RTEMS C User's Guide
_Internal_errors_What_happened
confdefs.h
CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
CONFIGURE_APPLICATION_EXTRA_DRIVERS
CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
CONFIGURE_BSP_PREREQUISITE_DRIVERS
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
CONFIGURE_EXECUTIVE_RAM_WORK_AREA
CONFIGURE_EXTRA_TASK_STACKS
CONFIGURE_GNAT_RTEMS
CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
CONFIGURE_HAS_OWN_INIT_TASK_TABLE
CONFIGURE_HAS_OWN_MOUNT_TABLE
CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
CONFIGURE_IDLE_TASK_BODY
CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
CONFIGURE_IDLE_TASK_STACK_SIZE
CONFIGURE_INIT_TASK_ARGUMENTS
CONFIGURE_INIT_TASK_ATTRIBUTES
CONFIGURE_INIT_TASK_ENTRY_POINT
CONFIGURE_INIT_TASK_INITIAL_MODES
CONFIGURE_INIT_TASK_NAME
CONFIGURE_INIT_TASK_PRIORITY
CONFIGURE_INIT_TASK_STACK_SIZE
CONFIGURE_INTERRUPT_STACK_SIZE
CONFIGURE_ITRON_HAS_OWN_INIT_TASK_TABLE
CONFIGURE_ITRON_INIT_TASK_ATTRIBUTES
CONFIGURE_ITRON_INIT_TASK_ENTRY_POINT
CONFIGURE_ITRON_INIT_TASK_PRIORITY
CONFIGURE_ITRON_INIT_TASK_STACK_SIZE
CONFIGURE_ITRON_INIT_TASK_TABLE
CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
CONFIGURE_MALLOC_STATISTICS
CONFIGURE_MAXIMUM_ADA_TASKS
CONFIGURE_MAXIMUM_DEVICES
CONFIGURE_MAXIMUM_DRIVERS
CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
CONFIGURE_MAXIMUM_ITRON_EVENTFLAGS
CONFIGURE_MAXIMUM_ITRON_FIXED_MEMORY_POOLS
CONFIGURE_MAXIMUM_ITRON_MAILBOXES
CONFIGURE_MAXIMUM_ITRON_MEMORY_POOLS
CONFIGURE_MAXIMUM_ITRON_MESSAGE_BUFFERS
CONFIGURE_MAXIMUM_ITRON_PORTS
CONFIGURE_MAXIMUM_ITRON_SEMAPHORES
CONFIGURE_MAXIMUM_ITRON_TASKS
CONFIGURE_MAXIMUM_MESSAGE_QUEUES
CONFIGURE_MAXIMUM_PARTITIONS
CONFIGURE_MAXIMUM_PERIODS
CONFIGURE_MAXIMUM_PORTS
CONFIGURE_MAXIMUM_POSIX_BARRIERS
CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
CONFIGURE_MAXIMUM_POSIX_KEYS
CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
CONFIGURE_MAXIMUM_POSIX_MUTEXES
CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
CONFIGURE_MAXIMUM_POSIX_RWLOCKS
CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
CONFIGURE_MAXIMUM_POSIX_THREADS
CONFIGURE_MAXIMUM_POSIX_TIMERS
CONFIGURE_MAXIMUM_PRIORITY
CONFIGURE_MAXIMUM_REGIONS
CONFIGURE_MAXIMUM_SEMAPHORES
CONFIGURE_MAXIMUM_TASKS
CONFIGURE_MAXIMUM_TIMERS
CONFIGURE_MAXIMUM_USER_EXTENSIONS
CONFIGURE_MEMORY_OVERHEAD
CONFIGURE_MESSAGE_BUFFER_MEMORY
CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
CONFIGURE_MICROSECONDS_PER_TICK
CONFIGURE_MINIMUM_TASK_STACK_SIZE
CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
CONFIGURE_MP_MAXIMUM_NODES
CONFIGURE_MP_MAXIMUM_PROXIES
CONFIGURE_MP_MPCI_TABLE_POINTER
CONFIGURE_MP_NODE_NUMBER
CONFIGURE_NUMBER_OF_TERMIOS_PORTS
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
CONFIGURE_POSIX_INIT_THREAD_TABLE
CONFIGURE_RTEMS_INIT_TASKS_TABLE
CONFIGURE_STACK_CHECKER_ENABLED
CONFIGURE_TASK_STACK_ALLOCATOR
CONFIGURE_TASK_STACK_DEALLOCATOR
CONFIGURE_TERMIOS_DISABLED
CONFIGURE_TICKS_PER_TIMESLICE
CONFIGURE_UNIFIED_WORK_AREAS
CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
int16_t
int32_t
int64_t
int8_t
posix_api_configuration_table
posix_initialization_threads_table
rtems extensions table index
rtems_address
rtems_api_configuration_table
rtems_asr
rtems_asr_entry
rtems_attribute
rtems_barrier_create
rtems_barrier_delete
rtems_barrier_ident
rtems_barrier_release
rtems_barrier_wait
rtems_boolean
rtems_build_id
rtems_build_name
rtems_chain_append
rtems_chain_are_nodes_equal
rtems_chain_extract
rtems_chain_get
rtems_chain_has_only_one_node
rtems_chain_head
rtems_chain_initialize
rtems_chain_initialize_empty
rtems_chain_insert
rtems_chain_is_empty
rtems_chain_is_first
rtems_chain_is_head
rtems_chain_is_last
rtems_chain_is_null_node
rtems_chain_is_tail
rtems_chain_prepend
rtems_chain_tail
rtems_clock_get
rtems_clock_get_options
rtems_clock_get_seconds_since_epoch
rtems_clock_get_ticks_per_second
rtems_clock_get_ticks_since_boot
rtems_clock_get_tod
rtems_clock_get_tod_timeval
rtems_clock_get_uptime
rtems_clock_set
rtems_clock_set_nanoseconds_extension
