Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
libio.h File Reference
Basic IO API. More...
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/ioctl.h>
#include <sys/statvfs.h>
#include <sys/uio.h>
#include <unistd.h>
#include <termios.h>
#include <rtems/fs.h>
#include <rtems/chain.h>
Include dependency graph for libio.h:
struct  rtems_filesystem_eval_path_context_t
 Path evaluation context. More...
struct  _rtems_filesystem_operations_table
 File system operations table. More...
struct  _rtems_filesystem_file_handlers_r
 File system node operations table. More...
struct  rtems_filesystem_limits_and_options_t
 Contain file system specific information which is required to support fpathconf(). More...
struct  rtems_libio_tt
 An open file data structure. More...
struct  rtems_libio_rw_args_t
 Paramameter block for read/write. More...
struct  rtems_libio_open_close_args_t
 Parameter block for open/close. More...
struct  rtems_libio_ioctl_args_t
 Parameter block for ioctl. More...
union  __rtems_dev_t
struct  rtems_filesystem_mount_table_entry_tt
 Mount table entry. More...
struct  rtems_filesystem_table_t
 File system table entry. More...
struct  rtems_filesystem_mount_configuration
struct  rtems_termios_callbacks
#define rtems_filesystem_split_dev_t(_dev, _major, _minor)
#define rtems_filesystem_pathconf(_mte)   ((_mte)->pathconf_limits_and_options)
 The pathconf setting for a file system.
#define rtems_filesystem_type(_mte)   ((_mte)->type)
 The type of file system. More...
#define rtems_filesystem_mount_point(_mte)   ((_mte)->target)
 The mount point of a file system.
#define rtems_filesystem_mount_device(_mte)   ((_mte)->dev)
 The device entry of a file system.
Flag Values
#define LIBIO_FLAGS_NO_DELAY   0x0001U /* return immediately if no data */
#define LIBIO_FLAGS_READ   0x0002U /* reading */
#define LIBIO_FLAGS_WRITE   0x0004U /* writing */
#define LIBIO_FLAGS_OPEN   0x0100U /* device is open */
#define LIBIO_FLAGS_APPEND   0x0200U /* all writes append */
#define LIBIO_FLAGS_CREATE   0x0400U /* create file */
#define LIBIO_FLAGS_CLOSE_ON_EXEC   0x0800U /* close on process exec() */
#define LIBIO_FLAGS_READ_WRITE   (LIBIO_FLAGS_READ | LIBIO_FLAGS_WRITE)
Permission Macros
#define RTEMS_FS_PERMS_READ   0x4
#define RTEMS_FS_PERMS_WRITE   0x2
#define RTEMS_FS_PERMS_EXEC   0x1
#define RTEMS_FS_PERMS_RWX   (RTEMS_FS_PERMS_READ | RTEMS_FS_PERMS_WRITE | RTEMS_FS_PERMS_EXEC)
#define RTEMS_FS_FOLLOW_HARD_LINK   0x8
#define RTEMS_FS_FOLLOW_SYM_LINK   0x10
#define RTEMS_FS_FOLLOW_LINK   (RTEMS_FS_FOLLOW_HARD_LINK | RTEMS_FS_FOLLOW_SYM_LINK)
#define RTEMS_FS_MAKE   0x20
#define RTEMS_FS_EXCLUSIVE   0x40
#define RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS   0x80
#define RTEMS_FS_REJECT_TERMINAL_DOT   0x100
File System Types
#define RTEMS_FILESYSTEM_TYPE_IMFS   "imfs"
#define RTEMS_FILESYSTEM_TYPE_MINIIMFS   "mimfs"
#define RTEMS_FILESYSTEM_TYPE_DEVFS   "devfs"
#define RTEMS_FILESYSTEM_TYPE_FTPFS   "ftpfs"
#define RTEMS_FILESYSTEM_TYPE_TFTPFS   "tftpfs"
#define RTEMS_FILESYSTEM_TYPE_NFS   "nfs"
#define RTEMS_FILESYSTEM_TYPE_DOSFS   "dosfs"
#define RTEMS_FILESYSTEM_TYPE_RFS   "rfs"
#define RTEMS_FILESYSTEM_TYPE_JFFS2   "jffs2"
typedef void(* rtems_filesystem_mt_entry_lock_t) (const rtems_filesystem_mount_table_entry_t *mt_entry)
 Locks a file system instance. More...
