RTEMS 4.10.0 On-Line Library
Input and Output Primitives Manager Directives
RTEMS POSIX API User's Guide
5.4: Directives
Input and Output Primitives Manager pipe - Create an Inter-Process Channel
Input and Output Primitives Manager dup - Duplicates an open file descriptor
Input and Output Primitives Manager dup2 - Duplicates an open file descriptor
Input and Output Primitives Manager close - Closes a file
Input and Output Primitives Manager read - Reads from a file
Input and Output Primitives Manager write - Writes to a file
Input and Output Primitives Manager fcntl - Manipulates an open file descriptor
Input and Output Primitives Manager lseek - Reposition read/write file offset
Input and Output Primitives Manager fsync - Synchronize file complete in-core state with that on disk
Input and Output Primitives Manager fdatasync - Synchronize file in-core data with that on disk
Input and Output Primitives Manager sync - Schedule file system updates
Input and Output Primitives Manager mount - Mount a file system
Input and Output Primitives Manager unmount - Unmount file systems
Input and Output Primitives Manager readv - Vectored read from a file
Input and Output Primitives Manager writev - Vectored write to a file
Input and Output Primitives Manager aio_read - Asynchronous Read
Input and Output Primitives Manager aio_write - Asynchronous Write
Input and Output Primitives Manager lio_listio - List Directed I/O
Input and Output Primitives Manager aio_error - Retrieve Error Status of Asynchronous I/O Operation
Input and Output Primitives Manager aio_return - Retrieve Return Status Asynchronous I/O Operation
Input and Output Primitives Manager aio_cancel - Cancel Asynchronous I/O Request
Input and Output Primitives Manager aio_suspend - Wait for Asynchronous I/O Request
Input and Output Primitives Manager aio_fsync - Asynchronous File Synchronization
This section details the input and output primitives manager's directives.
A subsection is dedicated to each of this manager's directives
and describes the calling sequence, related constants, usage,
and status codes.
