Files | |
file | partimpl.h |
Classic Partition Manager Implementation. | |
#define | RTEMS_PART_EXTERN extern |
This constant is defined to extern most of the time when using this header file. More... | |
void | _Partition_Manager_initialization (void) |
Partition Manager Initialization. More... | |
RTEMS_INLINE_ROUTINE void * | _Partition_Allocate_buffer (Partition_Control *the_partition) |
Allocate a buffer from the_partition. More... | |
RTEMS_INLINE_ROUTINE void | _Partition_Free_buffer (Partition_Control *the_partition, Chain_Node *the_buffer) |
Frees the_buffer to the_partition. More... | |
RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_on_boundary (void *the_buffer, Partition_Control *the_partition) |
Checks whether is on a valid buffer boundary for the_partition. More... | |
RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_valid (Chain_Node *the_buffer, Partition_Control *the_partition) |
Checks whether the_buffer is a valid buffer from the_partition. More... | |
RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_size_aligned (uint32_t buffer_size) |
Checks if partition is buffer size aligned. More... | |
RTEMS_INLINE_ROUTINE Partition_Control * | _Partition_Allocate (void) |
Allocates a partition control block from the inactive chain of free partition control blocks. More... | |
RTEMS_INLINE_ROUTINE void | _Partition_Free (Partition_Control *the_partition) |
Frees a partition control block to the inactive chain of free partition control blocks. More... | |
RTEMS_INLINE_ROUTINE Partition_Control * | _Partition_Get (Objects_Id id, Objects_Locations *location) |
Maps partition IDs to partition control blocks. More... | |
RTEMS_PART_EXTERN Objects_Information | _Partition_Information |
The following defines the information control block used to manage this class of objects. | |
#define RTEMS_PART_EXTERN extern |
However by defining it to nothing, the data declared in this header file can be instantiated. This is done in a single per manager file.
Partition Manager – Instantiate Data
RTEMS_INLINE_ROUTINE Partition_Control* _Partition_Allocate | ( | void | ) |
This function allocates a partition control block from the inactive chain of free partition control blocks.
References _Objects_Allocate().
RTEMS_INLINE_ROUTINE void* _Partition_Allocate_buffer | ( | Partition_Control * | the_partition | ) |
This function attempts to allocate a buffer from the_partition. If successful, it returns the address of the allocated buffer. Otherwise, it returns NULL.
References _Chain_Get(), and Partition_Control::Memory.
RTEMS_INLINE_ROUTINE void _Partition_Free | ( | Partition_Control * | the_partition | ) |
This routine frees a partition control block to the inactive chain of free partition control blocks.
References _Objects_Free(), and Partition_Control::Object.
RTEMS_INLINE_ROUTINE void _Partition_Free_buffer | ( | Partition_Control * | the_partition, |
Chain_Node * | the_buffer | ||
This routine frees the_buffer to the_partition.
References _Chain_Append(), and Partition_Control::Memory.
RTEMS_INLINE_ROUTINE Partition_Control* _Partition_Get | ( | Objects_Id | id, |
Objects_Locations * | location | ||
This function maps partition IDs to partition control blocks. If ID corresponds to a local partition, then it returns the_partition control pointer which maps to ID and location is set to OBJECTS_LOCAL. If the partition ID is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_partition is undefined. Otherwise, location is set to OBJECTS_ERROR and the_partition is undefined.
References _Objects_Get().
Referenced by rtems_partition_delete().
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_on_boundary | ( | void * | the_buffer, |
Partition_Control * | the_partition | ||
This function returns TRUE if the_buffer is on a valid buffer boundary for the_partition, and FALSE otherwise.
References _Addresses_Subtract(), Partition_Control::buffer_size, and Partition_Control::starting_address.
Referenced by _Partition_Is_buffer_valid().
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_size_aligned | ( | uint32_t | buffer_size | ) |
This function returns TRUE if the use of the specified buffer_size will result in the allocation of buffers whose first byte is properly aligned, and FALSE otherwise.
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_valid | ( | Chain_Node * | the_buffer, |
This function returns TRUE if the_buffer is a valid buffer from the_partition, otherwise FALSE is returned.
References _Addresses_Add_offset(), _Addresses_Is_in_range(), _Partition_Is_buffer_on_boundary(), Partition_Control::length, and Partition_Control::starting_address.
void _Partition_Manager_initialization | ( | void | ) |
This routine performs the initialization necessary for this manager.
References _Objects_Initialize_information(), and _Partition_Information.
