Inlined Routines in the Priority Handler Bit Map Implementation. More...
| #define | _Bitfield_Find_first_bit(_value, _bit_number) _CPU_Bitfield_Find_first_bit( _value, _bit_number ) |
| Gets the _bit_number of the first bit set in the specified value. More... | |
| #define | _Priority_Mask(_bit_number) _CPU_Priority_Mask( _bit_number ) |
| This method returns the priority bit mask for the specified major or minor bit number. More... | |
| #define | _Priority_Bits_index(_priority) _CPU_Priority_bits_index( _priority ) |
| This method returns the bit index position for the specified priority. More... | |
| RTEMS_INLINE_ROUTINE Priority_bit_map_Word | _Priority_Major (Priority_Control the_priority) |
| This function returns the major portion of the_priority. | |
| RTEMS_INLINE_ROUTINE Priority_bit_map_Word | _Priority_Minor (Priority_Control the_priority) |
| This function returns the minor portion of the_priority. | |
| RTEMS_INLINE_ROUTINE Priority_bit_map_Word | _Priority_Mask (uint32_t bit_number) |
| This function returns the mask associated with the major or minor number passed to it. | |
| RTEMS_INLINE_ROUTINE Priority_bit_map_Word | _Priority_Mask_invert (uint32_t mask) |
| This function returns the mask bit inverted. | |
| RTEMS_INLINE_ROUTINE uint32_t | _Priority_Bits_index (uint32_t bit_number) |
| This function translates the bit numbers returned by the bit scan of a priority bit field into something suitable for use as a major or minor component of a priority. | |
| RTEMS_INLINE_ROUTINE void | _Priority_bit_map_Initialize (Priority_bit_map_Control *bit_map) |
| RTEMS_INLINE_ROUTINE void | _Priority_bit_map_Add (Priority_bit_map_Control *bit_map, Priority_bit_map_Information *bit_map_info) |
| Priority Queue implemented by bit map. | |
| RTEMS_INLINE_ROUTINE void | _Priority_bit_map_Remove (Priority_bit_map_Control *bit_map, Priority_bit_map_Information *bit_map_info) |
| RTEMS_INLINE_ROUTINE Priority_Control | _Priority_bit_map_Get_highest (const Priority_bit_map_Control *bit_map) |
| RTEMS_INLINE_ROUTINE bool | _Priority_bit_map_Is_empty (const Priority_bit_map_Control *bit_map) |
| RTEMS_INLINE_ROUTINE void | _Priority_bit_map_Initialize_information (Priority_bit_map_Control *bit_map, Priority_bit_map_Information *bit_map_info, Priority_Control new_priority) |
| const unsigned char | __log2table [256] |
| This table is used by the generic bitfield routines to perform a highly optimized bit scan without the use of special CPU instructions. | |
This file contains the static inline implementation of all inlined routines in the Priority Handler bit map implementation
