This handler encapsulates functionality related to the scheduling of watchdog functions to be called at specific times in the future. More...
Files | |
| file | watchdog.c |
| Watchdog Handler Initialization. | |
| file | watchdogadjust.c |
| Watchdog Adjust. | |
| file | watchdoginsert.c |
| Watchdog Insert. | |
| file | watchdogremove.c |
| Remove Watchdog from List. | |
| file | watchdogtickssinceboot.c |
| Watchdog Ticks Since Boot. | |
| struct | Watchdog_Control |
| The control block used to manage each watchdog timer. More... | |
| struct | Watchdog_Iterator |
| Iterator item to synchronize concurrent insert, remove and tickle operations. More... | |
| struct | Watchdog_Header |
| Watchdog header. More... | |
| #define | WATCHDOG_NO_TIMEOUT 0 |
| The constant for indefinite wait. More... | |
| #define | WATCHDOG_INITIALIZER(routine, id, user_data) |
| Watchdog initializer for static initialization. More... | |
Typedefs | |
| typedef uint32_t | Watchdog_Interval |
| Type is used to specify the length of intervals. More... | |
| typedef void | Watchdog_Service_routine |
| Return type from a Watchdog Service Routine. More... | |
| typedef Watchdog_Service_routine(* | Watchdog_Service_routine_entry) (Objects_Id, void *) |
| Pointer to a watchdog service routine. More... | |
Enumerations | |
| enum | Watchdog_States { WATCHDOG_INACTIVE, WATCHDOG_BEING_INSERTED, WATCHDOG_ACTIVE } |
| Set of the states which a watchdog timer may be at any given time. More... | |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Acquire (Watchdog_Header *header, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Release (Watchdog_Header *header, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Flash (Watchdog_Header *header, ISR_lock_Context *lock_context) |
| void | _Watchdog_Handler_initialization (void) |
| Initialize the watchdog handler. More... | |
| void | _Watchdog_Tick (void) |
| Triggers a watchdog tick. More... | |
| Watchdog_States | _Watchdog_Remove (Watchdog_Header *header, Watchdog_Control *the_watchdog) |
| Removes the_watchdog from the watchdog chain. More... | |
| void | _Watchdog_Adjust_backward (Watchdog_Header *header, Watchdog_Interval units) |
| Adjusts the header watchdog chain in the backward direction for units ticks. More... | |
| void | _Watchdog_Adjust_backward_locked (Watchdog_Header *header, Watchdog_Interval units) |
| Adjusts the watchdogs in backward direction in a locked context. More... | |
| void | _Watchdog_Adjust_forward (Watchdog_Header *header, Watchdog_Interval units) |
| Adjusts the header watchdog chain in the forward direction for units ticks. More... | |
| void | _Watchdog_Adjust_forward_locked (Watchdog_Header *header, Watchdog_Interval units, ISR_lock_Context *lock_context) |
| Adjusts the watchdogs in forward direction in a locked context. More... | |
| void | _Watchdog_Insert (Watchdog_Header *header, Watchdog_Control *the_watchdog) |
| Inserts the_watchdog into the header watchdog chain for a time of units. More... | |
| void | _Watchdog_Insert_locked (Watchdog_Header *header, Watchdog_Control *the_watchdog, ISR_lock_Context *lock_context) |
| Inserts the watchdog in a locked context. More... | |
| void | _Watchdog_Tickle (Watchdog_Header *header) |
| This routine is invoked at appropriate intervals to update the header watchdog chain. More... | |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Preinitialize (Watchdog_Control *the_watchdog) |
| Pre-initializes a watchdog. More... | |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Initialize (Watchdog_Control *the_watchdog, Watchdog_Service_routine_entry routine, Objects_Id id, void *user_data) |
| This routine initializes the specified watchdog. More... | |
| RTEMS_INLINE_ROUTINE bool | _Watchdog_Is_active (Watchdog_Control *the_watchdog) |
| This routine returns true if the watchdog timer is in the ACTIVE state, and false otherwise. | |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Activate (Watchdog_Control *the_watchdog) |
| This routine activates THE_WATCHDOG timer which is already on a watchdog chain. | |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Tickle_ticks (void) |
