Input Devices for MicroWindows.
More...
file | mw_print.c |
| MicroWindows Print.
file | mw_uid.c |
| MicroWindows UIDThis module implements the input devices interface used by MicroWindows in an embedded system environment.
#define | MW_UID_REGISTER_DEVICE 0x4100 |
#define | MW_UID_UNREGISTER_DEVICE 0x4101 |
#define | MV_BUTTON_RIGHT 0x01 |
#define | MV_BUTTON_CENTER 0x02 |
#define | MV_BUTTON_LEFT 0x04 |
#define | MV_KEY_MODIFIER_SHIFT_DOWN 0x10 |
#define | MV_KEY_MODIFIER_ALT_DOWN 0x20 |
#define | MV_KEY_MODIFIER_CAPS_ON 0x04 |
#define | MV_KEY_MODIFIER_NUN_LOCK_ON 0x02 |
#define | MV_KEY_SCROLL_LOCK_ON 0x01 |
#define | MV_KEY_MODE_ASCII 0x01 |
#define | MV_KEY_MODE_SCANCODE 0x00 |
#define | MV_KDGKBMODE 0x4B44 /* gets current keyboard mode */ |
#define | MV_KDSKBMODE 0x4B45 /* sets current keyboard mode */ |
enum | MW_INPUT_DEVICE_TYPE {
MV_UID_INVALID = 0,
MV_UID_REL_POS = 1,
MV_UID_ABS_POS = 2,
MV_UID_KBD = 3,
MV_UID_TIMER = 4
This file defines the interface for input devices used by MicroWindows in an embedded system environment.
◆ uid_close_queue()
int uid_close_queue |
void |
This method closes the message queue and deletes it.
- Return values
This | method returns 0 on success and -1 on error. |
◆ uid_open_queue()
int uid_open_queue |
const char * |
q_name, |
int |
flags, |
size_t |
max_msgs |
This method creates the message queue that holds events from the input devices.
- Parameters
[in] | q_name | is the name of the message queue |
[in] | flags | controls the behaviour of the queue |
[in] | max_msgs | specifies the maximum number of pending messages |
- Note
- The message queue is from the Classic API.
- Return values
◆ uid_print_message()
This methods prints the specified UID message using printk.
- Parameters
[in] | uid | points to the message to print |
◆ uid_print_message_with_plugin()
This methods prints the specified UID message using your fprintf style method of choice.
- Parameters
[in] | context | is a pointer to a data area which may be used by some print handlers |
[in] | handler | is the fprintf style method to invoke |
◆ uid_read_message()
int uid_read_message |
struct MW_UID_MESSAGE * |
m, |
unsigned long |
timeout |
This method reads a message from the queue.
It waits up to the specified timeout in miliseconds. A timeout of 0 is a poll.
- Parameters
[in] | m | will be filled in with the received message |
[in] | timeout | is the maximum number of mulliseconds to wait |
- Return values
◆ uid_send_message()
This methods writes a message to the queue.
- Parameters
[in] | m | is the message to send |
- Return values
