Data Structures | Typedefs | Enumerations | Functions | Variables
interr.h File Reference
Constants and Prototypes Related to the Internal Error Handler. More...
#include <stdbool.h>
#include <stdint.h>
Include dependency graph for interr.h:
struct  Internal_errors_Information
 This type holds the fatal error information. More...
typedef CPU_Uint32ptr Internal_errors_t
enum  Internal_errors_Source {
  INTERNAL_ERROR_CORE, INTERNAL_ERROR_RTEMS_API, INTERNAL_ERROR_POSIX_API, RTEMS_FATAL_SOURCE_BDBUF,
  RTEMS_FATAL_SOURCE_APPLICATION, RTEMS_FATAL_SOURCE_EXIT, RTEMS_FATAL_SOURCE_BSP, RTEMS_FATAL_SOURCE_ASSERT,
  RTEMS_FATAL_SOURCE_STACK_CHECKER, RTEMS_FATAL_SOURCE_EXCEPTION, RTEMS_FATAL_SOURCE_SMP, RTEMS_FATAL_SOURCE_LAST = 0xffffffff
 This type lists the possible sources from which an error can be reported. More...
enum  Internal_errors_Core_list {
  INTERNAL_ERROR_NO_CONFIGURATION_TABLE, INTERNAL_ERROR_NO_CPU_TABLE, INTERNAL_ERROR_TOO_LITTLE_WORKSPACE, INTERNAL_ERROR_WORKSPACE_ALLOCATION,
  INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL, INTERNAL_ERROR_THREAD_EXITTED, INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION, INTERNAL_ERROR_INVALID_NODE,
  INTERNAL_ERROR_NO_MPCI, INTERNAL_ERROR_BAD_PACKET, INTERNAL_ERROR_OUT_OF_PACKETS, INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS,
  INTERNAL_ERROR_OUT_OF_PROXIES, INTERNAL_ERROR_INVALID_GLOBAL_ID, INTERNAL_ERROR_BAD_STACK_HOOK, INTERNAL_ERROR_BAD_ATTRIBUTES,
  INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY, OBSOLETE_INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL, INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE, INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0,
  OBSOLETE_INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP, INTERNAL_ERROR_GXX_KEY_ADD_FAILED, INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED, INTERNAL_ERROR_NO_MEMORY_FOR_HEAP,
  INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR, INTERNAL_ERROR_RESOURCE_IN_USE
 A list of errors which are generated internally by the executive core.
void _Terminate (Internal_errors_Source the_source, bool is_internal, Internal_errors_t the_error)
 Initiates system termination. More...
Internal_errors_Information _Internal_errors_What_happened
 When a fatal error occurs, the error information is stored here.
This include file contains constants and prototypes related to the Internal Error Handler.
