTOR(51) 5228 #define USART2_RX_vect_num 51 5231 #define USART2_UDRE_vect _VECTOR(52) 5232 #define USART2_UDRE_vect_num 52 5235 #define USART2_TX_vect _VECTOR(53) 5236 #define USART2_TX_vect_num 53 5239 #define USART3_RX_vect _VECTOR(54) 5240 #define USART3_RX_vect_num 54 5243 #define USART3_UDRE_vect _VECTOR(55) 5244 #define USART3_UDRE_vect_num 55 5247 #define USART3_TX_vect _VECTOR(56) 5248 #define USART3_TX_vect_num 56 5251 #define TRX24_PLL_LOCK_vect _VECTOR(57) 5252 #define TRX24_PLL_LOCK_vect_num 57 5255 #define TRX24_PLL_UNLOCK_vect _VECTOR(58) 5256 #define TRX24_PLL_UNLOCK_vect_num 58 5259 #define TRX24_RX_START_vect _VECTOR(59) 5260 #define TRX24_RX_START_vect_num 59 5263 #define TRX24_RX_END_vect _VECTOR(60) 5264 #define TRX24_RX_END_vect_num 60 5267 #define TRX24_CCA_ED_DONE_vect _VECTOR(61) 5268 #define TRX24_CCA_ED_DONE_vect_num 61 5271 #define TRX24_XAH_AMI_vect _VECTOR(62) 5272 #define TRX24_XAH_AMI_vect_num 62 5275 #define TRX24_TX_END_vect _VECTOR(63) 5276 #define TRX24_TX_END_vect_num 63 5279 #define TRX24_AWAKE_vect _VECTOR(64) 5280 #define TRX24_AWAKE_vect_num 64 5283 #define SCNT_CMP1_vect _VECTOR(65) 5284 #define SCNT_CMP1_vect_num 65 5287 #define SCNT_CMP2_vect _VECTOR(66) 5288 #define SCNT_CMP2_vect_num 66 5291 #define SCNT_CMP3_vect _VECTOR(67) 5292 #define SCNT_CMP3_vect_num 67 5295 #define SCNT_OVFL_vect _VECTOR(68) 5296 #define SCNT_OVFL_vect_num 68 5299 #define SCNT_BACKOFF_vect _VECTOR(69) 5300 #define SCNT_BACKOFF_vect_num 69 5303 #define AES_READY_vect _VECTOR(70) 5304 #define AES_READY_vect_num 70 5307 #define BAT_LOW_vect _VECTOR(71) 5308 #define BAT_LOW_vect_num 71 5313 #define SPM_PAGESIZE (256) 5314 #define RAMSTART (0x200) 5315 #define RAMSIZE (0x4000) 5316 #define RAMEND (0x41FF) 5317 #define XRAMSTART (0x0000) 5318 #define XRAMSIZE (0x0000) 5319 #define XRAMEND RAMEND 5320 #define E2END (0xFFF) 5321 #define E2PAGESIZE (0x08) 5322 #define FLASHEND (0x1ffff) 5327 #define FUSE_MEMORY_SIZE 3 5330 #define FUSE_CKSEL0 ~_BV(0) 5331 #define FUSE_CKSEL1 ~_BV(1) 5332 #define FUSE_CKSEL2 ~_BV(2) 5333 #define FUSE_CKSEL3 ~_BV(3) 5334 #define FUSE_SUT0 ~_BV(4) 5335 #define FUSE_SUT1 ~_BV(5) 5336 #define FUSE_CKOUT ~_BV(6) 5337 #define FUSE_CKDIV8 ~_BV(7) 5338 #define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_SUT1 & FUSE_CKDIV8) 5341 #define FUSE_BOOTRST ~_BV(0) 5342 #define FUSE_BOOTSZ0 ~_BV(1) 5343 #define FUSE_BOOTSZ1 ~_BV(2) 5344 #define FUSE_EESAVE ~_BV(3) 5345 #define FUSE_WDTON ~_BV(4) 5346 #define FUSE_SPIEN ~_BV(5) 5347 #define FUSE_JTAGEN ~_BV(6) 5348 #define FUSE_OCDEN ~_BV(7) 5349 #define HFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_SPIEN & FUSE_JTAGEN) 5352 #define FUSE_BODLEVEL0 ~_BV(0) 5353 #define FUSE_BODLEVEL1 ~_BV(1) 5354 #define FUSE_BODLEVEL2 ~_BV(2) 5355 #define EFUSE_DEFAULT (0xFF) 5361 #define __BOOT_LOCK_BITS_0_EXIST 5362 #define __BOOT_LOCK_BITS_1_EXIST 5363 #define __LOCK_BITS_EXIST 5368 #define SIGNATURE_0 0x1E 5369 #define SIGNATURE_1 0xA7 5370 #define SIGNATURE_2 0x01 Definition: iom128rfa1.h:1074
Definition: iom128rfa1.h:1429
Definition: iom128rfa1.h:3664
Definition: iom128rfa1.h:514
Definition: iom128rfa1.h:1160
Definition: iom128rfa1.h:3598
Definition: iom128rfa1.h:1956
Definition: iom128rfa1.h:3078
Definition: iom128rfa1.h:4677
Definition: iom128rfa1.h:3174
Definition: iom128rfa1.h:2838
Definition: iom128rfa1.h:3270
Definition: iom128rfa1.h:1689
Definition: iom128rfa1.h:2057
Macros for Accessing AVR Special Function Registers.
Definition: iom128rfa1.h:1528
Definition: iom128rfa1.h:4529
Definition: iom128rfa1.h:1909
Definition: iom128rfa1.h:1129
Definition: iom128rfa1.h:4749
Definition: iom128rfa1.h:1835
Definition: iom128rfa1.h:4900
Definition: iom128rfa1.h:2251
Definition: iom128rfa1.h:3697
Definition: iom128rfa1.h:2742
Definition: iom128rfa1.h:1316
Definition: iom128rfa1.h:1189
Definition: iom128rfa1.h:3765
Definition: iom128rfa1.h:1341
Definition: iom128rfa1.h:946
Definition: iom128rfa1.h:2982
Definition: iom128rfa1.h:3535
Definition: iom128rfa1.h:2682
Definition: iom128rfa1.h:1361
Definition: iom128rfa1.h:4032
Definition: iom128rfa1.h:1632
Definition: iom128rfa1.h:465
Definition: iom128rfa1.h:2321
Definition: iom128rfa1.h:2421
Definition: iom128rfa1.h:3471
Definition: iom128rfa1.h:2910
Definition: iom128rfa1.h:1264
Definition: iom128rfa1.h:2010
Definition: iom128rfa1.h:3514
Definition: iom128rfa1.h:4444
Definition: iom128rfa1.h:2111
Definition: iom128rfa1.h:832
Definition: iom128rfa1.h:1105
Definition: iom128rfa1.h:2790
Definition: iom128rfa1.h:976
Definition: iom128rfa1.h:1578
Definition: iom128rfa1.h:4701
Definition: iom128rfa1.h:3294
Definition: iom128rfa1.h:715
Definition: iom128rfa1.h:3102
Definition: iom128rfa1.h:3198
Definition: iom128rfa1.h:3741
Definition: iom128rfa1.h:764
Definition: iom128rfa1.h:1718
Definition: iom128rfa1.h:4236
Definition: iom128rfa1.h:3369
Definition: iom128rfa1.h:4953
Definition: iom128rfa1.h:1501
Definition: iom128rfa1.h:1747
Definition: iom128rfa1.h:4557
Definition: iom128rfa1.h:1773
Definition: iom128rfa1.h:2700
Definition: iom128rfa1.h:4359
Definition: iom128rfa1.h:2483
Definition: iom128rfa1.h:1001
Definition: iom128rfa1.h:1292
Definition: iom128rfa1.h:1654
Definition: iom128rfa1.h:541
Definition: iom128rfa1.h:2183
Definition: iom128rfa1.h:3556
