RTEMS Logo
RTEMS 4.10.2 On-Line Library
Chains Insert a Node
PREV UP NEXT Bookshelf RTEMS C User's Guide
28.4.15: Insert a Node
CALLING SEQUENCE:
void rtems_chain_insert(
  rtems_chain_node *after_node,
  rtems_chain_node *the_node
RETURNS
Returns nothing.
DESCRIPTION:
This routine inserts a node on a chain immediately following the specified node.
NOTES:
Interrupts are disabled during the insert to ensure the atomicity of the operation.
Use rtems_chain_insert_unprotected() to avoid disabling of interrupts.
