Files | |
| file | timercreate.c |
| Create a Per-Process Timer. | |
| file | timergetoverrun.c |
| Get Overrun Count for a POSIX Per-Process Timer. | |
| void | _POSIX_Timer_Manager_initialization (void) |
| POSIX Timer Manager Initialization. More... | |
| int | timer_create (clockid_t clock_id, struct sigevent *evp, timer_t *timerid) |
| int | timer_delete (timer_t timerid) |
| Delete a Per-Process Timer. | |
| int | timer_settime (timer_t timerid, int flags, const struct itimerspec *value, struct itimerspec *ovalue) |
| Set a Per-Process Timer. | |
| int | timer_gettime (timer_t timerid, struct itimerspec *value) |
| int | timer_getoverrun (timer_t timerid) |
| Get overrun count for a Per-Process Timer. More... | |
| void _POSIX_Timer_Manager_initialization | ( | void | ) |
This routine performs the initialization necessary for this manager.
| int timer_getoverrun | ( | timer_t | timerid | ) |
The expiration of a timer must increase by one a counter. After the signal handler associated to the timer finishes its execution, _POSIX_Timer_TSR will have to set this counter to 0.
References _POSIX_Timer_Get().
