#include <sys/uio.h> ssize_t readv( int fd, const struct iovec *iov, int iovcnt );
In addition to the errors detected by
Input and Output Primitives Manager read - Reads from a file, read(),
this routine may return -1 and sets errno based upon the following
errors:
iov_len values in the iov array overflowed an
ssize_t.
iovcnt argument was less than or equal to 0, or greater
than IOV_MAX.
The readv() function is equivalent to read()
except as described here. The readv() function shall place
the input data into the iovcnt buffers specified by the
members of the iov array: iov[0], iov[1], ..., iov[iovcnt-1].
Each iovec entry specifies the base address and length of an area
in memory where data should be placed. The readv() function
always fills an area completely before proceeding to the next.
NONE
