RTEMS Logo
RTEMS 4.10.0 On-Line Library
Input and Output Primitives Manager mount - Mount a file system
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
5.4.12: mount - Mount a file system
CALLING SEQUENCE:
#include <libio.h>
int mount(
  rtems_filesystem_mount_table_entry_t **mt_entry,
  rtems_filesystem_operations_table    *fs_ops,
  rtems_filesystem_options_t            fsoptions,
  char                                 *device,
  char                                 *mount_point
STATUS CODES:
EXXX
DESCRIPTION:
The mount routines mounts the filesystem class which uses the filesystem operations specified by fs_ops and fsoptions. The filesystem is mounted at the directory mount_point and the mode of the mounted filesystem is specified by fsoptions. If this filesystem class requires a device, then the name of the device must be specified by device.
If this operation succeeds, the mount table entry for the mounted filesystem is returned in mt_entry.
NOTES:
NONE
