nvdisk.h File Reference
Non-volatile Disk Block Device Implementation. More...
#include <stdint.h>
#include <sys/ioctl.h>
Include dependency graph for nvdisk.h:
struct  rtems_nvdisk_monitor_data
 NV Disk Monitoring Data allows a user to obtain the current status of the disk. More...
struct  rtems_nvdisk_driver_handlers
 NV Low Level driver handlers. More...
struct  rtems_nvdisk_device_desc
 NV Device Descriptor holds the description of a device that is part of the NV disk. More...
struct  rtems_nvdisk_config
 RTEMS Non-Volatile Disk configuration table used to initialise the driver. More...
#define RTEMS_NVDISK_DEVICE_BASE_NAME   "/dev/nvd"
 The Non-volatile disk provides a simple directly mapped disk driver with checksums for each. More...
#define RTEMS_NVDISK_IOCTL_ERASE_DISK   _IO('B', 128)
 NV disk specific ioctl request types. More...
#define RTEMS_NVDISK_IOCTL_MONITORING   _IO('B', 129)
#define RTEMS_NVDISK_IOCTL_INFO_LEVEL   _IO('B', 130)
#define RTEMS_NVDISK_IOCTL_PRINT_STATUS   _IO('B', 131)
#define RTEMS_NVDISK_KBYTES(_k)   ((_k) * 1024)
 Return the number of kilo-bytes.
#define RTEMS_NVDISK_CHECK_PAGES   (1 << 0)
 Check the pages during initialisation to see which pages are valid and which are not. More...
typedef struct rtems_nvdisk_monitor_data rtems_nvdisk_monitor_data
typedef struct rtems_nvdisk_driver_handlers rtems_nvdisk_driver_handlers
typedef struct rtems_nvdisk_device_desc rtems_nvdisk_device_desc
typedef struct rtems_nvdisk_config rtems_nvdisk_config
rtems_device_driver rtems_nvdisk_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Non-volatile disk device driver initialization. More...
const rtems_nvdisk_config rtems_nvdisk_configuration []
 External reference to the configuration. More...
uint32_t rtems_nvdisk_configuration_size
 External reference to the number of configurations. More...
◆ RTEMS_NVDISK_CHECK_PAGES
This could slow down initialising the disk driver.
◆ RTEMS_NVDISK_DEVICE_BASE_NAME
It is designed to provied a disk that can survive a restart. Examples are EEPROM devices which have byte writeable locations, or a battery backed up RAM disk.
The low level driver provides the physical access to the hardware. The base name of the nv disks.
◆ RTEMS_NVDISK_IOCTL_ERASE_DISK
To use open the device and issue the ioctl call.
int fd = open ("/dev/nvdisk0", O_WRONLY, 0);
if (fd < 0)
printf ("driver open failed: %s\n", strerror (errno));
exit (1);
if (ioctl (fd, RTEMS_NVDISK_IOCTL_ERASE_DISK) < 0)
printf ("driver erase failed: %s\n", strerror (errno));
exit (1);
close (fd);
Typedef Documentation
◆ rtems_nvdisk_device_desc
Typically this structure is part of a table of the device which is referenced in the nvdisk configuration table. The reference is kept in the driver and used all the time to manage the nv device, therefore it must always exist.
◆ rtems_nvdisk_driver_handlers
Typically this structure is part of a table of handlers in the device which is referenced in the nvdisk configuration table. The reference is kept in the driver and used all the time to manage the nv device, therefore it must always exist.
◆ rtems_nvdisk_initialize()
rtems_device_driver rtems_nvdisk_initialize ( rtems_device_major_number  major,
void *  arg
Place in a table as the initialisation entry and remainder of the entries are the RTEMS block device generic handlers.
Parameters
majorNV disk major device number.
minorMinor device number, not applicable.
argInitialization argument, not applicable.
Returns
The rtems_device_driver is actually just rtems_status_code.
Todo:
Memory clean up on error is really badly handled.
Parameters
Variable Documentation
◆ rtems_nvdisk_configuration
const rtems_nvdisk_config rtems_nvdisk_configuration[]
Please supply. Support is present in confdefs.h for providing this variable.
◆ rtems_nvdisk_configuration_size