Definition: iom128rfa1.h:1388
Definition: iom128rfa1.h:2862
Definition: iom128rfa1.h:2390
Definition: iom128rfa1.h:1049
Definition: iom128rfa1.h:1023
Definition: iom128rfa1.h:3625
Definition: iom128rfa1.h:4974
Definition: iom128rfa1.h:1212
Definition: iom128rfa1.h:4390
Definition: iom128rfa1.h:2569
Definition: iom128rfa1.h:3952
Definition: iom128rfa1.h:4331
Definition: iom128rfa1.h:4629
Definition: iom128rfa1.h:856
Definition: iom128rfa1.h:4501
Definition: iom128rfa1.h:3054
Definition: iom128rfa1.h:4773
Definition: iom128rfa1.h:3150
Definition: iom128rfa1.h:669
Definition: iom128rfa1.h:4083
Definition: iom128rfa1.h:3246
Definition: iom128rfa1.h:4876
Definition: iom128rfa1.h:1551
Definition: iom128rfa1.h:739
Definition: iom128rfa1.h:3342
Definition: iom128rfa1.h:4111
Definition: iom128rfa1.h:4057
Definition: iom128rfa1.h:2158
Definition: iom128rfa1.h:3577
Definition: iom128rfa1.h:416
Definition: iom128rfa1.h:4301
Definition: iom128rfa1.h:4174
Definition: iom128rfa1.h:2538
Definition: iom128rfa1.h:3006
Definition: iom128rfa1.h:1479
Definition: iom128rfa1.h:4797
Definition: iom128rfa1.h:4581
Definition: iom128rfa1.h:3813
Definition: iom128rfa1.h:3396
Definition: iom128rfa1.h:4845
Definition: iom128rfa1.h:4205
Definition: iom128rfa1.h:2360
Definition: iom128rfa1.h:4653
Definition: iom128rfa1.h:2296
Definition: iom128rfa1.h:568
Definition: iom128rfa1.h:880
Definition: iom128rfa1.h:910
Definition: iom128rfa1.h:1882
Definition: iom128rfa1.h:2814
Definition: iom128rfa1.h:2718
Definition: iom128rfa1.h:4821
Definition: iom128rfa1.h:1804
Definition: iom128rfa1.h:4268
Definition: iom128rfa1.h:3492
Definition: iom128rfa1.h:3859
Definition: iom128rfa1.h:612
Definition: iom128rfa1.h:2934
Definition: iom128rfa1.h:1454
Definition: iom128rfa1.h:3443
Definition: iom128rfa1.h:2600
Definition: iom128rfa1.h:4605
Definition: iom128rfa1.h:2653
Definition: iom128rfa1.h:588
Definition: iom128rfa1.h:1983
Definition: iom128rfa1.h:1233
Definition: iom128rfa1.h:3644
Definition: iom128rfa1.h:2958
Definition: iom128rfa1.h:3983
Definition: iom128rfa1.h:3318
Definition: iom128rfa1.h:2084
Definition: iom128rfa1.h:3126
Definition: iom128rfa1.h:3222
Definition: iom128rfa1.h:636
Definition: iom128rfa1.h:4472
Definition: iom128rfa1.h:4928
Definition: iom128rfa1.h:4408
Definition: iom128rfa1.h:4725
Definition: iom128rfa1.h:4426
Definition: iom128rfa1.h:1605
Definition: iom128rfa1.h:4139
Definition: iom128rfa1.h:3881
Definition: iom128rfa1.h:3717
Definition: iom128rfa1.h:2766
Definition: iom128rfa1.h:1855
Definition: iom128rfa1.h:3030
Definition: iom128rfa1.h:438
Definition: iom128rfa1.h:2452
Definition: iom128rfa1.h:2886