| This routine is invoked at each clock tick to update the ticks watchdog chain. | |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Tickle_seconds (void) |
| This routine is invoked at each clock tick to update the seconds watchdog chain. | |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Insert_ticks (Watchdog_Control *the_watchdog, Watchdog_Interval units) |
| This routine inserts THE_WATCHDOG into the ticks watchdog chain for a time of UNITS ticks. More... | |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Insert_seconds (Watchdog_Control *the_watchdog, Watchdog_Interval units) |
| This routine inserts THE_WATCHDOG into the seconds watchdog chain for a time of UNITS seconds. More... | |
| RTEMS_INLINE_ROUTINE Watchdog_States | _Watchdog_Remove_ticks (Watchdog_Control *the_watchdog) |
| RTEMS_INLINE_ROUTINE Watchdog_States | _Watchdog_Remove_seconds (Watchdog_Control *the_watchdog) |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Reset_ticks (Watchdog_Control *the_watchdog) |
| This routine resets THE_WATCHDOG timer to its state at INSERT time. More... | |
| RTEMS_INLINE_ROUTINE Watchdog_Control * | _Watchdog_Next (Watchdog_Control *the_watchdog) |
| This routine returns a pointer to the watchdog timer following THE_WATCHDOG on the watchdog chain. | |
| RTEMS_INLINE_ROUTINE Watchdog_Control * | _Watchdog_Previous (Watchdog_Control *the_watchdog) |
| This routine returns a pointer to the watchdog timer preceding THE_WATCHDOG on the watchdog chain. | |
| RTEMS_INLINE_ROUTINE Watchdog_Control * | _Watchdog_First (Watchdog_Header *header) |
| This routine returns a pointer to the first watchdog timer on the watchdog chain HEADER. | |
| RTEMS_INLINE_ROUTINE Watchdog_Control * | _Watchdog_Last (Watchdog_Header *header) |
| This routine returns a pointer to the last watchdog timer on the watchdog chain HEADER. | |
| RTEMS_INLINE_ROUTINE bool | _Watchdog_Is_empty (const Watchdog_Header *header) |
| RTEMS_INLINE_ROUTINE void | _Watchdog_Header_initialize (Watchdog_Header *header) |
| volatile Watchdog_Interval | _Watchdog_Ticks_since_boot |
| The watchdog ticks counter. More... | |
| SCORE_EXTERN Watchdog_Header | _Watchdog_Ticks_header |
| Watchdog chain which is managed at ticks. More... | |
| SCORE_EXTERN Watchdog_Header | _Watchdog_Seconds_header |
| Watchdog chain which is managed at second boundaries. More... | |
| #define WATCHDOG_INITIALIZER | ( | routine, | |
| id, | |||
| user_data | |||
| #define WATCHDOG_NO_TIMEOUT 0 |
This is the constant for indefinite wait. It is actually an illegal interval.
Referenced by _MPCI_Receive_server(), and pthread_mutex_trylock().
| typedef uint32_t Watchdog_Interval |
This type is used to specify the length of intervals.
| typedef void Watchdog_Service_routine |
This type defines the return type from a Watchdog Service Routine.
| typedef Watchdog_Service_routine( * Watchdog_Service_routine_entry) (Objects_Id, void *) |
This type define a pointer to a watchdog service routine.
| enum Watchdog_States |
This enumerated type is the set of the states in which a watchdog timer may be at any given time.
| void _Watchdog_Adjust_backward | ( | Watchdog_Header * | header, |
| Watchdog_Interval | units | ||
| [in] | header | The watchdog chain. |
| [in] | units | The units of ticks to adjust. |
| void _Watchdog_Adjust_backward_locked | ( | Watchdog_Header * | header, |
The caller must be the owner of the watchdog lock and will be the owner after the call.
| [in] | header | The watchdog header. |
| void _Watchdog_Adjust_forward | ( | Watchdog_Header * | header, |
This may lead to several _Watchdog_Tickle() invocations.
| void _Watchdog_Adjust_forward_locked | ( | Watchdog_Header * | header, |
| Watchdog_Interval | units, | ||
| ISR_lock_Context * | lock_context | ||
The caller must be the owner of the watchdog lock and will be the owner after the call. This function may release and acquire the watchdog lock internally.
| [in] | lock_context | The lock context. |
| void _Watchdog_Handler_initialization | ( | void | ) |
This routine initializes the watchdog handler. The watchdog synchronization flag is initialized and the watchdog chains are initialized and emptied.
