This is an extension of the Deterministic Priority SMP Scheduler. More...
Files | |
| file | schedulerpriorityaffinitysmp.h |
| Deterministic Priority Affinity SMP Scheduler API. | |
| file | schedulerpriorityaffinitysmp.c |
| Deterministic Priority Affinity SMP Scheduler Implementation. | |
| struct | Scheduler_priority_affinity_SMP_Node |
| Scheduler node specialization for Deterministic Priority Affinity SMP schedulers. More... | |
| #define | SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS |
| Entry points for the Deterministic Priority Affinity SMP Scheduler. More... | |
| void | _Scheduler_priority_affinity_SMP_Node_initialize (const Scheduler_Control *scheduler, Thread_Control *thread) |
| Initializes per thread scheduler information. More... | |
| void | _Scheduler_priority_affinity_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread) |
| SMP Priority Affinity Scheduler Block Operation. More... | |
| Thread_Control * | _Scheduler_priority_affinity_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread) |
| SMP Priority Affinity Scheduler Unblock Operation. More... | |
| bool | _Scheduler_priority_affinity_SMP_Get_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, size_t cpusetsize, cpu_set_t *cpuset) |
| Get affinity for the priority affinity SMP scheduler. More... | |
| Thread_Control * | _Scheduler_priority_affinity_SMP_Change_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Control new_priority, bool prepend_it) |
| Change priority for the priority affinity SMP scheduler. More... | |
| Thread_Control * | _Scheduler_priority_affinity_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *offers_help, Thread_Control *needs_help) |
| bool | _Scheduler_priority_affinity_SMP_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, size_t cpusetsize, const cpu_set_t *cpuset) |
| Set affinity for the priority affinity SMP scheduler. More... | |
which is an implementation of the global fixed priority scheduler (G-FP). It adds thread to core affinity support.
| #define SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS |
| void _Scheduler_priority_affinity_SMP_Block | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | thread | ||
This method is the block operation for this scheduler.
| [in] | scheduler | is the scheduler instance information |
| [in] | thread | is the thread to block |
| Thread_Control* _Scheduler_priority_affinity_SMP_Change_priority | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread, | ||
| Priority_Control | new_priority, | ||
| bool | prepend_it | ||
| [in] | scheduler | The scheduler of the thread. |
| [in] | the_thread | The associated thread. |
| [in] | new_priority | The new priority for the thread. |
| [in] | prepend_it | Append or prepend the thread to its priority FIFO. |
| bool _Scheduler_priority_affinity_SMP_Get_affinity | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | thread, | ||
| size_t | cpusetsize, | ||
| cpu_set_t * | cpuset | ||
| [in] | thread | The associated thread. |
| [in] | cpusetsize | The size of the cpuset. |
| [in,out] | cpuset | The associated affinity set. |
| 0 | Successfully got cpuset |
| -1 | The cpusetsize is invalid for the system |
| void _Scheduler_priority_affinity_SMP_Node_initialize | ( | const Scheduler_Control * | scheduler, |
This routine allocates thread->scheduler.
| [in] | scheduler | points to the scheduler specific information. |
| [in] | thread | is the thread the scheduler is allocating management memory for. |
| bool _Scheduler_priority_affinity_SMP_Set_affinity | ( | const Scheduler_Control * | scheduler, |
| const cpu_set_t * | cpuset | ||
| [in] | cpuset | Affinity new affinity set. |
| true | if successful |
| false | if unsuccessful |
| Thread_Control* _Scheduler_priority_affinity_SMP_Unblock | ( | const Scheduler_Control * | scheduler, |
This method is the unblock operation for this scheduler.
| [in] | thread | is the thread to unblock |
