rtems-4.11.3
libnetworking
arpa
ftp.h
1
2
* Copyright (c) 1983, 1989, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 3. All advertising materials mentioning features or use of this software
14
* must display the following acknowledgement:
15
* This product includes software developed by the University of
16
* California, Berkeley and its contributors.
17
* 4. Neither the name of the University nor the names of its contributors
18
* may be used to endorse or promote products derived from this software
19
* without specific prior written permission.
20
21
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
22
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
25
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
26
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
27
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
28
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
29
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
30
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
31
* SUCH DAMAGE.
32
33
* @(#)ftp.h 8.1 (Berkeley) 6/2/93
34
35
36
#ifndef _ARPA_FTP_H_
37
#define _ARPA_FTP_H_
38
39
/* Definitions for FTP; see RFC-765. */
40
41
42
* Reply codes.
43
44
#define PRELIM 1
/* positive preliminary */
45
#define COMPLETE 2
/* positive completion */
46
#define CONTINUE 3
/* positive intermediate */
47
#define TRANSIENT 4
/* transient negative completion */
48
#define ERROR 5
/* permanent negative completion */
49
50
51
* Type codes
52
53
#define TYPE_A 1
/* ASCII */
54
#define TYPE_E 2
/* EBCDIC */
55
#define TYPE_I 3
/* image */
56
#define TYPE_L 4
/* local byte size */
57
58
#ifdef FTP_NAMES
59
char
*typenames[] = {
"0"
"ASCII"
"EBCDIC"
"Image"
"Local"
60
#endif
61
62
63
* Form codes
64
65
#define FORM_N 1
/* non-print */
66
#define FORM_T 2
/* telnet format effectors */
67
#define FORM_C 3
/* carriage control (ASA) */
68
#ifdef FTP_NAMES
69
char
*formnames[] = {
"0"
"Nonprint"
"Telnet"
"Carriage-control"
70
#endif
71
72
73
* Structure codes
74
75
#define STRU_F 1
/* file (no record structure) */
76
#define STRU_R 2
/* record structure */
77
#define STRU_P 3
/* page structure */
78
#ifdef FTP_NAMES
79
char
*strunames[] = {
"0"
"File"
"Record"
"Page"
80
#endif
81
82
83
* Mode types
84
85
#define MODE_S 1
/* stream */
86
#define MODE_B 2
/* block */
87
#define MODE_C 3
/* compressed */
88
#ifdef FTP_NAMES
89
char
*modenames[] = {
"0"
"Stream"
"Block"
"Compressed"
90
#endif
91
92
93
* Record Tokens
94
95
#define REC_ESC '\377'
/* Record-mode Escape */
96
#define REC_EOR '\001'
/* Record-mode End-of-Record */
97
#define REC_EOF '\002'
/* Record-mode End-of-File */
98
99
100
* Block Header
101
102
#define BLK_EOR 0x80
/* Block is End-of-Record */
103
#define BLK_EOF 0x40
/* Block is End-of-File */
104
#define BLK_ERRORS 0x20
/* Block is suspected of containing errors */
105
#define BLK_RESTART 0x10
/* Block is Restart Marker */
106
107
#define BLK_BYTECOUNT 2
/* Bytes in this block */
108
109
#endif
/* !_FTP_H_ */
