Input and Output Primitives Manager write - Writes to a file
RTEMS POSIX API User's Guide
5.4.6: write - Writes to a file
CALLING SEQUENCE:
#include <unistd.h>
int write(
int fildes,
const void *buf,
unsigned int nbytes
STATUS CODES:
EAGAIN
The O_NONBLOCK flag is set for a file descriptor and the process
would be delayed in the I/O operation.
EBADF
Invalid file descriptor
EFBIG
An attempt was made to write to a file that exceeds the maximum file
size
EINTR
The function was interrupted by a signal.
EIO
Input or output error.
ENOSPC
No space left on disk.
EPIPE
Attempt to write to a pope or FIFO with no reader.
EINVAL
Bad buffer pointer
DESCRIPTION:
The write() function writes nbyte from the array pointed
to by buf into the file associated with fildes.
If nybte is zero and the file is a regular file, the write()
function returns zero and has no other effect. If nbyte is zero
and the file is a special file, te results are not portable.
The write() function returns the number of bytes written. This
number will be less than nbytes if there is an error. It will never
be greater than nbytes.