typedef void(* rtems_filesystem_mt_entry_unlock_t) (const rtems_filesystem_mount_table_entry_t *mt_entry)
 Unlocks a file system instance. More...
typedef void(* rtems_filesystem_eval_path_t) (rtems_filesystem_eval_path_context_t *ctx)
 Path evaluation. More...
typedef int(* rtems_filesystem_link_t) (const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
 Creates a new link for the existing file. More...
typedef int(* rtems_filesystem_fchmod_t) (const rtems_filesystem_location_info_t *loc, mode_t mode)
 Changes the mode of a node. More...
typedef int(* rtems_filesystem_chown_t) (const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
 Changes owner and group of a node. More...
typedef int(* rtems_filesystem_clonenode_t) (rtems_filesystem_location_info_t *loc)
 Clones a location. More...
typedef void(* rtems_filesystem_freenode_t) (const rtems_filesystem_location_info_t *loc)
 Frees the location of a node. More...
typedef int(* rtems_filesystem_mount_t) (rtems_filesystem_mount_table_entry_t *mt_entry)
 Mounts a file system instance in a mount point (directory). More...
typedef int(* rtems_filesystem_fsmount_me_t) (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
 Initializes a file system instance. More...
typedef int(* rtems_filesystem_unmount_t) (rtems_filesystem_mount_table_entry_t *mt_entry)
 Unmounts a file system instance in a mount point (directory). More...
typedef void(* rtems_filesystem_fsunmount_me_t) (rtems_filesystem_mount_table_entry_t *mt_entry)
 Destroys a file system instance. More...
typedef bool(* rtems_filesystem_are_nodes_equal_t) (const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
 Tests if the node of one location is equal to the node of the other location. More...
typedef int(* rtems_filesystem_mknod_t) (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
 Creates a new node. More...
typedef int(* rtems_filesystem_rmnod_t) (const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
 Removes a node. More...
typedef int(* rtems_filesystem_utime_t) (const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
 Set node access and modification times. More...
typedef int(* rtems_filesystem_symlink_t) (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
 Makes a symbolic link to a node. More...
typedef ssize_t(* rtems_filesystem_readlink_t) (const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
 Reads the contents of a symbolic link. More...
typedef int(* rtems_filesystem_rename_t) (const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
 Renames a node. More...
typedef int(* rtems_filesystem_statvfs_t) (const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
 Gets file system information. More...
typedef int(* rtems_filesystem_open_t) (rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
 Opens a node. More...
typedef int(* rtems_filesystem_close_t) (rtems_libio_t *iop)
 Closes a node. More...
typedef ssize_t(* rtems_filesystem_read_t) (rtems_libio_t *iop, void *buffer, size_t count)
 Reads from a node. More...
typedef ssize_t(* rtems_filesystem_readv_t) (rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
 Reads an IO vector from a node. More...
typedef ssize_t(* rtems_filesystem_write_t) (rtems_libio_t *iop, const void *buffer, size_t count)
 Writes to a node. More...
typedef ssize_t(* rtems_filesystem_writev_t) (rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
 Writes an IO vector to a node. More...
typedef int(* rtems_filesystem_ioctl_t) (rtems_libio_t *iop, ioctl_command_t request, void *buffer)
 IO control of a node. More...
typedef off_t(* rtems_filesystem_lseek_t) (rtems_libio_t *iop, off_t offset, int whence)
 Moves the read/write file offset. More...
typedef int(* rtems_filesystem_fstat_t) (const rtems_filesystem_location_info_t *loc, struct stat *buf)
 Gets a node status. More...
typedef int(* rtems_filesystem_ftruncate_t) (rtems_libio_t *iop, off_t length)
 Truncates a file to a specified length. More...
typedef int(* rtems_filesystem_fsync_t) (rtems_libio_t *iop)
 Synchronizes changes to a file. More...
typedef int(* rtems_filesystem_fdatasync_t) (rtems_libio_t *iop)
 Synchronizes the data of a file. More...
