Private Inlined Routines for POSIX Key's. More...
#include <rtems/posix/key.h>
#include <rtems/score/freechain.h>
#define | POSIX_KEYS_RBTREE_NODE_TO_KEY_VALUE_PAIR(node) RTEMS_CONTAINER_OF( node, POSIX_Keys_Key_value_pair, Key_value_lookup_node ) |
void | _POSIX_Key_Manager_initialization (void) |
POSIX key manager initialization. More... | |
RBTree_Compare_result | _POSIX_Keys_Key_value_compare (const RBTree_Node *node1, const RBTree_Node *node2) |
POSIX keys Red-Black tree node comparison. More... | |
void | _POSIX_Keys_Run_destructors (Thread_Control *thread) |
Create thread-specific data POSIX key. More... | |
void | _POSIX_Keys_Free_memory (POSIX_Keys_Control *the_key) |
Free a POSIX key table memory. More... | |
RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Free (POSIX_Keys_Control *the_key) |
Free a POSIX keys control block. More... | |
RTEMS_INLINE_ROUTINE POSIX_Keys_Control * | _POSIX_Keys_Allocate (void) |
Allocate a keys control block. More... | |
RTEMS_INLINE_ROUTINE POSIX_Keys_Control * | _POSIX_Keys_Get (pthread_key_t id, Objects_Locations *location) |
Get a keys control block. More... | |
POSIX_Keys_Key_value_pair * | _POSIX_Keys_Key_value_pair_allocate (void) |
RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Key_value_pair_free (POSIX_Keys_Key_value_pair *key_value_pair) |
RTEMS_INLINE_ROUTINE RBTree_Node * | _POSIX_Keys_Find (pthread_key_t key, Thread_Control *thread) |
RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Free_key_value_pair (POSIX_Keys_Key_value_pair *key_value_pair) |
POSIX_EXTERN Objects_Information | _POSIX_Keys_Information |
The information control block used to manage this class of objects. | |
RBTree_Control | _POSIX_Keys_Key_value_lookup_tree |
The rbtree control block used to manage all key values. | |
POSIX_EXTERN Freechain_Control | _POSIX_Keys_Keypool |
This freechain is used as a memory pool for POSIX_Keys_Key_value_pair. | |
This include file contains the static inline implementation of the private inlined routines for POSIX key's.
