| #define | PRELIM 1 /* positive preliminary */ |
| #define | COMPLETE 2 /* positive completion */ |
| #define | CONTINUE 3 /* positive intermediate */ |
| #define | TRANSIENT 4 /* transient negative completion */ |
| #define | ERROR 5 /* permanent negative completion */ |
| #define | TYPE_A 1 /* ASCII */ |
| #define | TYPE_E 2 /* EBCDIC */ |
| #define | TYPE_I 3 /* image */ |
| #define | TYPE_L 4 /* local byte size */ |
| #define | FORM_N 1 /* non-print */ |
| #define | FORM_T 2 /* telnet format effectors */ |
| #define | FORM_C 3 /* carriage control (ASA) */ |
| #define | STRU_F 1 /* file (no record structure) */ |
| #define | STRU_R 2 /* record structure */ |
| #define | STRU_P 3 /* page structure */ |
| #define | MODE_S 1 /* stream */ |
| #define | MODE_B 2 /* block */ |
| #define | MODE_C 3 /* compressed */ |
| #define | REC_ESC '\377' /* Record-mode Escape */ |
| #define | REC_EOR '\001' /* Record-mode End-of-Record */ |
| #define | REC_EOF '\002' /* Record-mode End-of-File */ |
| #define | BLK_EOR 0x80 /* Block is End-of-Record */ |
| #define | BLK_EOF 0x40 /* Block is End-of-File */ |
| #define | BLK_ERRORS 0x20 /* Block is suspected of containing errors */ |
| #define | BLK_RESTART 0x10 /* Block is Restart Marker */ |
| #define | BLK_BYTECOUNT 2 /* Bytes in this block */ |
