RTEMS File Systems Block RoutinesThese functions manage blocks in the RFS file system. More...
#include <inttypes.h>
#include <rtems/rfs/rtems-rfs-block.h>
#include <rtems/rfs/rtems-rfs-data.h>
#include <rtems/rfs/rtems-rfs-group.h>
#include <rtems/rfs/rtems-rfs-inode.h>
Include dependency graph for rtems-rfs-block.c:
void rtems_rfs_block_get_bpos (rtems_rfs_file_system *fs, rtems_rfs_pos pos, rtems_rfs_block_pos *bpos)
 Given a position compute the block number and block offset. More...
rtems_rfs_pos rtems_rfs_block_get_pos (rtems_rfs_file_system *fs, rtems_rfs_block_pos *bpos)
 Given a block position compute the absolute offset. More...
void rtems_rfs_block_get_block_size (rtems_rfs_file_system *fs, rtems_rfs_pos pos, rtems_rfs_block_size *size)
 Set the size given a position. More...
rtems_rfs_pos rtems_rfs_block_get_size (rtems_rfs_file_system *fs, rtems_rfs_block_size *size)
 Calculate the position given the number of blocks and the offset. More...
int rtems_rfs_block_map_open (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *inode, rtems_rfs_block_map *map)
 Open a block map. More...
int rtems_rfs_block_map_close (rtems_rfs_file_system *fs, rtems_rfs_block_map *map)
 Close the map. More...
int rtems_rfs_block_map_find (rtems_rfs_file_system *fs, rtems_rfs_block_map *map, rtems_rfs_block_pos *bpos, rtems_rfs_block_no *block)
 Find a block number in the map from the position provided. More...
int rtems_rfs_block_map_seek (rtems_rfs_file_system *fs, rtems_rfs_block_map *map, rtems_rfs_pos_rel offset, rtems_rfs_block_no *block)
 Seek around the map. More...
int rtems_rfs_block_map_next_block (rtems_rfs_file_system *fs, rtems_rfs_block_map *map, rtems_rfs_block_no *block)
 Seek to the next block. More...
int rtems_rfs_block_map_grow (rtems_rfs_file_system *fs, rtems_rfs_block_map *map, size_t blocks, rtems_rfs_block_no *new_block)
 Grow the block map by the specified number of blocks. More...
int rtems_rfs_block_map_shrink (rtems_rfs_file_system *fs, rtems_rfs_block_map *map, size_t blocks)
int rtems_rfs_block_map_free_all (rtems_rfs_file_system *fs, rtems_rfs_block_map *map)
 Free all blocks in the map. More...
A block is an area of the media and its size is set for a each specific media. The block size is set when the file system is set up and needs to be matched for it to be read correctly.
Blocks are managed as groups. A block group or "group" is part of the total number of blocks being managed by the file system and exist to allow resources to localised. A file in a directory will be allocated blocks in the same group as the directory, and the blocks for the file will also be allocated in the same group.
A group consist of a block bitmap, inodes and data blocks. The first block of the file system will hold the superblock. The block bitmap is a collection of blocks that hold a map of bits, one bit per block for each block in the group. When a file system is mounted the block bitmaps are read and a summary bit map is made. The summary bitmap has a single bit for 32 bits in the bitmap and is set when all 32 bits it maps to are set. This speeds up the search for a free block by a factor of 32.
◆ rtems_rfs_block_get_block_size()
void rtems_rfs_block_get_block_size ( rtems_rfs_file_system fs,
rtems_rfs_pos  pos,
rtems_rfs_block_size size
Parameters
[in]fsis the file system data.
[in]posis the position as an absolute offset from the start.
[out]sizeis a pointer to the block size to fill in.
◆ rtems_rfs_block_get_bpos()
void rtems_rfs_block_get_bpos ( rtems_rfs_file_system fs,
rtems_rfs_pos  pos,
rtems_rfs_block_pos bpos
Parameters
[out]bposis a pointer to the block position to fill in.
◆ rtems_rfs_block_get_pos()
rtems_rfs_pos rtems_rfs_block_get_pos ( rtems_rfs_file_system fs,
Parameters
Return values
offsetThe absolute offset.
◆ rtems_rfs_block_get_size()
rtems_rfs_pos rtems_rfs_block_get_size ( rtems_rfs_file_system fs,
If the block count is 0 the size is 0. If the block is greater than 0 and the offset is 0 the size is number of blocks multipled by the block size and if the offset is not 0 it is the offset into the last block. For example if blocks is 1 and offset is 0 the size is the block size. If the block count is 1 and size is 100 the size is 100.
Parameters
[in]sizeThe size in blocks and offset.
Return values
sizeThe size in bytes.
◆ rtems_rfs_block_map_close()
int rtems_rfs_block_map_close ( rtems_rfs_file_system fs,
rtems_rfs_block_map map
Close the map.
The buffer handles are closed and any help buffers are released.
Parameters
[in]mapis a pointer to the map that is opened.
Return values
0Successful operation.
error_codeAn error occurred.
◆ rtems_rfs_block_map_find()
int rtems_rfs_block_map_find ( rtems_rfs_file_system fs,
rtems_rfs_block_map map,
rtems_rfs_block_pos bpos,
rtems_rfs_buffer_block block
Parameters
[in]mapis a pointer to the map to search.
[in]bposis a pointer to the block position to find.
[out]blockwill contain the block in when found.
Return values
◆ rtems_rfs_block_map_free_all()
int rtems_rfs_block_map_free_all ( rtems_rfs_file_system fs,
Parameters
[in]mapis a pointer to the open map to free all blocks from.
Return values
References rtems_rfs_block_size_s::count, rtems_rfs_block_map_shrink(), and rtems_rfs_block_map_s::size.
◆ rtems_rfs_block_map_grow()
int rtems_rfs_block_map_grow ( rtems_rfs_file_system fs,
size_t  blocks,
rtems_rfs_block_no new_block
Parameters
[in]mapis a pointer to the open map to grow.
[in]blocksis the number of blocks to grow the map by.
[out]new_blockwill contain first of the blocks allocated to the map.
Return values
References rtems_rfs_trace().
◆ rtems_rfs_block_map_next_block()
int rtems_rfs_block_map_next_block ( rtems_rfs_file_system fs,
Parameters
Return values
ENXIOFailed to seek because it is outside the block map.
◆ rtems_rfs_block_map_open()
int rtems_rfs_block_map_open ( rtems_rfs_file_system fs,
rtems_rfs_inode_handle inode,
Open a block map.
The block map data in the inode is copied into the map. The buffer handles are opened. The block position is set to the start so a seek of offset 0 will return the first block.
Parameters
[in]inodeis a pointer to the inode the map belongs to.
Return values
◆ rtems_rfs_block_map_seek()
int rtems_rfs_block_map_seek ( rtems_rfs_file_system fs,
Parameters
[in]offsetis the distance to seek. It is signed.
Return values
◆ rtems_rfs_block_map_shrink()
int rtems_rfs_block_map_shrink ( rtems_rfs_file_system fs,
size_t  blocks
Parameters
[in]mapis a pointer to the open map to shrink.
[in]blocksis the number of blocks to shrink the map by. If more than the number of blocks the map is emptied.
Return values
Referenced by rtems_rfs_block_map_free_all().