typedef int(* rtems_filesystem_fcntl_t) (rtems_libio_t *iop, int cmd)
 File control. More...
typedef int(* rtems_filesystem_poll_t) (rtems_libio_t *iop, int events)
 Poll and select support. More...
typedef int(* rtems_filesystem_kqfilter_t) (rtems_libio_t *iop, struct knote *kn)
 Kernel event filter support. More...
typedef off_t rtems_off64_t
typedef void(* rtems_libio_helper) (void)
typedef struct rtems_filesystem_table_t rtems_filesystem_table_t
typedef bool(* rtems_per_filesystem_routine) (const rtems_filesystem_table_t *fs_entry, void *arg)
 Per file system type routine. More...
typedef bool(* rtems_filesystem_mt_entry_visitor) (const rtems_filesystem_mount_table_entry_t *mt_entry, void *arg)
 Mount table entry visitor. More...
typedef struct rtems_termios_callbacks rtems_termios_callbacks
External I/O Handlers
typedef int(* rtems_libio_open_t) (const char *pathname, uint32_t flag, uint32_t mode)
typedef int(* rtems_libio_close_t) (int fd)
typedef ssize_t(* rtems_libio_read_t) (int fd, void *buffer, size_t count)
typedef ssize_t(* rtems_libio_write_t) (int fd, const void *buffer, size_t count)
typedef int(* rtems_libio_ioctl_t) (int fd, uint32_t command, void *buffer)
typedef off_t(* rtems_libio_lseek_t) (int fd, off_t offset, int whence)
enum  rtems_filesystem_options_t { RTEMS_FILESYSTEM_READ_ONLY, RTEMS_FILESYSTEM_READ_WRITE, RTEMS_FILESYSTEM_BAD_OPTIONS }
 File system options.
void rtems_filesystem_default_lock (const rtems_filesystem_mount_table_entry_t *mt_entry)
 Obtains the IO library mutex. More...
void rtems_filesystem_default_unlock (const rtems_filesystem_mount_table_entry_t *mt_entry)
 Releases the IO library mutex. More...
void rtems_filesystem_default_eval_path (rtems_filesystem_eval_path_context_t *ctx)
 Terminates the path evaluation and replaces the current location with the null location. More...
int rtems_filesystem_default_link (const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
bool rtems_filesystem_default_are_nodes_equal (const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
 Tests if the node access pointer of one location is equal to the node access pointer of the other location. More...
int rtems_filesystem_default_mknod (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
int rtems_filesystem_default_rmnod (const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
int rtems_filesystem_default_fchmod (const rtems_filesystem_location_info_t *loc, mode_t mode)
int rtems_filesystem_default_chown (const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
int rtems_filesystem_default_clonenode (rtems_filesystem_location_info_t *loc)
void rtems_filesystem_default_freenode (const rtems_filesystem_location_info_t *loc)
int rtems_filesystem_default_mount (rtems_filesystem_mount_table_entry_t *mt_entry)
int rtems_filesystem_default_unmount (rtems_filesystem_mount_table_entry_t *mt_entry)
void rtems_filesystem_default_fsunmount (rtems_filesystem_mount_table_entry_t *mt_entry)
int rtems_filesystem_default_utime (const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
int rtems_filesystem_default_symlink (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
ssize_t rtems_filesystem_default_readlink (const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
int rtems_filesystem_default_rename (const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
int rtems_filesystem_default_statvfs (const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
int rtems_filesystem_default_open (rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
int rtems_filesystem_default_close (rtems_libio_t *iop)
ssize_t rtems_filesystem_default_read (rtems_libio_t *iop, void *buffer, size_t count)
ssize_t rtems_filesystem_default_readv (rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
 Calls the read handler for each IO vector entry. More...
ssize_t rtems_filesystem_default_write (rtems_libio_t *iop, const void *buffer, size_t count)
ssize_t rtems_filesystem_default_writev (rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
 Calls the write handler for each IO vector entry. More...
int rtems_filesystem_default_ioctl (rtems_libio_t *iop, ioctl_command_t request, void *buffer)
off_t rtems_filesystem_default_lseek (rtems_libio_t *iop, off_t offset, int whence)
off_t rtems_filesystem_default_lseek_directory (rtems_libio_t *iop, off_t offset, int whence)
 An offset 0 with a whence of SEEK_SET will perform a directory rewind operation. More...
