RTEMS 4.10.0 On-Line Library
Process Environment Manager Directives
RTEMS POSIX API User's Guide
3.4: Directives
Process Environment Manager getpid - Get Process ID
Process Environment Manager getppid - Get Parent Process ID
Process Environment Manager getuid - Get User ID
Process Environment Manager geteuid - Get Effective User ID
Process Environment Manager getgid - Get Real Group ID
Process Environment Manager getegid - Get Effective Group ID
Process Environment Manager setuid - Set User ID
Process Environment Manager setgid - Set Group ID
Process Environment Manager getgroups - Get Supplementary Group IDs
Process Environment Manager getlogin - Get User Name
Process Environment Manager getlogin_r - Reentrant Get User Name
Process Environment Manager getpgrp - Get Process Group ID
Process Environment Manager setsid - Create Session and Set Process Group ID
Process Environment Manager setpgid - Set Process Group ID for Job Control
Process Environment Manager uname - Get System Name
Process Environment Manager times - Get process times
Process Environment Manager getenv - Get Environment Variables
Process Environment Manager setenv - Set Environment Variables
Process Environment Manager ctermid - Generate Terminal Pathname
Process Environment Manager ttyname - Determine Terminal Device Name
Process Environment Manager ttyname_r - Reentrant Determine Terminal Device Name
Process Environment Manager isatty - Determine if File Descriptor is Terminal
Process Environment Manager sysconf - Get Configurable System Variables
This section details the process environment manager's directives.
A subsection is dedicated to each of this manager's directives
and describes the calling sequence, related constants, usage,
and status codes.
