rtems_status_code rtems_clock_get( rtems_clock_get_options option, void *time_buffer );
RTEMS_SUCCESSFUL - current time obtained successfully
RTEMS_NOT_DEFINED - system date and time is not set
RTEMS_INVALID_ADDRESS - time_buffer is NULL
This directive obtains the system date and time. If
the caller is attempting to obtain the date and time (i.e.
option is set to either RTEMS_CLOCK_GET_SECONDS_SINCE_EPOCH,
RTEMS_CLOCK_GET_TOD, or
RTEMS_CLOCK_GET_TIME_VALUE) and the date and time
has not been set with a previous call to
rtems_clock_set, then the
RTEMS_NOT_DEFINED status code is returned.
The caller can always obtain the number of ticks per second (option is
RTEMS_CLOCK_GET_TICKS_PER_SECOND) and the number of
ticks since the executive was initialized option is
RTEMS_CLOCK_GET_TICKS_SINCE_BOOT).
The option argument may taken on any value of the enumerated
type rtems_clock_get_options. The data type expected for
time_buffer is based on the value of option as
indicated below:
RTEMS_CLOCK_GET_TOD - (rtems_time_of_day *)
RTEMS_CLOCK_GET_SECONDS_SINCE_EPOCH - (rtems_interval *)
RTEMS_CLOCK_GET_TICKS_SINCE_BOOT - (rtems_interval *)
RTEMS_CLOCK_GET_TICKS_PER_SECOND - (rtems_interval *)
RTEMS_CLOCK_GET_TIME_VALUE - (struct timeval *)
This directive is callable from an ISR.
This directive will not cause the running task to be
preempted. Re-initializing RTEMS causes the system date and
time to be reset to an uninitialized state. Another call to
rtems_clock_set is required to re-initialize the
system date and time to application specific specifications.
