Inlined Routines from the POSIX Timer Manager. More...
| #define | POSIX_TIMER_STATE_FREE 0x01 |
| Timer is free. | |
| #define | POSIX_TIMER_STATE_CREATE_NEW 0x02 |
| Created timer but not running. | |
| #define | POSIX_TIMER_STATE_CREATE_RUN 0x03 |
| Created timer and running. | |
| #define | POSIX_TIMER_STATE_CREATE_STOP 0x04 |
| Created, ran and stopped timer. | |
| #define | POSIX_TIMER_RELATIVE 0 |
| Indicates that the fire time is relative to the current one. | |
| void | _POSIX_Timer_Manager_initialization (void) |
| POSIX Timer Manager Initialization. More... | |
| void | _POSIX_Timer_TSR (Objects_Id timer, void *data) |
| POSIX Timer Manager Timer Service Routine Helper. More... | |
| bool | _POSIX_Timer_Insert_helper (Watchdog_Control *timer, Watchdog_Interval ticks, Objects_Id id, Watchdog_Service_routine_entry TSR, void *arg) |
| POSIX Timer Watchdog Insertion Helper. | |
| RTEMS_INLINE_ROUTINE POSIX_Timer_Control * | _POSIX_Timer_Allocate (void) |
| POSIX Timer Allocate. More... | |
| RTEMS_INLINE_ROUTINE void | _POSIX_Timer_Free (POSIX_Timer_Control *the_timer) |
| POSIX Timer Free. More... | |
| RTEMS_INLINE_ROUTINE POSIX_Timer_Control * | _POSIX_Timer_Get (timer_t id, Objects_Locations *location) |
| POSIX Timer Get. More... | |
| POSIX_EXTERN Objects_Information | _POSIX_Timer_Information |
| The following defines the information control block used to manage this class of objects. | |
This file contains the static inline implementation of the inlined routines from the POSIX Timer Manager.
| RTEMS_INLINE_ROUTINE POSIX_Timer_Control* _POSIX_Timer_Allocate | ( | void | ) |
This function allocates a timer control block from the inactive chain of free timer control blocks.
References _Objects_Allocate().
| RTEMS_INLINE_ROUTINE void _POSIX_Timer_Free | ( | POSIX_Timer_Control * | the_timer | ) |
POSIX Timer Free.
This routine frees a timer control block to the inactive chain of free timer control blocks.
References _Objects_Free().
| RTEMS_INLINE_ROUTINE POSIX_Timer_Control* _POSIX_Timer_Get | ( | timer_t | id, |
| Objects_Locations * | location | ||
POSIX Timer Get.
This function maps timer IDs to timer control blocks. If ID corresponds to a local timer, then it returns the timer control pointer which maps to ID and location is set to OBJECTS_LOCAL. Otherwise, location is set to OBJECTS_ERROR and the returned value is undefined.
References _Objects_Get().
Referenced by timer_delete(), and timer_getoverrun().
| void _POSIX_Timer_TSR | ( | Objects_Id | timer, |
| void * | data | ||
This is the operation that is run when a timer expires.
References _POSIX_Timer_Insert_helper(), and Objects_Control::id.