off_t rtems_filesystem_default_lseek_file (rtems_libio_t *iop, off_t offset, int whence)
 Default lseek() handler for files. More...
int rtems_filesystem_default_fstat (const rtems_filesystem_location_info_t *loc, struct stat *buf)
 Sets the mode to S_IRWXU | S_IRWXG | S_IRWXO. More...
int rtems_filesystem_default_ftruncate (rtems_libio_t *iop, off_t length)
int rtems_filesystem_default_ftruncate_directory (rtems_libio_t *iop, off_t length)
int rtems_filesystem_default_fsync_or_fdatasync (rtems_libio_t *iop)
int rtems_filesystem_default_fsync_or_fdatasync_success (rtems_libio_t *iop)
int rtems_filesystem_default_fcntl (rtems_libio_t *iop, int cmd)
int rtems_filesystem_default_poll (rtems_libio_t *iop, int events)
 Default poll handler. More...
int rtems_filesystem_default_kqfilter (rtems_libio_t *iop, struct knote *kn)
 Default kernel event filter handler. More...
rtems_filesystem_fsmount_me_t rtems_filesystem_get_mount_handler (const char *type)
 Gets the mount handler for the file system type. More...
void rtems_libio_init (void)
 RTEMS LibIO Initialization. More...
void rtems_filesystem_initialize (void)
 Base File System Initialization. More...
void rtems_libio_helper_null (void)
void rtems_libio_post_driver (void)
void rtems_libio_exit (void)
int rtems_mkdir (const char *path, mode_t mode)
 Creates a directory and all its parent directories according to path. More...
int rtems_filesystem_register (const char *type, rtems_filesystem_fsmount_me_t mount_h)
 Registers a file system type. More...
int rtems_filesystem_unregister (const char *type)
 Unregisters a file system type. More...
int unmount (const char *mount_path)
 Unmounts the file system instance at the specified mount path. More...
int mount (const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
 Mounts a file system instance at the specified target path. More...
int mount_and_make_target_path (const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
 Mounts a file system and makes the target path. More...
bool rtems_filesystem_iterate (rtems_per_filesystem_routine routine, void *routine_arg)
 Iterates over all file system types. More...
bool rtems_filesystem_mount_iterate (rtems_filesystem_mt_entry_visitor visitor, void *visitor_arg)
 Iterates over all file system mount entries. More...
void rtems_termios_initialize (void)
rtems_status_code rtems_termios_bufsize (size_t cbufsize, size_t raw_input, size_t raw_output)
rtems_status_code rtems_termios_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg, const rtems_termios_callbacks *callbacks)
rtems_status_code rtems_termios_close (void *arg)
rtems_status_code rtems_termios_read (void *arg)
rtems_status_code rtems_termios_write (void *arg)
rtems_status_code rtems_termios_ioctl (void *arg)
int rtems_termios_enqueue_raw_characters (void *ttyp, const char *buf, int len)
int rtems_termios_dequeue_characters (void *ttyp, int len)
const rtems_filesystem_operations_table rtems_filesystem_operations_default
 File system operations table with default operations.
const rtems_filesystem_file_handlers_r rtems_filesystem_handlers_default
 File system node handler table with default node handlers.
const rtems_filesystem_limits_and_options_t rtems_filesystem_default_pathconf
 Default pathconf settings. More...
const rtems_libio_helper rtems_libio_init_helper
const rtems_libio_helper rtems_libio_post_driver_helper
const rtems_libio_helper rtems_libio_exit_helper
const rtems_libio_helper rtems_fs_init_helper
const rtems_filesystem_table_t rtems_filesystem_table []
 Static table of file systems. More...
rtems_chain_control rtems_filesystem_mount_table
const rtems_filesystem_mount_configuration rtems_filesystem_root_configuration
Basic IO API.
This file contains the support infrastructure used to manage the table of integer style file descriptors used by the low level POSIX system calls like open(), read, fstat(), etc.
◆ rtems_filesystem_type
#define rtems_filesystem_type (   _mte)    ((_mte)->type)
Its name.