rtems_clock_tick
rtems_configuration_table
rtems_context
rtems_context_fp
rtems_device_driver
rtems_device_driver_entry
rtems_device_major_number
rtems_device_minor_number
rtems_double
rtems_driver_address_table
rtems_event_receive
rtems_event_send
rtems_event_set
rtems_extension
rtems_extension_create
rtems_extension_delete
rtems_extension_ident
rtems_extensions_table
rtems_fatal_error_occurred
rtems_fatal_extension
rtems_id
rtems_initialization_tasks_table
rtems_initialize_before_drivers
rtems_initialize_data_structures
rtems_initialize_device_drivers
rtems_initialize_start_multitasking
rtems_interrupt_catch
rtems_interrupt_disable
rtems_interrupt_enable
rtems_interrupt_flash
rtems_interrupt_frame
rtems_interrupt_is_in_progress
rtems_interrupt_level
rtems_interval
rtems_io_close
rtems_io_control
rtems_io_initialize
rtems_io_lookup_name
rtems_io_open
rtems_io_read
rtems_io_register_driver
rtems_io_register_name
rtems_io_unregister_driver
rtems_io_write
rtems_isr
rtems_isr_entry
rtems_iterate_over_all_threads
rtems_message_queue_broadcast
rtems_message_queue_create
rtems_message_queue_delete
rtems_message_queue_flush
rtems_message_queue_get_number_pending
rtems_message_queue_ident
rtems_message_queue_receive
rtems_message_queue_send
rtems_message_queue_urgent
rtems_mode
rtems_mp_packet_classes
rtems_mpci_entry
rtems_mpci_get_packet_entry
rtems_mpci_initialization_entry
rtems_mpci_receive_packet_entry
rtems_mpci_return_packet_entry
rtems_mpci_send_packet_entry
rtems_mpci_table
rtems_multiprocessing_announce
rtems_name
rtems_object_api_maximum_class
rtems_object_api_minimum_class
rtems_object_get_api_class_name
rtems_object_get_api_name
rtems_object_get_class_information
rtems_object_get_name
rtems_object_id_api_maximum
rtems_object_id_api_minimum
rtems_object_id_get_api
rtems_object_id_get_class
rtems_object_id_get_index
rtems_object_id_get_node
rtems_object_name
rtems_object_set_name
rtems_option
rtems_packet_prefix
rtems_partition_create
rtems_partition_delete
rtems_partition_get_buffer
rtems_partition_ident
rtems_partition_return_buffer
rtems_port_create
rtems_port_delete
rtems_port_external_to_internal
rtems_port_ident
rtems_port_internal_to_external
rtems_rate_monotonic_cancel
rtems_rate_monotonic_create
rtems_rate_monotonic_delete
rtems_rate_monotonic_get_statistics
rtems_rate_monotonic_get_status
rtems_rate_monotonic_ident
rtems_rate_monotonic_period
rtems_rate_monotonic_period_statistics
rtems_rate_monotonic_period_status
rtems_rate_monotonic_report_statistics
rtems_rate_monotonic_reset_all_statistics
rtems_rate_monotonic_reset_statistics
rtems_region_create
rtems_region_delete
rtems_region_extend
rtems_region_get_segment
rtems_region_get_segment_size
rtems_region_ident
rtems_region_resize_segment
rtems_region_return_segment
rtems_semaphore_create
rtems_semaphore_delete
rtems_semaphore_flush
rtems_semaphore_ident
rtems_semaphore_obtain
rtems_semaphore_release
rtems_shutdown_executive
rtems_signal_catch
rtems_signal_send
rtems_signal_set
rtems_single
rtems_status_codes
rtems_task
rtems_task_argument
rtems_task_begin_extension
rtems_task_create
rtems_task_create_extension
rtems_task_delete
rtems_task_delete_extension
rtems_task_entry
rtems_task_exitted_extension
rtems_task_get_note
rtems_task_ident
rtems_task_is_suspended
rtems_task_mode
rtems_task_priority
rtems_task_restart
rtems_task_restart_extension
rtems_task_resume
rtems_task_self
rtems_task_set_note
rtems_task_set_priority
rtems_task_start
rtems_task_start_extension
rtems_task_suspend
rtems_task_switch_extension
rtems_task_variable_add
rtems_task_variable_delete
rtems_task_variable_get
rtems_task_wake_after
rtems_task_wake_when
rtems_tcb
rtems_time_of_day
rtems_timer_cancel
rtems_timer_create
rtems_timer_delete
rtems_timer_fire_after
rtems_timer_fire_when
rtems_timer_ident
rtems_timer_initiate_server
rtems_timer_reset
rtems_timer_server_fire_after
rtems_timer_server_fire_when
rtems_timer_service_routine
rtems_timer_service_routine_entry
rtems_vector_number
uint16_t
uint32_t
uint64_t
uint8_t
uintptr_t
