rtems_status_code rtems_region_extend( rtems_id id, void *starting_address, intptr_t length );
RTEMS_SUCCESSFUL
- region extended successfully
RTEMS_INVALID_ADDRESS
- starting_address
is NULL
RTEMS_INVALID_ID
- invalid region id
- invalid address of area to add
This directive adds the memory which starts at starting_address for length bytes to the region specified by id.
This directive will not cause the calling task to be preempted.
The calling task does not have to be the task that created the region. Any local task that knows the region id can extend the region.