References _Watchdog_Ticks_since_boot.
| RTEMS_INLINE_ROUTINE void _Watchdog_Initialize | ( | Watchdog_Control * | the_watchdog, |
| Watchdog_Service_routine_entry | routine, | ||
| Objects_Id | id, | ||
| void * | user_data | ||
The watchdog is made inactive, the watchdog id and handler routine are set to the specified values.
References _Assert, Watchdog_Control::id, Watchdog_Control::routine, Watchdog_Control::state, Watchdog_Control::user_data, and WATCHDOG_INACTIVE.
| void _Watchdog_Insert | ( | Watchdog_Header * | header, |
| Watchdog_Control * | the_watchdog | ||
This routine inserts the_watchdog into the header watchdog chain for a time of units. Update the delta interval counters.
| [in] | header | is the_watchdog list to insert the_watchdog on |
| [in] | the_watchdog | is the watchdog to insert |
Referenced by _Watchdog_Insert_seconds(), and _Watchdog_Insert_ticks().
| void _Watchdog_Insert_locked | ( | Watchdog_Header * | header, |
| Watchdog_Control * | the_watchdog, | ||
| [in] | the_watchdog | The watchdog. |
References Watchdog_Control::state, and WATCHDOG_INACTIVE.
| RTEMS_INLINE_ROUTINE void _Watchdog_Insert_seconds | ( | Watchdog_Control * | the_watchdog, |
The INSERT_MODE indicates whether THE_WATCHDOG is to be activated automatically or later, explicitly by the caller.
References _Watchdog_Insert(), _Watchdog_Seconds_header, Watchdog_Control::initial, and RTEMS_INLINE_ROUTINE.
| RTEMS_INLINE_ROUTINE void _Watchdog_Insert_ticks | ( | Watchdog_Control * | the_watchdog, |
References _Watchdog_Insert(), _Watchdog_Ticks_header, and Watchdog_Control::initial.
| RTEMS_INLINE_ROUTINE void _Watchdog_Preinitialize | ( | Watchdog_Control * | the_watchdog | ) |
This routine must be called before a watchdog is used in any way. The exception are statically initialized watchdogs via WATCHDOG_INITIALIZER().
| [in] | the_watchdog | The uninitialized watchdog. |
References Watchdog_Control::id, Watchdog_Control::routine, Watchdog_Control::state, Watchdog_Control::user_data, and WATCHDOG_INACTIVE.
Referenced by rtems_rate_monotonic_create(), and rtems_timer_create().
| Watchdog_States _Watchdog_Remove | ( | Watchdog_Header * | header, |
This routine removes the_watchdog from the watchdog chain on which it resides and returns the state the_watchdog timer was in.
| [in] | the_watchdog | will be removed |
| the | state in which the_watchdog was in when removed |
| RTEMS_INLINE_ROUTINE void _Watchdog_Reset_ticks | ( | Watchdog_Control * | the_watchdog | ) |
This routine is valid only on interval watchdog timers and is used to make an interval watchdog timer fire "every" so many ticks.
| void _Watchdog_Tick | ( | void | ) |
This routine executes TOD, watchdog and scheduler ticks.
References _Scheduler_Tick(), _Thread_Dispatch(), _Thread_Dispatch_is_enabled(), _TOD_Tickle_ticks(), and _Watchdog_Tickle_ticks().
| void _Watchdog_Tickle | ( | Watchdog_Header * | header | ) |
This routine is invoked at appropriate intervals to update the header watchdog chain. This routine decrements the delta counter in response to a tick.
| [in] | header | is the watchdog chain to tickle |
Referenced by _Watchdog_Tickle_seconds(), and _Watchdog_Tickle_ticks().
| SCORE_EXTERN Watchdog_Header _Watchdog_Seconds_header |
This is the watchdog chain which is managed at second boundaries.
Referenced by _Watchdog_Insert_seconds(), and _Watchdog_Tickle_seconds().
| SCORE_EXTERN Watchdog_Header _Watchdog_Ticks_header |
This is the watchdog chain which is managed at ticks.
Referenced by _Watchdog_Insert_ticks(), and _Watchdog_Tickle_ticks().
| volatile Watchdog_Interval _Watchdog_Ticks_since_boot |
With a 1ms watchdog tick, this counter overflows after 50 days since boot.
Referenced by _Scheduler_EDF_Priority_compare(), _Scheduler_EDF_Release_job(), _TOD_Tickle_ticks(), _Watchdog_Handler_initialization(), rtems_clock_get_ticks_since_boot(), and rtems_clock_tick_later().
